I have some of the new Lian Li Unifans and I was hoping to get support for fan speed monitoring. Has anyone been able to display monitoring for the hub that is supplied.
It's not supported by AIDA64 yet.  In order to let us have a better understanding on the USB layer of it, please right-click on the bottom status bar of AIDA64 main window --> System Debug --> USB Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first.
  • 2 months later...
Here is my USB Dump. I'm having the same issue.  I have the UNI Fan controllers pwm signal cable plugged into my motherboard but the fan does not show up in aida 64m to display the rpm.
------[ Versions ]------
Program Version : AIDA64 Extreme v6.32.5600
BenchDLL Version: 4.5.841.8-x64
Windows Version : Microsoft Windows 10 Pro 10.0.19042.746 (64-bit)
GetProductInfo  : 0x00000030
Motherboard ID      : <DMI>
Motherboard Model   : Asus ROG Crosshair VIII Hero
Motherboard Chipset : AMD Bixby X570, AMD K17.7 FCH, AMD K17.7 IMC
DMI MB Product      : ROG CROSSHAIR VIII HERO
DMI MB Version      : Rev X.0x
DMI MB Serial       : 200771769100642
DMI SYS Manufacturer: ASUS
DMI SYS Product     : System Product Name
DMI SYS Version     : System Version
DMI SYS Serial      : System Serial Number
DMI BIOS Version    : 3003
------[ USB Devices ]------
AMD USB 3.10 eXtensible Host Controller - 1.10 (Microsoft)
- [Port 1] USB Composite Device (Schiit Hel)
- - USB Input Device
- - - HID-compliant consumer control device
- - Schiit Hel
- - - Microphone (3- Schiit Hel)
- - - Speakers (3- Schiit Hel)
- [Port 2] < No Device Connected >
- [Port 3] < No Device Connected >
- [Port 4] Generic USB Hub
- - [Port 1] USB Composite Device (Razer DeathAdder V2)
- - - Razer DeathAdder V2
- - - - Razer DeathAdder V2
- - - - - Razer Control Device
- - - - HID-compliant consumer control device
- - - - - HID-compliant consumer control device
- - - - HID-compliant device
- - - - HID-compliant system controller
- - - USB Input Device
- - - - HID Keyboard Device
- - [Port 2] USB Composite Device (Corsair Gaming K95 RGB PLATINUM Keyboard)
- - - - HID-compliant vendor-defined device
- - - - HID-compliant mouse
- - [Port 3] USB Input Device
- [Port 5] < No Device Connected >
- [Port 6] < No Device Connected >
- [Port 7] < No Device Connected >
- [Port 8] Generic SuperSpeed USB Hub
- - [Port 1] < No Device Connected >
- - [Port 2] < No Device Connected >
- - [Port 3] < No Device Connected >
- [Port 4] < No Device Connected >
- [Port 5] Generic USB Hub (USB2.0 Hub)
- - [Port 1] USB Composite Device (LianLi)
- - - LianLi
- - [Port 3] USB Composite Device (AURA LED Controller)
- - - AURA LED Controller
- - [Port 4] < No Device Connected >
- [Port 8] < No Device Connected >
- [Port 9] < No Device Connected >
- [Port 10] < No Device Connected >
- [Port 2] Generic USB Hub (ASM107x)
- - [Port 3] USB Composite Device (Sound BlasterX G6)
- - - Sound BlasterX G6
- - - - External Mic (Sound BlasterX G6)
- - - - Line In (Sound BlasterX G6)
- - - - SPDIF In (Sound BlasterX G6)
- - - - Speakers (Sound BlasterX G6)
- - - - What U Hear (Sound BlasterX G6)
------[ USB Composite Device]------
Device Description   : USB Composite Device
Device ID            : 30BE-0101
Device Class         : EF / 02 (Interface Association Descriptor)
Device Protocol      : 01
Revision             : 0102h
Manufacturer         : Schiit Audio
Product              : Schiit Hel
Supported USB Version: 2.00
Current Speed        : High  (USB 2.0)
------[ Generic USB Hub]------
Device Description   : Generic USB Hub
Device ID            : 0451-8142
Device Class         : 09 / 00 (Hi-Speed Hub with multiple TTs)
Device Protocol      : 02
Revision             : 0100h
Serial Number        : A0030861E840
Supported USB Version: 2.10
Device ID            : 1532-0084
Device Class         : 03 / 01 (Human Interface Device)
Revision             : 0200h
Manufacturer         : Razer
Product              : Razer DeathAdder V2
Current Speed        : Full  (USB 1.1)
Device ID            : 1B1C-1B2D
Revision             : 0107h
Manufacturer         : Corsair
Product              : Corsair Gaming K95 RGB PLATINUM Keyboard
Serial Number        : 0501F02DAEFD8007582C8552F5001945
------[ USB Input Device]------
Device Description   : USB Input Device
Device ID            : 043E-9A57
Revision             : 0120h
------[ Generic SuperSpeed USB Hub]------
Device Description   : Generic SuperSpeed USB Hub
Device ID            : 0451-8140
Device Class         : 09 / 00 (Hub)
Device Protocol      : 03
Revision             : 0100h
Supported USB Version: 3.00
Current Speed        : Super  (USB 3.0)
Device ID            : 05E3-0610
Revision             : 3298h
Product              : USB2.0 Hub
Device ID            : 0CF2-7750
Device Class         : FF / FF
Device Protocol      : FF
Revision             : 0100h
Manufacturer         : ENE
Product              : LianLi
Serial Number        : 6243168001
Device ID            : 0B05-18F3
Revision             : 0100h
Manufacturer         : AsusTek Computer Inc.
Product              : AURA LED Controller
Serial Number        : 9876543210
Device ID            : 174C-2074
Revision             : 0001h
Manufacturer         : ASUS TEK.
Product              : ASM107x
Device ID            : 041E-3256
Revision             : 2000h
Manufacturer         : Creative Technology Ltd
Product              : Sound BlasterX G6
Serial Number        : 3300664767X
Device ID            : 174C-3074
Revision             : 0001h
------[ DevClass / USB Hubs ]------
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_0451&pid_8142#msft20a0030861e840#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_0451&PID_8142\MSFT20A0030861E840</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000004</ADDR><REV>0100</REV>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_174c&pid_2074#8&1b878445&0&2#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_174C&PID_2074\8&1B878445&0&2</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0001</REV>
<DESC>Generic SuperSpeed USB Hub</DESC><DEVPATH>\\?\usb#vid_0451&pid_8140#6&c1a2e2f&0&8#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_0451&PID_8140\6&C1A2E2F&0&8</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000008</ADDR><REV>0100</REV>
<DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#7&30304c2c&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ROOT_HUB30\7&30304C2C&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>Generic SuperSpeed USB Hub</DESC><DEVPATH>\\?\usb#vid_174c&pid_3074#8&1b878445&0&8#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_174C&PID_3074\8&1B878445&0&8</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000008</ADDR><REV>0001</REV>
<DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0610#8&384b90af&0&5#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\VID_05E3&PID_0610\8&384B90AF&0&5</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000005</ADDR><REV>3298</REV>
<DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#5&2c35141&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ROOT_HUB30\5&2C35141&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
<DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#7&14c6e8ad&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><INSTANCE>USB\ROOT_HUB30\7&14C6E8AD&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR>
------[ DevClass / USB Devices ]------
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_041e&pid_3256#3300664767x#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_041E&PID_3256\3300664767X</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>2000</REV>
<DESC>USB Input Device</DESC><DEVPATH>\\?\usb#vid_043e&pid_9a57#abc123456789#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_043E&PID_9A57\ABC123456789</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0120</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_30be&pid_0101#6&c1a2e2f&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_30BE&PID_0101\6&C1A2E2F&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0102</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_0cf2&pid_7750#6243168001#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_0CF2&PID_7750\6243168001</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_1532&pid_0084#7&254ec284&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_1532&PID_0084\7&254EC284&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_0b05&pid_18f3#9876543210#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_0B05&PID_18F3\9876543210</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000003</ADDR><REV>0100</REV>
<DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_1b1c&pid_1b2d#0501f02daefd8007582c8552f5001945#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><INSTANCE>USB\VID_1B1C&PID_1B2D\0501F02DAEFD8007582C8552F5001945</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0107</REV>
------[ DevClass / Human Interface Devices ]------
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_1b1c&pid_1b2d&mi_02#9&85f90cf&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1B1C&PID_1B2D&MI_02\9&85F90CF&0&0000</INSTANCE><BUSNUM>0000000C</BUSNUM><ADDR>00000001</ADDR><REV>0107</REV>
<DESC>Razer DeathAdder V2</DESC><DEVPATH>\\?\hid#vid_1532&pid_0084&mi_01&col01#9&18530977&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1532&PID_0084&MI_01&COL01\9&18530977&0&0000</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_0b05&pid_18f3&mi_02#b&395d80fb&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0B05&PID_18F3&MI_02\B&395D80FB&0&0000</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1b1c&pid_1b2d&mi_01&col02#9&20231d14&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1B1C&PID_1B2D&MI_01&COL02\9&20231D14&0&0001</INSTANCE><BUSNUM>0000000B</BUSNUM><ADDR>00000002</ADDR><REV>0107</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_1b1c&pid_1b2d&mi_01&col03#9&20231d14&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1B1C&PID_1B2D&MI_01&COL03\9&20231D14&0&0002</INSTANCE><BUSNUM>0000000B</BUSNUM><ADDR>00000003</ADDR><REV>0107</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_1b1c&pid_1b2d&mi_01&col04#9&20231d14&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1B1C&PID_1B2D&MI_01&COL04\9&20231D14&0&0003</INSTANCE><BUSNUM>0000000B</BUSNUM><ADDR>00000004</ADDR><REV>0107</REV>
<DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#vid_1b1c&pid_1b2d&mi_01&col05#9&20231d14&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1B1C&PID_1B2D&MI_01&COL05\9&20231D14&0&0004</INSTANCE><BUSNUM>0000000B</BUSNUM><ADDR>00000005</ADDR><REV>0107</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_043e&pid_9a57#8&14899ef0&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_043E&PID_9A57\8&14899EF0&0&0000</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000001</ADDR><REV>0120</REV>
<DESC>Razer DeathAdder V2</DESC><DEVPATH>\\?\hid#vid_1532&pid_0084&mi_00#9&8f7d32&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0084&MI_00\9&8F7D32&0&0000</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0084&mi_03#9&c3f57fa&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0084&MI_03\9&C3F57FA&0&0000</INSTANCE><BUSNUM>00000009</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0084&mi_00&col03#a&de649fc&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0084&MI_00&COL03\A&DE649FC&0&0000</INSTANCE><BUSNUM>0000000D</BUSNUM><ADDR>00000001</ADDR>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0084&mi_01&col02#9&18530977&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0084&MI_01&COL02\9&18530977&0&0001</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000002</ADDR><REV>0200</REV>
<DESC>HID-compliant system controller</DESC><DEVPATH>\\?\hid#vid_1532&pid_0084&mi_01&col03#9&18530977&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0084&MI_01&COL03\9&18530977&0&0002</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000003</ADDR><REV>0200</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0084&mi_01&col04#9&18530977&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0084&MI_01&COL04\9&18530977&0&0003</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000004</ADDR><REV>0200</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_041e&pid_3256&mi_04#b&a970222&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_041E&PID_3256&MI_04\B&A970222&0&0000</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000001</ADDR><REV>2000</REV>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1b1c&pid_1b2d&mi_00#9&3b420ae&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1B1C&PID_1B2D&MI_00\9&3B420AE&0&0000</INSTANCE><BUSNUM>0000000A</BUSNUM><ADDR>00000001</ADDR><REV>0107</REV>
<DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0084&mi_01&col05#9&18530977&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_1532&PID_0084&MI_01&COL05\9&18530977&0&0004</INSTANCE><BUSNUM>00000007</BUSNUM><ADDR>00000005</ADDR><REV>0200</REV>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1b1c&pid_1b2d&mi_01&col01#9&20231d14&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1B1C&PID_1B2D&MI_01&COL01\9&20231D14&0&0000</INSTANCE><BUSNUM>0000000B</BUSNUM><ADDR>00000001</ADDR><REV>0107</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_041e&pid_3256&mi_03#b&3301afeb&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_041E&PID_3256&MI_03\B&3301AFEB&0&0000</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000001</ADDR><REV>2000</REV>
<DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0084&mi_02#9&301695bc&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><INSTANCE>HID\VID_1532&PID_0084&MI_02\9&301695BC&0&0000</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV>
<DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_30be&pid_0101&mi_03#8&248f477d&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_30BE&PID_0101&MI_03\8&248F477D&0&0000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0102</REV>
<DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_0cf2&pid_7750&mi_01#b&10adb3fc&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><INSTANCE>HID\VID_0CF2&PID_7750&MI_01\B&10ADB3FC&0&0000</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV>
------[ HID Device Info / HID-compliant vendor-defined device ]------
Revision                  : 0107h
Device Instance           : HID\VID_1B1C&PID_1B2D&MI_02\9&85F90CF&0&0000
Usage                     : 0004h
Usage Page                : FFC2h
Input Report Byte Length  : 0
Output Report Byte Length : 65
Feature Report Byte Length: 65
Revision                  : 0100h
Device Instance           : HID\VID_0B05&PID_18F3&MI_02\B&395D80FB&0&0000
Usage                     : 00A1h
Usage Page                : FF72h
Input Report Byte Length  : 65
Feature Report Byte Length: 0
------[ HID Device Info / HID-compliant consumer control device ]------
Revision                  : 0107h
Device Instance           : HID\VID_1B1C&PID_1B2D&MI_01&COL02\9&20231D14&0&0001
Usage                     : 0001h
Usage Page                : 000Ch
Input Report Byte Length  : 5
Output Report Byte Length : 0
Revision                  : 0107h
Device Instance           : HID\VID_1B1C&PID_1B2D&MI_01&COL03\9&20231D14&0&0002
Usage                     : 0002h
Usage Page                : FFC0h
Input Report Byte Length  : 64
Revision                  : 0107h
Device Instance           : HID\VID_1B1C&PID_1B2D&MI_01&COL04\9&20231D14&0&0003
Usage                     : 0003h
Usage Page                : FFC2h
Manufacturer              : LG Electronics Inc.
Product                   : LG UltraGear Monitor
Serial Number             : ABC123456789
Revision                  : 0120h
Device Instance           : HID\VID_043E&PID_9A57\8&14899EF0&0&0000
Usage                     : 0001h
Usage Page                : FF00h
Feature Report Byte Length: 9
Revision                  : 0101h
Device Instance           : HID\VID_1532&PID_0084&MI_00&COL03\A&DE649FC&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
Input Report Byte Length  : 3
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_0084&MI_01&COL02\9&18530977&0&0001
Usage                     : 0001h
Usage Page                : 000Ch
Input Report Byte Length  : 16
------[ HID Device Info / HID-compliant system controller ]------
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_0084&MI_01&COL03\9&18530977&0&0002
Usage                     : 0080h
Usage Page                : 0001h
------[ HID Device Info / HID-compliant device ]------
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_0084&MI_01&COL04\9&18530977&0&0003
Usage                     : 0000h
Usage Page                : 0001h
Revision                  : 2000h
Device Instance           : HID\VID_041E&PID_3256&MI_04\B&A970222&0&0000
Usage                     : 0001h
Usage Page                : FF00h
Revision                  : 0200h
Device Instance           : HID\VID_1532&PID_0084&MI_01&COL05\9&18530977&0&0004
Usage                     : 0000h
Usage Page                : 0001h
Revision                  : 2000h
Device Instance           : HID\VID_041E&PID_3256&MI_03\B&3301AFEB&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
Input Report Byte Length  : 17
Revision                  : 0102h
Device Instance           : HID\VID_30BE&PID_0101&MI_03\8&248F477D&0&0000
Usage                     : 0001h
Usage Page                : 000Ch
Output Report Byte Length : 17
Manufacturer              : ENE
Product                   : LianLi
Revision                  : 0100h
Device Instance           : HID\VID_0CF2&PID_7750&MI_01\B&10ADB3FC&0&0000
Usage                     : 00A1h
Usage Page                : FF72h
------[ DevClass / COM Ports ]------
< No COM Port Found >
------[ DevClass / LPT Ports ]------
< No LPT Port Found >
------[ DevClass / Modems ]------
< No Modem Found >
------[ DevClass / SideShow Devices ]------
< No SideShow Device Found >
------[ DevClass / GX3 Devices ]------
< No GX3 Device Found >
------[ DevClass / USBXpress Devices ]------
< No USBXpress Device Found >
------[ DevClass / WinUSB Devices ]------
< No WinUSB Device Found >
------[ LibUsb0 Devices ]------
< No LibUsb0 Device Found >
------[ CH341 Devices ]------
< No CH341 Device Found >
------[ FTD2xx Devices ]------
< No FTD2xx Device Found >
------[ LibMPSSE Devices ]------
< No LibMPSSE Device Found >
------[ SiUSBXp Devices ]------
SiUSBXp.dll Path =
< No SiUSBXp Device Found >
------[ T-Balancer Devices ]------
< No T-Balancer Device Found >
------[ Koolance TMS-200 Devices ]------
< No T-Koolance TMS-200 Device Found >
------[ GRID+ V3 Devices ]------
< No GRID+ V3 Device Found >
------[ Kraken X-2/X-3 Devices ]------
< No Kraken X-2/X-3 Device Found >
  • 10 months later...
use a fan splitter, connect the main end to your motherboard and connect one set of your uni fans to one end and lian li hub pwm to the other, this way aida64 can read the rpm and when you make changes to fans speed using your motherboard software or bios, it will implement on the fans connected to the uni fans hub aswell
