Nicholas Jamelski Posted August 1, 2020 Posted August 1, 2020 Hello I have a question I have a Asus crosshair viii Wi-Fi motherboard and a ek rgb 360 watercooling kit it has a w_pump header and a w_flow header what one do u need to plug the pump into I know water pump but whats the w_flow header for? When I turn my pc on when it's plugged into w_pump header it over heats Quote
Fiery Posted August 1, 2020 Posted August 1, 2020 4 hours ago, Nicholas Jamelski said: Hello I have a question I have a Asus crosshair viii Wi-Fi motherboard and a ek rgb 360 watercooling kit it has a w_pump header and a w_flow header what one do u need to plug the pump into I know water pump but whats the w_flow header for? When I turn my pc on when it's plugged into w_pump header it over heats You need to refer to the user's manual of your motherboard to figure out which fan/pump header is right for your configuration. Quote
