Fry(NOR) Posted June 20, 2020 Posted June 20, 2020 Hello. I have set up a simple sensor panel on a second screen inside my case, when i use the clock HH:MM:SS the clock seems kinda slow and skips a seconds now and then. My PSU is a Corsair HX1000i and if i disable the HX/RMI-sensor the clock seems too fast and stops for a second. Is there a way to disable the SS part of the clock or something else i can try to fix this?. Quote
Fiery Posted July 9, 2020 Posted July 9, 2020 On 6/20/2020 at 11:24 AM, Fry(NOR) said: Hello. I have set up a simple sensor panel on a second screen inside my case, when i use the clock HH:MM:SS the clock seems kinda slow and skips a seconds now and then. My PSU is a Corsair HX1000i and if i disable the HX/RMI-sensor the clock seems too fast and stops for a second. Is there a way to disable the SS part of the clock or something else i can try to fix this?. There's a sensor item called Time (HH:MM) that you may find useful Quote
