Incorrect temps? (Gigabyte GA-P35-DS3L & Pentium E5200)
This isn't an issue with AIDA64 alone, but I'm curious if there's a fix. For whatever reason the lowest my core temperatures go is 40 C and 35 C. I'm also not convinced the CPU temperature is correct either. It's running a stock HSF and the ambient temp as of writing is 58 F/ 14.44 C. See attached pic. Right now I'm running the latest beta that came out today (2-5-12 or 5-2-12).
Here's the CPUID and MSR dump:
------[ Versions ]------
Program Version : AIDA64 v2.20.1812 Beta
BenchDLL Version: 2.7.398-x64
------[ CPU Info ]------
CPU Type		   : DualCore Intel Pentium E5200, 3133 MHz (12.5 x 251)
CPU Alias		  : Wolfdale-2M
CPU Platform	   : LGA775
CPU Stepping	   : R0
Instruction Set    : x86, x86-64, MMX, SSE, SSE2, SSE3, SSSE3
CPUID Manufacturer : GenuineIntel
CPUID CPU Name	 : Pentium(R) Dual-Core CPU E5200 @ 2.50GHz
CPUID Revision	 : 0001067Ah
IA Brand ID	    : 00h  (Unknown)
Platform ID	    : 2Eh  (LGA775)
HTT / CMP Units    : 0 / 2
Tjmax Temperature  : 100 Celsius
------[ Logical CPU #0 ]------
allcpu: Package 0 / Core 0 / Thread 0: Valid
CPUID 00000000: 0000000D-756E6547-6C65746E-49656E69 [GenuineIntel]
CPUID 00000001: 0001067A-00020800-0C00E39D-BFEBFBFF
CPUID 00000002: 05B0B101-005657F0-00000000-2CB4307D
CPUID 00000003: 00000000-00000000-00000000-00000000
CPUID 00000004: 04000121-01C0003F-0000003F-00000001
CPUID 00000004: 04000122-01C0003F-0000003F-00000001
CPUID 00000004: 04004143-01C0003F-00000FFF-00000001
CPUID 00000005: 00000040-00000040-00000003-00022220
CPUID 00000006: 00000001-00000002-00000003-00000000
CPUID 00000007: 00000000-00000000-00000000-00000000
CPUID 00000008: 00000400-00000000-00000000-00000000
CPUID 00000009: 00000000-00000000-00000000-00000000
CPUID 0000000A: 07280202-00000000-00000000-00000503
CPUID 0000000C: 00000000-00000000-00000000-00000000
CPUID 0000000D: 00000003-00000240-00000240-00000000
CPUID 80000000: 80000008-00000000-00000000-00000000
CPUID 80000001: 00000000-00000000-00000001-20100000
CPUID 80000002: 746E6550-286D7569-44202952-2D6C6175 [Pentium(R) Dual-]
CPUID 80000003: 65726F43-50432020-20202055-45202020 [Core  CPU	  E]
CPUID 80000004: 30303235-20402020-30352E32-007A4847 [5200  @ 2.50GHz]
CPUID 80000005: 00000000-00000000-00000000-00000000
CPUID 80000006: 00000000-00000000-08006040-00000000
CPUID 80000007: 00000000-00000000-00000000-00000000
CPUID 80000008: 00003024-00000000-00000000-00000000
L1    Data Cache:	 32 KB,  8-way Associative, 64-byte Line
L1  Instr. Cache:	 32 KB,  8-way Associative, 64-byte Line
L2 Unified Cache:   2048 KB,  8-way Associative, 64-byte Line
------[ Logical CPU #1 ]------
allcpu: Package 0 / Core 1 / Thread 0: Valid
CPUID 00000001: 0001067A-01020800-0C00E39D-BFEBFBFF
------[ All CPUs ]------
CPU   0: APICID   0 / Package 0 / Core  0 / Thread 0: Valid
CPU   1: APICID   1 / Package 0 / Core  1 / Thread 0: Valid
------[ MSR Registers ]------
MSR 00000017: 0400-0000-AE84-CC25 [PlatID = 0]
MSR 0000001B: 0000-0000-FEE0-0900
MSR 0000002A: 0000-0000-430C-0000
MSR 0000008B: 0000-0A07-0000-0000
MSR 000000CD: 0000-0000-8000-0802
MSR 000000CE: 0016-4C25-4646-0712
MSR 000000E7: 0000-0F01-339A-9548
MSR 000000E8: 0000-0B2E-954C-9F63
MSR 000000EE: 0000-0000-8679-0300
MSR 0000011E: 0000-0000-BE70-2107
MSR 00000198: 0616-4C25-0600-4C25
MSR 00000199: 0000-0000-0000-4C25
MSR 0000019A: 0000-0000-0000-0008
MSR 0000019B: 0000-0000-0000-0000
MSR 0000019C: 0000-0000-883C-0000
MSR 0000019D: 0000-0000-0000-0616
MSR 000001A0: 0000-0040-6A87-2489
PerformanceFrequency = 3051806
CPU Clock M.Method = 2  (TSC PMT)
PM Timer Address   = 1032  (0408h)
APIC Clock = 250.00 MHz
APIC Clock = 250.23 MHz
APIC Clock = 249.99 MHz
Core temperatures (measured via Intel DTS core diode sensors) are known to be inaccurate on Core 2-family processors, and the inaccuracy gets worse as your CPU cools down. Under 50 Celsius it gets quite inaccurate.
As for the CPU temperature, some Gigabyte motherboards are known to provide unrealistically low temperature readings. Make sure to verify the CPU temperature against Gigabyte EasyTune. If the CPU temperature measured by EasyTune doesn't match AIDA64, then please create an ISA Sensor Dump, and copy-paste the results into this topic.
