om3nz Posted February 8, 2012 Posted February 8, 2012 Aida64 v2.20.1800 shows 10.472 V value on 12v rail with MSI GF615M-P33 v2 motherboard. I've tested it with 2 different PSU's and values are simmilar, 10.4-10.5 volts. One PSU is brand new. In BIOS values are ok. Here is report: --------[ AIDA64 Extreme Edition ]-------------------------------------------------------------------------------------- Version AIDA64 v2.20.1800 Benchmark Module 2.7.398-x64 Homepage http://www.aida64.com/ Report Type Quick Report Computer xxx Generator xxx Operating System Microsoft Windows 7 Professional 6.1.7601 (Win7 RTM) Date 2012-02-08 Time 19:46 --------[ Sensor ]------------------------------------------------------------------------------------------------------ Sensor Properties: Sensor Type Fintek F71868A/869A/870A (ISA A00h) Temperatures: CPU 30 °C (86 °F) CPU #1 / Core #1 22 °C (72 °F) CPU #1 / Core #2 22 °C (72 °F) MCP 58 °C (136 °F) Aux 31 °C (88 °F) SAMSUNG SP1223N 34 °C (93 °F) Cooling Fans: CPU 3546 RPM Voltage Values: CPU Core 1.336 V +3.3 V 3.376 V +12 V 10.472 V +3.3 V Standby 3.360 V VBAT Battery 3.248 V Debug Info F 01A7 0FFF 0FFF Debug Info T 30 31 128 Debug Info V D3 A7 00 00 00 77 8C D2 CB Debug Info I FF FF FF FF FF (1007) Quote
Fiery Posted February 8, 2012 Posted February 8, 2012 1) Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. 2) Then right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> SMBus Dump (Full). Copy-paste the full results into this topic. 3) If it's possible, please let us know what temperature, fan speed, and voltage values you can see in the BIOS Setup, under the PC Health Status or HW Monitor page. Such data would provide an accurate reference for us. Using those dumps and data we can correct the sensor readings to make sure they provide accurate values on your motherboard. Thanks, Fiery Quote
om3nz Posted February 8, 2012 Author Posted February 8, 2012 ISA sensor dump: ------[ AIDA64 v2.20.1800 ]------ ------[ Microsoft Windows 7 Professional 6.1.7601 Service Pack 1 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 64-0100-000001-00101111-021411-ATHLON64$A7597200_A7597NMS V10.1 021411 Motherboard Model : MSI GF615M-P33 V2 (MS-7597) Motherboard Chipset : nVIDIA nForce 7025-630a, AMD K10 DMI MB Manufacturer : MSI DMI MB Product : GF615M-P33 V2(MS-7597) DMI MB Version : 2.0 DMI MB Serial : To be filled by O.E.M. DMI SYS Manufacturer: MSI DMI SYS Product : MS-7597 DMI SYS Version : 2.0 DMI SYS Serial : To Be Filled By O.E.M. DMI BIOS Version : V10.1 ITE 87xx Port = 00h ITE 87xx HWMonitor Port = 0000h ITE 87xx Device ID = 0000h ITE 87xx Version = 00h Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port = 0000h Winbond SuperIO Device ID = 1007h Fintek SuperIO Port = 4Eh Fintek SuperIO HWMonitor Port = 0A00h Fintek SuperIO Device ID = 1007h LPC47 SuperIO HWMonitor Port = 0000h LPC47 SuperIO Device ID = FFFFh ------[ LM78 ISA Sensor Device at 0A00 ]------ 0000 FF 03 00 00 01 FF FF 00 4C 00 40 00 55 00 FF 20 0010 00 00 06 FF FF FF FF FF FF FF FF FF FF FF FF FF 0020 D3 A7 00 00 00 77 8D D4 CB FF FF FF FF FF 89 80 0030 7A D7 FF FF FF FF C9 C8 75 85 FF FF FF FF FF 00 0040 44 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0060 00 00 00 00 00 FF 02 00 00 00 FF 0E 40 24 FF 08 0070 FF FF 21 FF 21 FF 80 FF FF FF 00 00 00 00 00 00 0080 FF FF 64 55 64 55 55 46 FF FF FF FF FF FF AA FF 0090 00 06 06 00 2A FF 17 FF 42 04 02 2A 55 05 66 0A 00A0 01 A7 00 FF 03 FF 3C 32 28 1E FF E5 CE B7 A0 1D 00B0 0F FF 00 89 03 FF 3C 32 28 1E FF D9 B2 99 80 1E 00C0 0F FF 00 80 03 FF 3C 32 28 1E FF D9 B2 99 80 1F 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 00 00 00 00 00 00 00 00 00 FF FF FF 00 00 01 00 00F0 00 00 00 00 00 00 37 FF 00 00 FF 00 80 00 FF FF 0070 0072 0074 0076 0078 0079 007A 007B 007C 007D 007E 007F T: 255 33 33 128 255 255 0 0 0 0 0 0 T: 255 33 33 128 255 255 0 0 0 0 0 0 T: 255 33 33 128 255 255 0 0 0 0 0 0 T: 255 33 33 128 255 255 0 0 0 0 0 0 T: 255 33 33 128 255 255 0 0 0 0 0 0 T: 255 33 33 128 255 255 0 0 0 0 0 0 T: 255 32 33 128 255 255 0 0 0 0 0 0 T: 255 32 33 128 255 255 0 0 0 0 0 0 T: 255 32 33 128 255 255 0 0 0 0 0 0 T: 255 33 33 128 255 255 0 0 0 0 0 0 Reg$20 CPU Core: r = 211, r*0.016 = 3.38 Reg$21 CPU Aux: r = 167, r*0.016 = 2.67 Reg$22 +3.3 V: r = 0, r*0.016 = 0.00 Reg$23 +5 V: r = 0, r*0.016 = 0.00 Reg$24 +12 V: r = 0, r*0.016 = 0.00 Reg$25 -12 V: r = 119, r*0.016 = 1.90 Reg$26 -5 V: r = 141, r*0.016 = 2.26 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : ------[ nVIDIA THERM Fan ]------ Initial : 00 (0 ms) Step 5 : 00 (0 ms) Step 5 : 00 (16 ms) Step 5 : 00 (16 ms) Step 5 : 00 (31 ms) Step 5 : 00 (31 ms) Step 5 : 00 (47 ms) Step 5 : 00 (47 ms) Step 5 : 00 (62 ms) Step 5 : 00 (62 ms) Step 5 : 00 (62 ms) Step 10 : 00 (78 ms) Step 10 : 00 (94 ms) Step 10 : 00 (109 ms) Step 10 : 00 (125 ms) Step 10 : 00 (140 ms) Step 10 : 00 (140 ms) Step 10 : 00 (156 ms) Step 10 : 00 (172 ms) Step 10 : 00 (187 ms) Step 10 : 00 (187 ms) Step 50 : 00 (250 ms) Step 50 : 00 (312 ms) Step 50 : 00 (359 ms) Step 50 : 00 (421 ms) Step 50 : 00 (484 ms) Step 50 : 00 (530 ms) Step 50 : 00 (593 ms) Step 50 : 00 (640 ms) Step 50 : 00 (686 ms) Step 50 : 00 (749 ms) Step 100: 00 (842 ms) Step 100: 00 (952 ms) Step 100: 00 (1045 ms) Step 100: 00 (1154 ms) Step 100: 00 (1248 ms) Step 100: 00 (1357 ms) Step 100: 00 (1466 ms) Step 100: 00 (1576 ms) Step 100: 00 (1685 ms) Step 100: 00 (1794 ms) Step 200: 00 (2012 ms) Step 200: 00 (2215 ms) Step 200: 00 (2418 ms) Step 200: 00 (2636 ms) Step 200: 00 (2839 ms) Step 200: 00 (3042 ms) Step 200: 00 (3260 ms) Step 200: 00 (3463 ms) Step 200: 00 (3666 ms) Step 200: 00 (3884 ms) SMBus Dump (Full): ------[ AIDA64 v2.20.1800 ]------ ------[ Microsoft Windows 7 Professional 6.1.7601 Service Pack 1 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 64-0100-000001-00101111-021411-ATHLON64$A7597200_A7597NMS V10.1 021411 Motherboard Model : MSI GF615M-P33 V2 (MS-7597) Motherboard Chipset : nVIDIA nForce 7025-630a, AMD K10 DMI MB Manufacturer : MSI DMI MB Product : GF615M-P33 V2(MS-7597) DMI MB Version : 2.0 DMI MB Serial : To be filled by O.E.M. DMI SYS Manufacturer: MSI DMI SYS Product : MS-7597 DMI SYS Version : 2.0 DMI SYS Serial : To Be Filled By O.E.M. DMI BIOS Version : V10.1 ------[ GPIO @ isa 44C0 ]------ 0000 48 48 44 65 48 48 48 48 48 48 48 68 48 48 48 00 0010 48 00 48 48 48 48 48 00 28 28 28 28 28 48 48 48 0020 48 48 48 48 68 68 68 68 68 00 68 48 48 00 00 48 0030 48 48 48 68 68 48 48 48 48 48 48 48 48 48 48 00 ------[ 2 SMBuses detected ]------ ------[ SMBus #0 ]------ SMBus Type : nForce2/3/4/5/6 - Primary SMBus Port : 4D00 Can Have SPD: Yes Scan Type : Full ------[ SMBus Device B00-D50 ]------ 0000 92 10 0B 02 03 19 00 01 03 52 01 08 0C 00 3C 00 .........R....<. 0010 69 78 69 30 69 11 20 89 00 05 3C 3C 00 F0 83 05 ixi0i. ...<<.... 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 0F 01 00 00 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 01 4F 54 11 35 00 09 1D F6 57 39 ......OT.5....W9 0080 4A 4D 31 33 33 33 4B 4C 4E 2D 32 47 20 20 20 20 JM1333KLN-2G 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 33 4D 50 33 31 30 2D 47 50 34 35 00 00 00 00 00 3MP310-GP45..... 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 AB ................ ------[ SMBus Device B00-D51 ]------ 0000 92 10 0B 02 02 11 00 09 03 52 01 08 0C 00 3C 00 .........R....<. 0010 69 78 69 30 69 11 20 89 70 03 3C 3C 00 F0 83 85 ixi0i. .p.<<.... 0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0030 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 ................ 0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 0070 00 00 00 00 00 01 7A 00 11 35 02 01 13 55 7C ED ......z..5...U|. 0080 37 38 2E 41 31 47 43 36 2E 39 48 31 30 43 20 20 78.A1GC6.9H10C 0090 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 .............. 00A0 00 00 00 00 00 00 30 00 00 30 30 30 00 00 37 47 ......0..000..7G 00B0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00D0 00 00 00 00 00 00 00 00 00 00 03 DF 00 00 00 00 ................ 00E0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................ 00F0 00 00 00 00 00 88 00 00 02 00 00 00 00 00 1E 0C ................ ------[ SMBus #1 ]------ SMBus Type : nForce2/3/4/5/6 - Secondary SMBus Port : 4E00 Can Have SPD: No Scan Type : Full ------[ SMBus Device B01-D28 ]------ 0000 07 0A 81 01 01 80 01 FF FF FF FF FF FF FF FF FF ................ 0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0040 FF 0A 81 01 01 80 01 FF FF FF FF FF FF FF FF FF ................ 0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 0080 FF 0A 81 01 01 80 01 FF FF FF FF FF FF FF FF FF ................ 0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00C0 FF 0A 81 01 01 80 01 FF FF FF FF FF FF FF FF FF ................ 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................ ------[ SMBus Device B01-D28 ]------ 0000 0A07 810A 0181 FF01 FF01 FF80 FF01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0040 0AFF 810A 0181 FF01 FF01 FF80 FF01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0080 0AFF 810A 0181 FF01 FF01 FF80 FF01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00C0 0AFF 810A 0181 FF01 FF01 FF80 FF01 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF ------[ Chips Found ]------ B00-D51: SPD BIOS Hardware monitor: CPU Temperature: 38C/132F System Temperature: 32C/121F CPU FAN Speed: 3512 RPM CPU Vcore 1.336V 3.3V: 3.376 V 5V: 5.003 V 12V: 12.408 V Quote
Fiery Posted February 10, 2012 Posted February 10, 2012 Thank you for the data. Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1817wmksq1gtjrzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how it works. Thanks, Fiery Quote
om3nz Posted February 10, 2012 Author Posted February 10, 2012 The download link to this version isn't working. Quote
Fiery Posted February 10, 2012 Posted February 10, 2012 The download link to this version isn't working. Fixed it, please try it now. Quote
om3nz Posted February 10, 2012 Author Posted February 10, 2012 Everything is working now. Thanks for the fix. Quote
