hamad Posted December 2, 2020 Posted December 2, 2020 Hi Is this considered normal I will not encounter any problems Most of the time the temperature does not exceed 80 ° C for just a second? my cpy : i9 10900k overclocke to 5.2 GHz Motherboard : ASUS ROG MAXIMUS XII FORMULA Quote
Fiery Posted December 2, 2020 Posted December 2, 2020 3 hours ago, hamad said: Hi Is this considered normal I will not encounter any problems Most of the time the temperature does not exceed 80 ° C for just a second? my cpy : i9 10900k overclocke to 5.2 GHz Motherboard : ASUS ROG MAXIMUS XII FORMULA Under heavy load such small amount of throttling is considered acceptable for a high-performance + overclocked system like yours. I suppose the only way to avoid it in your case would be to switch to liquid cooling. Quote
hamad Posted December 2, 2020 Author Posted December 2, 2020 2 hours ago, Fiery said: Under heavy load such small amount of throttling is considered acceptable for a high-performance + overclocked system like yours. I suppose the only way to avoid it in your case would be to switch to liquid cooling. First, I am really sorry for repeating the topic in more than one place It is already water cooling sir Quote
Fiery Posted December 2, 2020 Posted December 2, 2020 11 minutes ago, hamad said: It is already water cooling sir That's quite odd then. Well... I suppose it would be best to consult overclocking enthusiasts on XtremeSystems or other similar forums about your liquid cooler setup and whether it's normal to have such high thermals with your particular setup. Quote
