canr6 Posted November 9, 2020 Posted November 9, 2020 hello AIDA64 not displaying no temperature although present in samsung nvme 980 pro. Any chance this could be fixed please? Quote
Fiery Posted November 9, 2020 Posted November 9, 2020 13 minutes ago, canr6 said: hello AIDA64 not displaying no temperature although present in samsung nvme 980 pro. Any chance this could be fixed please? Do you have a NVMe RAID array that this SSD is a member of? Quote
canr6 Posted November 10, 2020 Author Posted November 10, 2020 14 hours ago, Fiery said: Do you have a NVMe RAID array that this SSD is a member of? No 1 x 980 pro 500 gb 1x 1 tb 970 evo m2 no raid Quote
Fiery Posted November 10, 2020 Posted November 10, 2020 1 minute ago, canr6 said: No 1 x 980 pro 500 gb 1x 1 tb 970 evo m2 no raid Thank you! Please right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> SMART Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> RAID Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
canr6 Posted November 10, 2020 Author Posted November 10, 2020 8 hours ago, Fiery said: Teşekkür ederim! Lütfen AIDA64 ana penceresinin alt durum çubuğuna sağ tıklayın -> Disk Hata Ayıklama -> SMART Dökümü . Tüm sonuçları bu konuya kopyalayıp yapıştırın veya sonuçları TXT dosyası olarak gönderinize ekleyin. Önce AIDA64 / ana menü / Görünüm'de durum çubuğunu etkinleştirmeniz gerekebilir. Ayrıca AIDA64 ana penceresinin alt durum çubuğuna sağ tıklayın -> Disk Hata Ayıklama -> RAID Dökümü . Tüm sonuçları bu konuya kopyalayıp yapıştırın veya sonuçları TXT dosyası olarak gönderinize ekleyin. Teşekkürler Fiery smartdump.txt raiddump.txt Quote
Fiery Posted November 12, 2020 Posted November 12, 2020 On 11/10/2020 at 8:02 PM, canr6 said: smartdump.txt 9.15 kB · 1 download raiddump.txt 158.97 kB · 0 downloads Thank you! Please try to install Samsung's NVMe drivers that are suitable for 980 Pro, and let me know if it helps. Quote
canr6 Posted November 12, 2020 Author Posted November 12, 2020 43 minutes ago, Fiery said: Teşekkür ederim! Lütfen Samsung'un 980 Pro için uygun NVMe sürücülerini yüklemeyi deneyin ve yardımcı olup olmadığını bana bildirin. No driver for 980 pro Quote
Fiery Posted November 12, 2020 Posted November 12, 2020 45 minutes ago, canr6 said: No driver for 980 pro Thank you for the info. Please send us a final dump: right-click on the bottom status bar of AIDA64 main window --> Disk Debug --> NVMe Dump. Quote
canr6 Posted November 12, 2020 Author Posted November 12, 2020 nvmedump.txt 2 hours ago, Fiery said: Bilgi için teşekkürler. Lütfen bize son bir döküm gönderin: AIDA64 ana penceresinin alt durum çubuğuna sağ tıklayın -> Disk Hata Ayıklama -> NVMe Dökümü . Quote
Fiery Posted November 24, 2020 Posted November 24, 2020 On 11/21/2020 at 6:58 PM, canr6 said: @Fiery ? Thank you for the data. I'm afraid we cannot find the root cause of the issue. We'll need to order a 980 Pro SSD unit and try to replicate the issue using it. 1 Quote
