I have set up sensorpanel but my two M2 drives temperatures (digits) are sometimes not showing. When i want to edit and check the "OK" button is greyed out. One startup they show immediately, other startup not. Or become visible after some time.
The sensors are visible in the Sensorpanel edit screen though.
Same problem voor Down and upload speed. NIC5 is not regonized in the sensorpanel setup. In aida64 itself is there.
I have a ASUS Strix-E X570 motherboard.
I am on the latest beta version
1) What are the model ID of those M.2 SSD's?
2) Is your NIC5 a simple wired Ethernet network connection?  Can you see it on the Network / Windows Network page of AIDA64?
