Aelb88 Posted June 13, 2020 Posted June 13, 2020 I saw in a previous thread that you at aida64 made support for steelseries keyboards by someone linking a usb dumb file. I have a steelseries arctis pro wireless which has a lcd display on the connector. It would be cool(and I know you are) to have my values on the lcd. I am not the most tech savy guy but I think this is what you are looking for. If not plz reply to me with what you need. Usb dumb.txt Usb dumb.txt Quote
Fiery Posted June 16, 2020 Posted June 16, 2020 On 6/13/2020 at 7:11 PM, Aelb88 said: I saw in a previous thread that you at aida64 made support for steelseries keyboards by someone linking a usb dumb file. I have a steelseries arctis pro wireless which has a lcd display on the connector. It would be cool(and I know you are) to have my values on the lcd. I am not the most tech savy guy but I think this is what you are looking for. If not plz reply to me with what you need. Are you sure it's possible to 3rd party applications to put information on the LCD of the connector? Quote
Aelb88 Posted June 18, 2020 Author Posted June 18, 2020 Uhh I am not sure. I just saw this post. Quote
Aelb88 Posted June 18, 2020 Author Posted June 18, 2020 And I figured it was close to the same. Maybe its easier with the gamedac. It is running through steelseries engine like the apex pro. I can send you dump files for the arctis pro gamedac aswell. But I am not a programmer. So not sure what's possible and whats not. Tho you unmatched make the best all around hardware monitor software. So I believe. Especially because I don't have to do it myself SS GameDac.txt SS GameDac.txt Quote
Aelb88 Posted June 18, 2020 Author Posted June 18, 2020 And sorry for the late reply. I asked to be notified when someone replied. Guess it didn't work. Quote
Fiery Posted June 7, 2025 Posted June 7, 2025 On 6/19/2020 at 12:10 AM, Aelb88 said: And I figured it was close to the same. Maybe its easier with the gamedac. It is running through steelseries engine like the apex pro. I can send you dump files for the arctis pro gamedac aswell. But I am not a programmer. So not sure what's possible and whats not. Tho you unmatched make the best all around hardware monitor software. So I believe. Especially because I don't have to do it myself Thank you for your help! Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Quote
