Monitor device
Quote
  [ Mixed Reality headset [NoDB] ]
    Monitor Properties:
      Monitor Name                                      Mixed Reality headset [NoDB]
      Monitor ID                                        SEC144A
      Model                                             SEC144A
      Manufacture Date                                  Week 1 / 2017
      Serial Number                                     None
      Max. Visible Display Size                         2880 mm x 1600 mm (129.7")
      Picture Aspect Ratio                              16:9
      Gamma                                             2.20
      DPMS Mode Support                                 None
    Supported Video Modes:
      2880 x 1600                                       Pixel Clock: 296.39 MHz
      2880 x 1600                                       Pixel Clock: 299.72 MHz
      2880 x 1600                                       Pixel Clock: 449.60 MHz
It's Samsung HMD Odyssey (original edition, not "plus" one): https://www.samsung.com/us/support/computing/hmd/hmd-odyssey
Info from Monitor Asset Manager if needed:
Quote
Monitor
  Model name............... SEC144A
  Windows description...... Mixed Reality headset
  Manufacturer............. Samsung
  Plug and Play ID......... SEC144A
  Serial number............ n/a
  Manufacture date......... 2017, ISO week 1
  Filter driver............ None
  EDID revision............ 1.3
  Input signal type........ Digital
  Color bit depth.......... Undefined
  Display type............. RGB color
  Screen size.............. Undefined or variable
  Power management......... Not supported
  Extension blocs.......... 1 (Unknown type)
  DDC/CI................... n/a
Color characteristics
  Default color space...... Non-sRGB
  Display gamma............ 2,20
  Red chromaticity......... Rx 0,625 - Ry 0,340
  Green chromaticity....... Gx 0,280 - Gy 0,595
  Blue chromaticity........ Bx 0,155 - By 0,070
  White point (default).... Wx 0,283 - Wy 0,298
  Additional descriptors... None
Timing characteristics
  Range limits............. Not available
  GTF standard............. Not supported
  Preferred timing......... Yes
  Native/preferred timing.. 2880x1600p at 90Hz
    Modeline............... "2880x1600" 449,600 2880 2994 3026 3076 1600 1610 1612 1624 -hsync -vsync
  Detailed timing #1....... 2880x1600p at 60Hz
    Modeline............... "2880x1600" 299,720 2880 2994 3026 3076 1600 1610 1612 1624 -hsync -vsync
  Detailed timing #2....... 2880x1600p at 60Hz
    Modeline............... "2880x1600" 296,390 2880 2980 3012 3042 1600 1610 1612 1624 -hsync -vsync
Standard timings supported
Report information
  Date generated........... 11.04.2020
  Software revision........ 2.90.0.1020
  Data source.............. Registry
  Operating system......... 10.0.18363.2
Raw data
  00,FF,FF,FF,FF,FF,FF,00,4C,A3,4A,14,00,00,00,00,01,1B,01,03,80,00,00,78,0A,0D,C9,A0,57,47,98,27,
  12,48,4C,00,00,00,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,01,A0,AF,40,C4,B0,40,18,60,72,20,
  A2,00,40,40,B6,00,00,18,14,75,40,C4,B0,40,18,60,72,20,A2,00,40,40,B6,00,00,18,C7,73,40,A2,B0,40,
  18,60,64,20,A2,00,40,40,B6,00,00,18,00,00,00,FC,00,53,45,43,31,34,34,41,20,20,20,20,20,0A,01,06
On 4/11/2020 at 3:03 AM, mastan said:
Monitor device
Monitor device
I'm afraid that monitor device has no identification strings in the EDID block, so we cannot add it to our monitor database.
