Egik81 Posted November 18, 2011 Posted November 18, 2011 Hello. The program defines that status L3-Cache is disable. Though though as that regulate management a cache memory I can't. It is a bug or at me problems with the equipment? --------[ AIDA64 Extreme Edition ]-------------------------------------------------------------------------------------- Version AIDA64 v2.00.1720 Beta Benchmark Module 2.7.391-x64 Homepage http://www.aida64.com/ Report Type Quick Report [ TRIAL VERSION ] Computer ADMIN-ПК Generator Admin Operating System Microsoft Windows 7 Home Premium 6.1.7601 (Win7 RTM) Date 2011-11-18 Time 05:12 --------[ DMI ]--------------------------------------------------------------------------------------------------------- [ BIOS ] BIOS Properties: Vendor American Megatrends Inc. Version P1.60 Release Date 07/08/2011 Size 8192 KB Boot Devices Floppy Disk, Hard Disk, CD-ROM Capabilities Flash BIOS, Shadow BIOS, Selectable Boot, EDD, BBS Supported Standards DMI, ACPI Expansion Capabilities PCI, USB BIOS Manufacturer: Company Name American Megatrends Inc. Product Information http://www.ami.com/amibios BIOS Upgrades http://www.aida64.com/bios-updates [ System ] System Properties: Manufacturer To Be Filled By O.E.M. Product To Be Filled By O.E.M. Version To Be Filled By O.E.M. Serial Number [ TRIAL VERSION ] SKU# To Be Filled By O.E.M. Family To Be Filled By O.E.M. Universal Unique ID [ TRIAL VERSION ] Wake-Up Type Power Switch [ Motherboard ] Motherboard Properties: Manufacturer ASRock Product H67DE3 Serial Number [ TRIAL VERSION ] Motherboard Manufacturer: Company Name ASRock Inc. Product Information http://www.asrock.com/mb/index.asp?s=n BIOS Download http://www.asrock.com/support/Download.asp Driver Update http://www.aida64.com/driver-updates BIOS Upgrades http://www.aida64.com/bios-updates [ Chassis ] Chassis Properties: Manufacturer To Be Filled By O.E.M. Version To Be Filled By O.E.M. Serial Number [ TRIAL VERSION ] Asset Tag [ TRIAL VERSION ] Chassis Type Desktop Case Boot-Up State Safe Power Supply State Safe Thermal State Safe Security Status None [ Processors / Intel® Core i7-2600 CPU @ 3.40GHz ] Processor Properties: Manufacturer Intel Version Intel® Core i7-2600 CPU @ 3.40GHz Serial Number To Be Filled By O.E.M. Asset Tag To Be Filled By O.E.M. Part Number To Be Filled By O.E.M. External Clock 100 MHz Maximum Clock 3800 MHz Current Clock 3400 MHz Type Central Processor Status Enabled Socket Designation CPUSocket HTT / CMP Units 0 / 4 CPU Manufacturer: Company Name Intel Corporation Product Information http://ark.intel.com/search.aspx?q=Intel Core i7-2600 Driver Update http://www.aida64.com/driver-updates [ Caches / L1-Cache ] Cache Properties: Type Internal Status Enabled Operational Mode Write-Through Associativity 8-way Set-Associative Maximum Size 128 KB Installed Size 128 KB Error Correction None Socket Designation L1-Cache [ Caches / L2-Cache ] Cache Properties: Type Internal Status Enabled Operational Mode Write-Through Associativity 8-way Set-Associative Maximum Size 1024 KB Installed Size 1024 KB Error Correction None Socket Designation L2-Cache [ Caches / L3-Cache ] Cache Properties: Type Internal Status Disabled Operational Mode Write-Back Associativity 16-way Set-Associative Maximum Size 8192 KB Installed Size 8192 KB Error Correction None Socket Designation L3-Cache [ Memory Devices / A1_DIMM0 ] Memory Device Properties: Form Factor DIMM Type Detail Synchronous Size 2048 MB Speed 1333 MHz Total Width 64-bit Data Width 64-bit Device Locator A1_DIMM0 Bank Locator A1_BANK0 Manufacturer Corsair Serial Number 00000000 Asset Tag A1_AssetTagNum0 Part Number VS2GB1333D4 [ Memory Devices / A1_DIMM1 ] Memory Device Properties: Form Factor DIMM Type Detail Synchronous Size 2048 MB Speed 1333 MHz Total Width 64-bit Data Width 64-bit Device Locator A1_DIMM1 Bank Locator A1_BANK1 Manufacturer Corsair Serial Number 00000E42 Asset Tag A1_AssetTagNum1 Part Number VS2GB1333D4 [ Memory Devices / A1_DIMM2 ] Memory Device Properties: Form Factor DIMM Type Detail Synchronous Size 2048 MB Speed 1333 MHz Total Width 64-bit Data Width 64-bit Device Locator A1_DIMM2 Bank Locator A1_BANK2 Manufacturer Corsair Serial Number 00000000 Asset Tag A1_AssetTagNum2 Part Number VS2GB1333D4 [ Memory Devices / A1_DIMM3 ] Memory Device Properties: Form Factor DIMM Type Detail Synchronous Size 2048 MB Speed 1333 MHz Total Width 64-bit Data Width 64-bit Device Locator A1_DIMM3 Bank Locator A1_BANK3 Manufacturer Corsair Serial Number 00000E43 Asset Tag A1_AssetTagNum3 Part Number VS2GB1333D4 [ System Slots / PCI1 ] System Slot Properties: Slot Designation PCI1 Type PCI Usage In Use Data Bus Width 32-bit Length Short [ System Slots / PCI2 ] System Slot Properties: Slot Designation PCI2 Type PCI Usage In Use Data Bus Width 32-bit Length Short [ System Slots / PCIE1 ] System Slot Properties: Slot Designation PCIE1 Type PCI-E x1 Usage In Use Data Bus Width x16 Length Long [ System Slots / PCIE2 ] System Slot Properties: Slot Designation PCIE2 Type PCI-E x1 Usage In Use Data Bus Width x1 Length Short [ System Slots / PCIE3 ] System Slot Properties: Slot Designation PCIE3 Type PCI-E x1 Usage In Use Data Bus Width x1 Length Short [ System Slots / PCIE4 ] System Slot Properties: Slot Designation PCIE4 Type PCI-E x1 Usage In Use Data Bus Width x1 Length Short [ Miscellaneous ] Miscellaneous: OEM String To Be Filled By O.E.M. --------[ Debug - PCI ]------------------------------------------------------------------------------------------------- B00 D00 F00: Intel Sandy Bridge-DT - Host Bridge/DRAM Controller Offset 000: 86 80 00 01 06 00 90 20 09 00 00 06 00 00 00 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 49 18 00 01 Offset 030: 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 01 90 D1 FE 00 00 00 00 01 00 D1 FE 00 00 00 00 Offset 050: 03 00 00 00 09 00 00 00 00 00 00 00 01 00 80 BF Offset 060: 01 00 00 E0 00 00 00 00 01 80 D1 FE 00 00 00 00 Offset 070: 00 00 80 FF 01 00 00 00 00 0C 80 FF 7F 00 00 00 Offset 080: 10 11 11 00 00 00 11 00 1A 00 00 00 00 00 00 00 Offset 090: 01 00 80 FF 01 00 00 00 01 00 70 3F 02 00 00 00 Offset 0A0: 01 00 00 00 02 00 00 00 01 00 80 3F 02 00 00 00 Offset 0B0: 01 00 00 C0 01 00 00 C0 01 00 80 BF 01 00 00 C0 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 09 00 0C 01 96 A0 00 E2 90 00 00 16 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 B8 0F 06 00 00 00 00 00 B00 D01 F00: Intel Sandy Bridge-DT - PCI Express Graphics Root Port Offset 000: 86 80 01 01 07 00 10 00 09 00 04 06 10 00 81 00 Offset 010: 00 00 00 00 00 00 00 00 00 01 01 00 E0 E0 00 20 Offset 020: 50 FE 50 FE 01 D0 F1 DF 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 88 00 00 00 00 00 00 00 10 01 18 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0A Offset 080: 01 90 03 C8 08 00 00 00 0D 80 00 00 49 18 01 01 Offset 090: 05 A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 10 00 42 01 00 80 00 00 00 00 00 00 02 2D 21 02 Offset 0B0: 40 00 02 D1 80 25 04 00 00 00 48 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 08 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 01 00 00 00 00 00 00 00 10 00 B00 D16 F00: Intel Cougar Point PCH - Manageability Engine Interface 1 [b-2] Offset 000: 86 80 3A 1C 06 00 10 00 04 00 80 07 00 00 80 00 Offset 010: 04 40 60 FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 49 18 3A 1C Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 0B 01 00 00 Offset 040: 45 02 00 1E 08 00 01 80 06 00 00 60 F8 1F 00 10 Offset 050: 01 8C 03 C8 08 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 05 00 80 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 C0 Offset 0C0: 57 12 23 A9 E2 C5 AB 64 38 94 6C 67 8C DA 94 0F Offset 0D0: FD 06 FA 08 39 1B 20 5C 83 21 CF 65 BE 02 FC 7F Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B00 D1A F00: Intel Cougar Point PCH - USB EHCI #2 Controller [b-3] Offset 000: 86 80 2D 1C 06 00 90 02 05 20 03 0C 00 00 00 00 Offset 010: 00 30 60 FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 49 18 2D 1C Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00 Offset 060: 20 20 FF 07 00 00 00 00 01 00 00 00 00 00 00 C0 Offset 070: 00 00 FF 3F 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 80 00 11 88 0C 93 30 0D 00 24 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 09 22 80 89 CC 00 90 00 04 18 50 86 Offset 0F0: 00 00 00 00 88 85 80 00 87 0F 05 08 E8 17 5B 20 B00 D1C F00: Intel Cougar Point PCH - PCI Express Port 1 [b-3] Offset 000: 86 80 10 1C 04 00 10 00 B5 00 04 06 10 00 81 00 Offset 010: 00 00 00 00 00 00 00 00 00 02 02 00 F0 00 00 20 Offset 020: F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 11 01 00 00 Offset 040: 10 80 42 01 00 80 00 00 00 00 10 00 12 4C 11 01 Offset 050: 00 00 01 10 00 B2 04 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 16 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 01 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 0D A0 00 00 49 18 10 1C 00 00 00 00 00 00 00 00 Offset 0A0: 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 01 00 0B 00 00 00 80 11 01 00 00 00 00 Offset 0E0: 00 03 00 00 00 00 00 00 03 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 87 0F 05 08 00 00 00 00 B00 D1C F02: Intel Cougar Point PCH - PCI Express Port 3 [b-3] Offset 000: 86 80 14 1C 05 00 10 00 B5 00 04 06 10 00 81 00 Offset 010: 00 00 00 00 00 00 00 00 00 03 03 00 D0 D0 00 00 Offset 020: F0 FF 00 00 F1 FF 01 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 12 03 00 00 Offset 040: 10 80 42 01 00 80 00 00 00 00 10 00 12 3C 11 03 Offset 050: 40 00 11 70 00 B2 14 00 00 00 40 01 00 00 00 00 Offset 060: 00 00 00 00 16 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 0D A0 00 00 49 18 14 1C 00 00 00 00 00 00 00 00 Offset 0A0: 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 01 00 0B 00 00 00 80 11 01 00 00 00 00 Offset 0E0: 00 03 00 00 00 00 00 00 03 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 87 0F 05 08 00 00 00 00 B00 D1C F04: Intel Cougar Point PCH - PCI Express Port 5 [b-3] Offset 000: 86 80 18 1C 07 00 10 00 B5 00 04 06 10 00 81 00 Offset 010: 00 00 00 00 00 00 00 00 00 04 05 00 C0 C0 00 20 Offset 020: 00 FE 40 FE F1 FF 01 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 11 01 00 00 Offset 040: 10 80 42 01 00 80 00 00 00 00 10 00 12 4C 11 05 Offset 050: 00 00 11 30 00 B2 24 00 00 00 40 01 00 00 00 00 Offset 060: 00 00 00 00 16 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 02 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 05 90 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 0D A0 00 00 49 18 18 1C 00 00 00 00 00 00 00 00 Offset 0A0: 01 00 02 C8 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 01 00 0B 00 00 00 80 11 01 00 00 00 00 Offset 0E0: 00 03 00 00 00 00 00 00 03 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 87 0F 05 08 00 00 00 00 B00 D1D F00: Intel Cougar Point PCH - USB EHCI #1 Controller [b-3] Offset 000: 86 80 26 1C 06 00 90 02 05 20 03 0C 00 00 00 00 Offset 010: 00 20 60 FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 49 18 26 1C Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 17 01 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 58 C2 C9 00 00 00 00 0A 98 A0 20 00 00 00 00 Offset 060: 20 20 FF 07 00 00 00 00 01 00 00 00 00 00 00 C0 Offset 070: 00 00 FF 3F 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 80 00 11 88 0C 93 30 0D 00 24 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 13 00 06 03 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 AA FF 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 D8 04 16 0C 00 08 2C 30 00 10 DD 08 Offset 0F0: 00 00 00 00 88 85 80 00 87 0F 05 08 E8 17 5B 20 B00 D1F F00: Intel H67 PCH - LPC Interface Controller [b-3] Offset 000: 86 80 4A 1C 07 00 10 02 05 00 01 06 00 00 80 00 Offset 010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 49 18 4A 1C Offset 030: 00 00 00 00 E0 00 00 00 00 00 00 00 00 00 00 00 Offset 040: 01 04 00 00 80 00 00 00 01 05 00 00 10 00 00 00 Offset 050: F8 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 8B 8A 85 85 D0 00 00 00 80 80 80 85 F8 F0 00 00 Offset 070: 78 F0 79 F0 7A F0 7B F0 7C F0 7D F0 7E F0 7F F0 Offset 080: 10 00 00 3F 91 02 0C 00 41 02 0C 00 51 02 0C 00 Offset 090: 00 00 00 00 00 0F 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 08 0A 80 00 09 18 06 00 00 47 00 00 00 03 00 80 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 33 22 11 00 67 45 00 00 C0 FF 00 00 00 00 00 00 Offset 0E0: 09 00 0C 10 00 00 00 00 93 02 64 0C 00 00 00 00 Offset 0F0: 01 C0 D1 FE 00 00 00 00 87 0F 05 08 00 00 00 00 B00 D1F F02: Intel Cougar Point PCH - SATA AHCI 6-Port Controller [b-3] Offset 000: 86 80 02 1C 07 00 B0 02 05 01 06 01 00 00 00 00 Offset 010: 71 F0 00 00 61 F0 00 00 51 F0 00 00 41 F0 00 00 Offset 020: 21 F0 00 00 00 10 60 FE 00 00 00 00 49 18 02 1C Offset 030: 00 00 00 00 80 00 00 00 00 00 00 00 13 02 00 00 Offset 040: 00 00 00 00 07 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 01 A8 03 40 08 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 05 70 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 60 00 3F 8C 83 01 00 00 08 42 5C 01 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 12 B0 10 00 48 00 00 00 Offset 0B0: 13 00 06 03 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 87 0F 05 08 00 00 00 00 B00 D1F F03: Intel Cougar Point PCH - SMBus Controller [b-3] Offset 000: 86 80 22 1C 03 00 80 02 05 00 05 0C 00 00 00 00 Offset 010: 04 00 60 FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 01 F0 00 00 00 00 00 00 00 00 00 00 49 18 22 1C Offset 030: 00 00 00 00 00 00 00 00 00 00 00 00 05 03 00 00 Offset 040: 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 03 04 04 00 00 00 08 08 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 87 0F 05 08 00 00 00 00 B00 D1F F06: Intel Cougar Point PCH - Thermal Management Controller [b-3] Offset 000: 86 80 24 1C 00 00 10 00 05 00 80 11 00 00 00 00 Offset 010: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 00 03 00 00 Offset 040: 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 00 23 00 08 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 87 0F 05 08 00 00 00 00 B01 D00 F00: Asus EAH6850 Video Adapter Offset 000: 02 10 39 67 07 04 10 00 00 00 00 03 10 00 80 00 Offset 010: 0C 00 00 D0 00 00 00 00 04 00 52 FE 00 00 00 00 Offset 020: 01 E0 00 00 00 00 00 00 00 00 00 00 43 10 B4 03 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 00 01 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 B4 03 Offset 050: 01 58 03 06 00 00 00 00 10 A0 12 00 A1 8F 2C 01 Offset 060: 00 29 09 00 02 0D 00 00 40 00 02 11 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 05 00 81 00 0C F0 EF FE 00 00 00 00 B0 49 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B01 D00 F01: AMD Barts - High Definition Audio Controller Offset 000: 02 10 88 AA 06 00 10 00 00 00 03 04 10 00 80 00 Offset 010: 04 00 54 FE 00 00 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 88 AA Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 11 02 00 00 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 43 10 88 AA Offset 050: 01 58 03 06 00 00 00 00 10 A0 12 00 A1 8F 2C 01 Offset 060: 00 29 09 00 02 0D 00 00 40 00 02 11 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B03 D00 F00: PCI Express ECP Parallel Port (LPT1) [1415-C110] [NoDB] Offset 000: 15 14 10 C1 05 00 10 00 00 02 01 07 10 00 00 00 Offset 010: 11 D0 00 00 01 D0 00 00 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 15 14 10 C1 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 12 01 00 00 Offset 040: 01 50 43 F6 08 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 05 70 80 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 10 00 11 00 40 82 90 05 00 20 10 00 11 FC 07 00 Offset 080: 40 00 11 10 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 11 00 0F 00 01 30 1B 00 01 20 1B 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B04 D00 F00: ASMedia ASM1083 PCI-E to PCI Bridge Controller Offset 000: 21 1B 80 10 07 00 10 00 01 00 04 06 10 00 01 00 Offset 010: 00 00 00 00 00 00 00 00 04 05 05 20 C1 C1 20 20 Offset 020: 00 FE 40 FE F1 FF 01 00 00 00 00 00 00 00 00 00 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 10 01 00 00 Offset 040: 20 00 00 00 00 07 00 00 00 00 00 00 A7 27 00 00 Offset 050: 05 78 80 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 11 78 01 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 01 80 23 FE 08 01 00 00 Offset 080: 10 C0 71 00 00 80 90 05 00 28 02 00 11 DC 00 01 Offset 090: 00 00 11 00 00 00 00 00 C0 03 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 0D 00 00 00 49 18 80 10 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B05 D00 F00: Creative SB X-Fi XtremeMusic/Platinum Sound Card Offset 000: 02 11 05 00 07 00 10 02 00 00 01 04 00 20 00 00 Offset 010: 01 C1 00 00 04 00 20 FE 00 00 00 00 04 00 00 FE Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 02 11 21 00 Offset 030: 00 00 00 00 40 00 00 00 00 00 00 00 10 01 04 05 Offset 040: 01 50 22 06 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 05 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 AA 83 00 00 Offset 0D0: 00 80 00 00 FF FF 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 80 00 1A 00 2B 08 00 00 00 00 00 00 05 00 80 80 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B05 D01 F00: Realtek RTL8139 PCI Fast Ethernet Adapter [A/B/C] Offset 000: EC 10 39 81 07 00 90 02 10 00 00 02 00 20 00 00 Offset 010: 01 C0 00 00 00 00 40 FE 00 00 00 00 00 00 00 00 Offset 020: 00 00 00 00 00 00 00 00 00 00 00 00 EC 10 39 81 Offset 030: 00 00 00 00 50 00 00 00 00 00 00 00 11 01 20 40 Offset 040: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 050: 01 00 C2 F7 00 01 00 00 00 00 00 00 00 00 00 00 Offset 060: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 070: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 080: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 090: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0A0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0B0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0C0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0D0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0E0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 0F0: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 PCI-8086-0100: Intel Sandy Bridge MCHBAR Offset 4000: 99 79 18 00 55 54 19 0A 20 22 02 0A 90 56 00 00 Offset 4010: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 PCI-8086-0100: Intel Sandy Bridge MCHBAR Offset 4280: 00 00 00 00 00 00 0C 00 00 00 00 00 44 00 00 00 Offset 4290: 80 40 00 00 0F 98 00 00 4F 14 6B 5A D0 C4 00 00 PCI-8086-0100: Intel Sandy Bridge MCHBAR Offset 4400: 99 79 18 00 55 54 19 0A 20 22 02 0A 90 56 00 00 Offset 4410: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 PCI-8086-0100: Intel Sandy Bridge MCHBAR Offset 4680: 00 00 00 00 00 00 0C 00 00 00 00 00 44 00 00 00 Offset 4690: 80 40 00 00 0F 98 00 00 4F 14 6B 5A D0 C4 00 00 PCI-8086-0100: Intel Sandy Bridge MCHBAR Offset 4800: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 4810: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 PCI-8086-0100: Intel Sandy Bridge MCHBAR Offset 4A80: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 4A90: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 PCI-8086-0100: Intel Sandy Bridge MCHBAR Offset 5000: 24 00 00 00 08 08 60 00 08 08 60 00 00 00 60 00 Offset 5010: 00 00 00 00 00 00 20 10 00 00 00 00 00 00 00 00 PCI-8086-0100: Intel Sandy Bridge MCHBAR Offset 5940: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 Offset 5950: 00 00 00 00 00 00 04 00 00 22 01 60 00 10 00 00 Offset 5960: 00 00 00 00 77 84 06 5F AC 72 06 5F FB 51 AF 83 Offset 5970: 00 00 00 00 00 00 00 00 25 00 00 00 25 00 00 00 Offset 5980: 25 00 00 00 92 0D 68 02 00 00 00 00 00 00 00 00 Offset 5990: FF 00 00 00 FF 00 00 00 1B 11 11 00 00 12 62 00 PCI-8086-0100: Intel Sandy Bridge MCHBAR Offset 5E00: 05 00 00 00 05 00 00 00 00 00 00 00 00 00 00 00 Offset 5E10: 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 --------[ Debug - Video BIOS ]------------------------------------------------------------------------------------------ C000:0000 U...9.........................IBM............... 761295520...... C000:0040 1...............11/09/10 01:24..3...................h........... C000:0080 . ..........................9g..........113-AC92700-110.BARTS.PC C000:00C0 I_EXPRESS.GDDR5...6739.13.9.0.3.AS01 C000:0100 .. ... ...© 1988-2010, AMD Techno C000:0140 logies Inc. .ATOMBIOSBK-ATI VER013.009.000.003.000000.AC92700.00 C000:0180 4 .607819 .169110 . .ASUS_BARTS_PRO_PWR_Redesign\config C000:01C0 .h....$...ATOM....v...........C.............PCIR..9g........{... C000:0200 ....AMD ATOMBIOS...=Y............5#...@.3%g......V.......LP. .^. C000:0240 .fPfQfRfSfUfVfW..................f......f.(....X.2.......$..$..$ C000:0280 .......H$.^$.......DP. u......d..d.......LP.....Q..DX.......f... C000:02C0 ....fP........fXt.. f............f_f^f]f[fZfYfX.............F.f3 C000:0300 ..F...F..R.....RDZ..........f........f.\.f.L.;.u...f.^.f.N...... C000:0340 ...........>...u.............f....e.....@.....B.............|..m C000:0380 ..~......q.........g.............g..g.)g...PMID..TL............. C000:03C0 .......f.........................fPfR.1f...f....fZfX.fPfR.1f...f --------[ Debug - Unknown ]--------------------------------------------------------------------------------------------- PCI/AGP 1415-C110 [subSys: 1415-C110]: PCI Express ECP Parallel Port (LPT1) [1415-C110] [NoDB] ------------------------------------------------------------------------------------------------------------------------ The names of actual companies and products mentioned herein may be the trademarks of their respective owners. Quote
Fiery Posted November 18, 2011 Posted November 18, 2011 It is due to a BIOS bug about building DMI information. Please check Q#10 at: http://www.aida64.co.../knowledge-base I'm pretty sure the L3 cache isn't actually disabled. You can check the L3 cache size on the Motherboard / CPU page in AIDA64. If it shows a non-zero value there, your L3 cache is enabled. You can also try to run the Cache & Memory Benchmark (AIDA64 / main menu / Tools / Cache & Memory Benchmark) -- you should see a L3 cache read score somewhere between the L2 cache score and the Memory score. Since the L3 cache is a slower buffer than the L2 cache, but faster than the system memory. And BTW, such DMI issues do not affect system performance or stability at all. Regards, Fiery Quote
Egik81 Posted November 19, 2011 Author Posted November 19, 2011 Clearly size of a cache is shown. Testing cache L3 gives out the following data Read 31050 MB/s Write 22914 MB/s Copy 28532 MB/s Latency 5.6 ns That is all is normal. I am right? Quote
Fiery Posted November 24, 2011 Posted November 24, 2011 Clearly size of a cache is shown. Testing cache L3 gives out the following data Read 31050 MB/s Write 22914 MB/s Copy 28532 MB/s Latency 5.6 ns That is all is normal. I am right? Yes, those L3 cache benchmark values look just fine for a Core i7-2600 CPU. The L3 cache is definitely operational in your CPU. Quote
Egik81 Posted December 6, 2011 Author Posted December 6, 2011 Thanks you big for the competent answer. The theme can be closed. Quote
Egik81 Posted January 3, 2012 Author Posted January 3, 2012 I apologize for English. Yesterday at last after inquiry in support service Asrock they have sent BIOS. It most likely a beta or something like it but the problem in it is corrected. Quote
Fiery Posted January 3, 2012 Posted January 3, 2012 I apologize for English. Yesterday at last after inquiry in support service Asrock they have sent BIOS. It most likely a beta or something like it but the problem in it is corrected. Thank you for letting us know. Quote
