So I have searched through the forum on this issue and the common answer is you need to have Riva Tuner installed which I do..  Yet for some reason the RTS FPS option on my panel  constantly displays 0 fps.  Is there specific settings I need to have for my aida64 options in Riva Tuner?   I have tried to do multiple searches and have not come up with a reason to why this is happening.  Any and all help is welcome.
As far as we know, RTSS support is properly implemented on our end.  So in case RTSS fails to provide the FPS values using the standardized method, then I'd try contacting RTSS author to find out what could be wrong on his end.
I will contact them,  but I am not sure if it is on there side as it is reporting FPS in MSI Afterburner.  Which makes me think it is an issue with the link between Aida64 and Riva Tuner.
  • 3 months later...
