Do you have both RAID related options enabled (checked) in AIDA64 / main menu / File / Preferences / Stability?
RAID member enumeration
RAID SMART support
If yes, then please right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> RAID Dump. Attach the results as a TXT file to your post.  And also right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> Disk Controllers Dump. Attach the results as a TXT file to your post.
