fixed: Voltage values of Be Quiet dark Power Pro 11 correct? (ASRock G41C-GS R2.0)
byw7
Hi i have a question about the display of values at 12 volts.
Why does it say 1.398V?
Can that be correct?
The Aida 64 Version is the 6.25 Business
 Board is a  ASRock G41C-GS R2.0
Regards
That's due to an incorrect voltage ratio or voltage register used by AIDA64 on your motherboard.  We'd be happy to fix it up, if you could submit an ISA Sensor Dump of your motherboard: please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
On 10/7/2020 at 7:34 AM, byw7 said:
Hi Fiery,
when i can expect changes to the AIDA software?
In a pre-beta version
or only with the next release version? (Date)
Kind Regards
byw7
Please upgrade to the latest beta version of AIDA64 Extreme available at:
Let me know how it works.
On 10/23/2020 at 9:28 AM, byw7 said:
Thank you Fiery.
When will all improvements be implemented in a new
Business Version released?
When will the next Business Version be released?
Kind Regards
The next AIDA64 stable release will be rolled out tomorrow.
  • Fiery changed the title to fixed: Voltage values of Be Quiet dark Power Pro 11 correct? (ASRock G41C-GS R2.0)
