cloudconnected Posted December 20, 2020 Posted December 20, 2020 Can pls someone help me? I cant import Templates. I click on import choose the right file und nothing happens Quote
Fiery Posted December 21, 2020 Posted December 21, 2020 14 hours ago, cloudconnected said: Can pls someone help me? I cant import Templates. I click on import choose the right file und nothing happens Where do you get your templates from? Are you trying to import them into the LCD module or SensorPanel module? Quote
cloudconnected Posted December 21, 2020 Author Posted December 21, 2020 both doesnt work from the channel here share you templates and from http://www.lamptron.com/Products/HardwareMonitor/117.html Quote
Fiery Posted January 6, 2021 Posted January 6, 2021 On 12/21/2020 at 5:05 PM, cloudconnected said: both doesnt work from the channel here share you templates and from http://www.lamptron.com/Products/HardwareMonitor/117.html What happens when you try to import a .sensorpanel file using the SensorPanel Manager's Import button? Quote
AaronYTW6715 Posted May 28, 2021 Posted May 28, 2021 Hello! It seems like I'm having the same issues. After I've deleted all the files and import a sensor panel files, nothing shows up! Just wondering have to fixed this problem? If do, mind sharing how? Thank you in advance! Quote
Pagano89 Posted July 17, 2021 Posted July 17, 2021 Hi, also having the same issue, can save a sensor panel but cant import one. tried pre-made panels from here and my own that were saved previously, but none import. any update on this issue ? Thanks Quote
flu_years Posted August 20, 2021 Posted August 20, 2021 Hello, I'm also having the same issue. I can put new elements on the LCD but can't import premade template. The function works just fine yesterday and suddenly became unusable. Quote
9junes Posted January 5, 2022 Posted January 5, 2022 Has any of your guys figured it out? I have the same issue, I can import sensor panel template but not lcd template. Quote
