Installed a 7" lcd on my case to use with AIDA64. It receives power from the usb header on the mb. Issue is when I shutdown pc for the night, the screen is still powered on.
Is there a windows setting or another way to power it so it will shutoff when I power off the pc?
Thx
Thx
AFAIK usually the BIOS has a setting that allows you to power off USB ports when the computer is off.
