Was wondering if possible could the CPU Fan #2 Speed Sensor be added to the Sensor Listing In AIDA64? It displays in ASRock's UEFI as well as in their eXtreme Tuner application. My CPU cooling solution is Corsairs H100 and therefor the unit is directly connected to a PSU molex (the 2 radiator fans are connected to the units controller) and the only way to monitor the fans speed was to connect the 3-pin monitoring wire to the 3-pin CPU Fan 2 header on the board. The CPU 1 Fan Header on the board is a 4-pin since normally that's what is used to connect the CPU Heatsinks fan...
Thanks and Happy New Years!
Hi Fiery
I saw that thread after I posted this and apologize for wasting your time in answering this one...Shame that 'ASRock is using some "weird GPIO fan muxing on their boards" that only their software can read'
Thanks again for your time :)
