CPU Package temperatures doubt (Xeon E5-2650 v2 + Asus Rampage IV Extreme)
hi im using motherboard asus rampage 4 extreme  with xeon e5-2650v2 and cpu package it's always 10-11 more than the rest
and checking on other softwares the cpu package does not show this temperature, which one is correct the aida64 or the others?
https://i.imgur.com/JD16pmz.png
We've checked, and I'm pretty sure our CPU Package temperature measurement works fine.  I'm not sure if HWMonitor's correct since it's not our software, so I don't have an oversight on the validity of those readings.
However, if you're in doubt about the CPU Package temperature, just ignore it and focus on the other CPU related thermal readings that your motherboard and processor provides.
