barry.b.brooks Posted September 10, 2020 Posted September 10, 2020 Looking for information or fix for to see the Chipset PCH temperature on my laptop. I looked into this because in HWiNFO, it reports the chipset PCH temperature at a constant 135c, I don't think it's correct as it does not change. Either way, I'd like to know if there is a setting to allow or a fix to enable it to work in AIDA64. attached is the pcidump from AIDA64. pcidump.txt Quote
Fiery Posted September 10, 2020 Posted September 10, 2020 7 hours ago, barry.b.brooks said: Looking for information or fix for to see the Chipset PCH temperature on my laptop. I looked into this because in HWiNFO, it reports the chipset PCH temperature at a constant 135c, I don't think it's correct as it does not change. Either way, I'd like to know if there is a setting to allow or a fix to enable it to work in AIDA64. attached is the pcidump from AIDA64. It seems your laptop has no PCH diode thermal measurement enabled by the BIOS. Quote
