Hi.
I have installed trial of AIDA64 V2.20.1800.
On my MB EliteGroup A880GM-M7 it shows wrong:
1) CPU and chipset temperature
2) Votage
CPU temp seems to be right, but Core1/2 (of AMD Phenom X2 250) is about half of CPU temp.
Regarding voltage - it is 1.6 for +3.3V and about 4 for +12V.
I have checked it with two power units, one of them is just from the store.
Should I provide more info with report from AIDA64?
1) Please copy-paste the full content of the Computer / Sensor page of AIDA64 into this topic.
2) Then right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic.
3) Then right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic.
4) If it's possible, please also note down all temperature, fan speed, and voltage values you can see in the BIOS Setup, on the PC Health Status or HW Monitor page. Such data would provide an accurate reference for us.
Using those dump and data we can correct the sensor readings to make sure they provide accurate values on your motherboard.
BIOS temp:
CPU - 40
Fan RPMs: 2500
That's all available data.
Here goes data from AIDA64:
Field Value
Sensor Properties
Sensor Type ITE IT8726F (ISA E80h)
Chassis Intrusion Detected No
Temperatures
CPU 45 °C (113 °F)
CPU #1 / Core #1 16 °C (61 °F)
CPU #1 / Core #2 16 °C (61 °F)
Aux 12 °C (54 °F)
ST1000DL002-9TT153 30 °C (86 °F)
Cooling Fans
CPU 2437 RPM
Voltage Values
CPU Core 1.024 V
+2.5 V 2.144 V
+3.3 V 1.600 V
+12 V 4.800 V
+5 V Standby 5.564 V
VBAT Battery 3.056 V
------[ AIDA64 v2.20.1800 ]------
------[ Microsoft Windows 7 Ultimate 6.1.7601 Service Pack 1 (64-bit) ]------
Motherboard ID : 64-0100-001131-00101111-062310-ATHLON64$1AAAA000_A880GM-M7 RELEASE 06/23/2010
Motherboard Model : ECS A880GM-M7
Motherboard Chipset : AMD 880G, AMD K10
DMI MB Manufacturer : ECS
DMI MB Product : A880GM-M7
DMI MB Version : 1.0
DMI MB Serial :
DMI SYS Manufacturer: ECS
DMI SYS Product : A880GM-M7
DMI SYS Version : 1.0
DMI SYS Serial :
DMI BIOS Version : 080015
ITE 87xx Port = 2Eh
ITE 87xx HWMonitor Port = 0E80h
ITE 87xx Device ID = 8726h
ITE 87xx Version = 03h
Winbond SuperIO Port = 00h
Winbond SuperIO HWMonitor Port = 0000h
Winbond SuperIO Device ID = FFFFh
Fintek SuperIO Port = 00h
Fintek SuperIO Device ID = 0000h
LPC47 SuperIO Device ID = FFFFh
------[ LM78 ISA Sensor Device at 0E80 ]------
0000 11 00 FF 00 00 00 00 00 00 80 16 C9 07 15 FF FF
0010 FF FF FF 71 D7 80 40 40 01 FF FF FF FF FF FF FF
0020 56 86 64 FF 4B 9C 9F CF BF 0C 80 2D C1 F6 F6 F6
0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0040 FF FF FF FF FF FF 5F 74 2D 40 9C 22 FF FF FF FF
0050 FF 05 7F 7F 7F 50 ED 56 90 FA 00 12 60 00 00 00
0060 00 1B 7F 2B 18 03 FF FF 7F 7F 7F 00 00 24 FF FF
0070 7F 7F 7F 00 00 24 FF FF FF FF FF FF FF FF FF FF
0080 00 00 00 00 FF FF FF FF 67 7F FF C0 02 00 99 99
0090 7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF
00A0 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF
00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0029 002A 002B
T: 12 128 45
T: 12 128 45
T: 12 128 45
T: 12 128 45
T: 12 128 45
T: 12 128 45
T: 11 128 45
T: 11 128 45
T: 11 128 45
T: 12 128 45
Reg$20 CPU Core: r = 86, r*0.016 = 1.38
Reg$21 CPU Aux: r = 134, r*0.016 = 2.14
Reg$22 +3.3 V: r = 100, r*0.016 = 1.60
Reg$23 +5 V: r = 255, r*0.016 = 4.08
Reg$24 +12 V: r = 75, r*0.016 = 1.20
Reg$25 -12 V: r = 156, r*0.016 = 2.50
Reg$26 -5 V: r = 159, r*0.016 = 2.54
------[ SB7xx/8xx/9xx PM2 at 0CD0 ]------
0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0020 00 00 00 00 00 00 00 00 FF FF FF 00 00 00 00 00
0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0040 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0070 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0090 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00
00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00E0 51 F0 F8 F1 F0 F4 F0 70 00 EC FD FD C0 F0 F0 F0
00F0 B0 22 F0 00 80 00 00 20 E2 F0 10 FF FF FF FF FF
Reg$59VIN0: r = $0000, r*0.000046 = 0.0000
Reg$5DVIN1: r = $0000, r*0.000046 = 0.0000
Reg$61VIN2: r = $0000, r*0.000046 = 0.0000
Reg$65VIN3: r = $0000, r*0.000046 = 0.0000
Reg$69VIN4: r = $0000, r*0.000046 = 0.0000
Reg$6DVIN5: r = $0000, r*0.000046 = 0.0000
Reg$71VIN6: r = $0000, r*0.000046 = 0.0000
Reg$75VIN7: r = $0000, r*0.000046 = 0.0000
------[ SB7xx/8xx/9xx PM at 0CD6 ]------
0000 00 00 00 00 00 00 00 00 00 00 00 00 00 43 0C 00
0010 2B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0020 00 08 04 08 08 08 10 08 20 08 B0 00 00 FE B8 00
0030 00 00 00 00 00 00 00 04 00 00 00 00 00 00 01 FF
0040 00 00 50 9E 04 00 00 00 00 00 00 00 00 00 00 00
0050 E0 05 82 C0 08 37 00 05 0C 08 00 00 00 00 00 03
0060 20 48 00 05 02 B4 20 06 0C 01 00 00 F0 00 C0 FE
0070 00 00 0B 80 40 C1 FF FF FF FB 00 00 1F 02 00 00
0080 06 21 43 55 5A 02 00 00 10 10 90 01 00 11 00 20
0090 00 FF FF 00 33 06 00 00 00 00 B6 00 00 00 D0 00
00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00B0 04 00 11 00 00 00 00 00 00 00 00 60 00 00 00 00
00C0 00 01 00 E2 55 55 55 00 00 01 00 00 00 00 00 00
00D0 00 00 00 00 40 00 00 E3 00 00 00 00 00 00 00 00
00E0 00 03 3C 00 00 03 3C 00 00 03 3C 00 00 03 3C 00
00F0 00 03 3C 00 00 03 3C 00 00 03 3C 00 00 03 3C 00
_TZ_.THM0._TMP :
_TZ_.THM1._TMP :
_TZ_.THR0._TMP :
_TZ_.THR1._TMP :
_TZ_.TZ00._TMP :
_TZ_.TZ01._TMP :
_TZ_.RTMP :
_TZ_.RFAN :
_TZ_.RFAN(0) :
_TZ_.RFAN(1) :
_SB_.ATKD._HID :
_SB_.ATKD.TMPR :
_SB_.PCI0.LPC0.EC0_.CCTV :
_SB_.PCI0.LPC0.EC0_.LRPM :
_SB_.PCI0.LPC0.EC0_.HRPM :
_SB_.PCI0.SBRG.EC0_.ECPU :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0 :
_SB_.PCI0.SBRG.EC0_.TAH1 :
_SB_.PCI0.SBRG.EC0_.ST00 :
_SB_.PCI0.SBRG.EC0_.SC01 :
_SB_.PCI0.SBRG.EC0_.SC02 :
_SB_.PCI0.SBRG.EC0_.SC03 :
_SB_.PCI0.SBRG.EC0_.SC04 :
_SB_.PCI0.SBRG.EC0_.SC05 :
_SB_.PCI0.SBRG.EC0_.SC06 :
_SB_.PCI0.PIB_.EC0_.TCRT :
_SB_.PCI0.SBRG.EC0_.CTPM :
_SB_.PCI0.SBRG.EC__.CPUT :
_SB_.PCI0.SBRG.EC__.SYST :
_SB_.PCI0.LPC_.EC0_.CTMP :
_SB_.PCI0.LPCB.EC0_.CTMP :
_SB_.PCI0.LPC_.EC0_.TMP1 :
_SB_.PCI0.LPC_.EC0_.TMP2 :
_SB_.PCI0.LPC_.EC0_.TMPI :
_SB_.PCI0.LPC_.EC0_.TMPV :
_SB_.PCI0.LPCB.EC0_.A1TP :
_SB_.PCI0.LPCB.EC0_.A2TP :
_SB_.PCI0.LPCB.EC0_.FAN0 :
_SB_.PCI0.LPCB.EC__.TS1R :
_SB_.PCI0.LPCB.EC__.TS2R :
_SB_.PCI0.LPCB.EC__.TS3R :
_SB_.PCI0.LPCB.EC__.F1FL :
_SB_.PCI0.LPCB.EC__.F1FH :
_SB_.PCI0.LPCB.EC__.F2FL :
_SB_.PCI0.LPCB.EC__.F2FH :
_SB_.PCI0.LPC_.H8EC.RTMP :
_SB_.PCI0.LPC_.H8EC.LTMP :
_SB_.PCI0.LPC_.H8EC.MTMP :
_SB_.PCI0.LPC_.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.CTMP :
_SB_.PCI0.LPCB.H8EC.DTMP :
_SB_.PCI0.LPCB.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.ITMP :
_SB_.PCI0.LPCB.H8EC.MTMP :
_SB_.PCI0.LPCB.H8EC.STMP :
_SB_.PCI0.LPCB.H8EC.PFAN :
DMI MB Serial :
DMI SYS Serial :
------[ SMBus #0 ]------
SMBus Type : Intel / VIA / ServerWorks / SMSC / ATI
SMBus Port : 0B00
Can Have SPD: Yes
Scan Type : Full
------[ SMBus Device B00-D30 ]------
0000 03 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF ................
0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0040 FF 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF ................
0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0080 FF 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF ................
0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00C0 FF 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF ................
00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0000 0003 0000 0000 0000 FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0040 00FF 0000 0000 0000 FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0080 00FF 0000 0000 0000 FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00C0 00FF 0000 0000 0000 FF00 FF00 FF00 FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
------[ SMBus Device B00-D38 ]------
0000 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
0010 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
0020 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
0030 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
0040 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
0050 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
0060 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
0070 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
0080 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
0090 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
00A0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
00B0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
00C0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
00D0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
00E0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
00F0 01 00 00 00 00 50 AC 14 81 B4 08 10 7C 04 00 00 .....P......|...
0000 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
0010 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
0020 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
0030 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
0040 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
0050 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
0060 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
0070 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
0080 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
0090 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
00A0 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
00B0 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
00C0 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
00D0 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
00E0 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
00F0 0001 0000 0000 0000 5000 AC50 14AC 8114 B481 08B4 1008 7C10 047C 0004 0000 0100
------[ SMBus Device B00-D50 ]------
0000 92 10 0B 02 03 19 00 01 03 52 01 08 0C 00 7E 00 .........R....~.
0010 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 82 05 ixi0i. ...<<....
0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0030 00 00 00 00 00 00 00 00 00 00 00 00 0F 01 00 00 ................
0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8B B7 ................
0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0090 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
Well, I have tried it.
CPU is about 40.
Core 1/2 is about 15.
Regarding voltage - it is gone!
There is VBAT only, 3V, as before.
Does this mean that my MB can't report voltage at all?
Should I collect debug info one more time?
Thank you for the feedback. AFAIK your motherboard cannot measure the regular voltages (+5V, +12V), so that's why we've removed those bogus readings. You can check in the BIOS Setup whether your motherboard is capable of measuring a specific voltage rail or not.
OK, thanks.
I was suspecting that MB and BIOS are very limited as MB is of very low price.
But what about CPU cores? Shoild it be 1/2 of total CPU for each core?
Here goes new debug info:
Field Value
Sensor Properties
Motherboard Name ECS A880GM-M7
Temperatures
CPU 47 °C (117 °F)
CPU #1 / Core #1 14 °C (57 °F)
CPU #1 / Core #2 14 °C (57 °F)
ST1000DL002-9TT153 [ TRIAL VERSION ]
Cooling Fans
CPU 2437 RPM
Voltage Values
CPU Core 1.376 V
------[ AIDA64 v2.20.1822 Beta ]------
DMI MB Serial :
DMI SYS Serial :
SMBus Port : 0B00
Can Have SPD: Yes
Scan Type : Full
DMI MB Serial :
DMI SYS Serial :
ITE 87xx Port = 2Eh
0000 11 00 FF 00 00 00 00 00 00 80 16 C9 07 16 FF FF
0010 FF FF FF 71 D7 80 40 40 01 FF FF FF FF FF 07 16
0020 40 86 64 FF 4B 9C A0 CF BF 0D 80 30 C0 C6 BF BF
0029 002A 002B
T: 13 128 48
T: 13 128 48
T: 13 128 48
T: 12 128 48
T: 12 128 48
T: 11 128 48
T: 11 128 47
T: 11 128 47
T: 10 128 47
T: 10 128 47
Reg$20 CPU Core: r = 64, r*0.016 = 1.02
Reg$26 -5 V: r = 160, r*0.016 = 2.56
_TZ_.THM0._TMP :
_TZ_.THM1._TMP :
_TZ_.THR0._TMP :
_TZ_.THR1._TMP :
_TZ_.TZ00._TMP :
_TZ_.TZ01._TMP :
_TZ_.RTMP :
_TZ_.RFAN :
_TZ_.RFAN(0) :
_TZ_.RFAN(1) :
_SB_.ATKD._HID :
_SB_.ATKD.TMPR :
I'm afraid certain AMD processor models, especially the latest FX Series are infamous for providing very low core diode temperature readings, usually way below ambient temperature at idle. So you may want to ignore the core diode temperature readings.
