When I start stress test for my gpu (im on a laptop with intel integrated graphics and nivdia 1050ti) it says that both gpus are being stress tested butt my task manager says that only the integrated graphics are on 100% load and nvidia on 0%. Also HW monitor says that both are being stress tested and not ony the integrated.
What should I do?
What should I do?
Try to enable the option called Wake GPUs up at AIDA64 startup in AIDA64 / main menu / File / Preferences / Stability, and restart AIDA64 to apply the changes.  Let me know if it helps.
