Anticonformity11 Posted March 12, 2012 Posted March 12, 2012 Hello, I have noticed that my computer does not have an average CPU temp like the other computers I have installed AIDA64 on. It only shows the following: CPU #1 / Core #1 20C CPU #1 / Core #2 20C CPU #1 / Core #3 20C CPU #1 / Core #4 20C CPU #1 / Core #5 20C CPU #1 / Core #6 20C In the other computers I have used it has a single CPU Temp with an average temperature. Also, I am running a Phenom II Black Edition 1090T (not OC'd) with the stock fan. ~20C on idle is too good to be true. Can someone help me troubleshoot this? - Anticonformity11 Quote
Fiery Posted March 15, 2012 Posted March 15, 2012 1) What motherboard do you have? 2) What version of AIDA64 are you using? 3) Please note that AMD processors may or may not feature an accurate temperature diode. It is a hardware flaw that affects a lot of processor parts Also, core diode temperatures will all become zero when ACC (Advanced Clock Calibration) is activated in the BIOS Setup. Regards, Fiery Quote
Anticonformity11 Posted March 16, 2012 Author Posted March 16, 2012 Thank you for your response. I have an Asus M4A785-M and I'm using AIDA64 Extreme Edition (Not the trial version, I liked it so much I bought it). Also, if you don't mind me asking, does AIDA64's System Stability Test work just as good as an application such as Orthos or Prime95? Thank you for listening, Anticonformity11 Quote
Fiery Posted March 16, 2012 Posted March 16, 2012 Please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic. Using that data we can adjust the sensor readings to perfectly suit your motherboard. As for the AIDA64 System Stability Test, yes, we believe it is just as good or even better than competitive solutions. Our solution uses state-of-the-art methods like AVX and XOP acceleration, and now features an OpenCL GPGPU module as well. However, due to the fact that instability issues cannot be characterized or defined like a mathematical formula, there's no telling which stress tesing or stability checking solution would be able to catch an instability situation, or trigger a system malfunction while stressing the computer. AIDA64 System Stability Test is well-proven and favored by many enthusiasts, and we never stop improving it to make it even more efficient. Quote
Anticonformity11 Posted March 17, 2012 Author Posted March 17, 2012 ------[ AIDA64 v2.00.1700 ]------ ------[ Microsoft Windows 7 Home Premium 6.1.7601 (64-bit) ]------ ------[ Motherboard Info ]------ Motherboard ID : 64-1006-000001-00101111-081810-RS785_SB710$A1429001_BIOS DATE: 08/18/10 17:03:35 VER: 10.06 Motherboard Model : Asus M4A785-M Motherboard Chipset : AMD 785G, AMD K10 DMI MB Manufacturer : ASUSTeK Computer INC. DMI MB Product : M4A785-M DMI MB Version : Rev X.0x DMI MB Serial : 104417150002046 DMI SYS Manufacturer: System manufacturer DMI SYS Product : System Product Name DMI SYS Version : System Version DMI SYS Serial : System Serial Number DMI BIOS Version : 1006 ITE 87xx Port = 2Eh ITE 87xx HWMonitor Port = 0290h ITE 87xx Device ID = 8712h ITE 87xx Version = 08h Winbond SuperIO Port = 00h Winbond SuperIO HWMonitor Port = 0000h Winbond SuperIO Device ID = FFFFh Fintek SuperIO Port = 00h Fintek SuperIO HWMonitor Port = 0000h Fintek SuperIO Device ID = 0000h LPC47 SuperIO HWMonitor Port = 0000h LPC47 SuperIO Device ID = FFFFh ------[ LM78 ISA Sensor Device at 0290 ]------ 0000 19 00 FF 03 00 00 00 00 00 80 40 09 03 BC FF 00 0010 FF FF FF 37 87 7F 7F 7F 00 FF 00 FF FF FF FF FF 0020 4A FF CF FF C4 63 FF FF D1 23 2C 80 EE F0 F0 F0 0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0040 FF FF FF FF FF FF FF FF 2D FF FF FF FF FF FF FF 0050 35 18 7F 7F 7F 00 56 56 90 56 FF 12 80 00 00 00 0060 7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF 0070 7F 7F 7F 00 00 7F FF FF FF FF FF FF FF FF FF FF 0080 00 00 00 00 FF FF FF FF 00 00 FF 40 02 00 99 99 0090 7F 7F 7F 00 00 7F FF FF 7F 7F 7F 00 00 7F FF FF 00A0 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 0029 002A 002B T: 35 44 128 T: 35 44 128 T: 35 44 128 T: 35 44 128 T: 35 43 128 T: 35 43 128 T: 36 44 128 T: 36 44 128 T: 36 44 128 T: 36 44 128 Reg$20 CPU Core: r = 74, r*0.016 = 1.18 Reg$21 CPU Aux: r = 255, r*0.016 = 4.08 Reg$22 +3.3 V: r = 207, r*0.016 = 3.31 Reg$23 +5 V: r = 255, r*0.016 = 4.08 Reg$24 +12 V: r = 196, r*0.016 = 3.14 Reg$25 -12 V: r = 99, r*0.016 = 1.58 Reg$26 -5 V: r = 255, r*0.016 = 4.08 ------[ SB7xx/8xx/9xx PM2 at 0CD0 ]------ 0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0010 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 00 00 00 00 00 00 00 FF FF FF 00 00 00 00 00 0030 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0040 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0070 00 00 00 00 00 00 00 00 00 00 00 10 00 00 00 00 0080 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0090 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 00 00 00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00E0 51 F0 F8 F1 F0 F4 F0 70 00 EC FD FD C0 F0 F0 F0 00F0 B0 22 F0 00 80 00 00 20 E2 F0 10 FF FF FF FF FF Reg$59VIN0: r = $0000, r*0.000046 = 0.0000 Reg$5DVIN1: r = $0000, r*0.000046 = 0.0000 Reg$61VIN2: r = $0000, r*0.000046 = 0.0000 Reg$65VIN3: r = $0000, r*0.000046 = 0.0000 Reg$69VIN4: r = $0000, r*0.000046 = 0.0000 Reg$6DVIN5: r = $0000, r*0.000046 = 0.0000 Reg$71VIN6: r = $0000, r*0.000046 = 0.0000 Reg$75VIN7: r = $0000, r*0.000046 = 0.0000 ------[ SB7xx/8xx/9xx PM at 0CD6 ]------ 0000 00 01 00 00 00 00 00 00 00 00 00 00 00 43 0C 00 0010 6B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0020 00 08 04 08 08 08 10 08 20 08 B0 00 00 FE B8 00 0030 00 00 00 00 00 00 00 04 00 00 00 10 00 00 01 FF 0040 00 00 50 9E 04 00 00 00 00 00 00 00 00 00 00 00 0050 E0 05 82 40 00 27 00 05 0C 08 00 00 00 00 00 00 0060 20 48 00 05 02 B4 20 06 8C 03 00 00 F0 00 C0 FE 0070 00 00 0B 80 40 C1 FF FF FF FB 00 00 1F 02 00 00 0080 06 21 43 55 5B 02 00 00 10 10 90 01 00 11 00 20 0090 00 FF FF 00 1C 06 00 00 00 00 B6 00 00 00 D0 00 00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00B0 2B 50 91 00 00 00 00 00 00 00 00 60 00 00 00 00 00C0 00 00 00 30 55 55 55 00 00 01 00 00 00 00 00 00 00D0 00 00 00 00 40 00 00 E3 00 00 00 00 00 00 00 00 00E0 00 05 3A 00 00 05 3A 00 00 05 3A 00 00 05 3A 00 00F0 00 05 3A 00 00 05 3A 00 00 05 3A 00 00 05 3A 00 ------[ ACPI Temperatures & Fans ]------ _TZ_.THM0._TMP : _TZ_.THM1._TMP : _TZ_.THR0._TMP : _TZ_.THR1._TMP : _TZ_.TZ00._TMP : _TZ_.TZ01._TMP : _TZ_.RTMP : _TZ_.RFAN : _TZ_.RFAN(0) : _TZ_.RFAN(1) : _SB_.ATKD._HID : _SB_.ATKD.TMPR : _SB_.PCI0.LPC0.EC0_.CCTV : _SB_.PCI0.LPC0.EC0_.LRPM : _SB_.PCI0.LPC0.EC0_.HRPM : _SB_.PCI0.SBRG.EC0_.ECPU : _SB_.PCI0.SBRG.EC0_.TACH(0): _SB_.PCI0.SBRG.EC0_.TACH(1): _SB_.PCI0.SBRG.EC0_.TAH0 : _SB_.PCI0.SBRG.EC0_.TAH1 : _SB_.PCI0.SBRG.EC0_.ST00 : _SB_.PCI0.SBRG.EC0_.SC01 : _SB_.PCI0.SBRG.EC0_.SC02 : _SB_.PCI0.SBRG.EC0_.SC03 : _SB_.PCI0.SBRG.EC0_.SC04 : _SB_.PCI0.SBRG.EC0_.SC05 : _SB_.PCI0.SBRG.EC0_.SC06 : _SB_.PCI0.PIB_.EC0_.TCRT : _SB_.PCI0.SBRG.EC0_.CTPM : _SB_.PCI0.SBRG.EC__.CPUT : _SB_.PCI0.SBRG.EC__.SYST : _SB_.PCI0.LPC_.EC0_.CTMP : _SB_.PCI0.LPCB.EC0_.CTMP : _SB_.PCI0.LPC_.EC0_.TMP1 : _SB_.PCI0.LPC_.EC0_.TMP2 : _SB_.PCI0.LPC_.EC0_.TMPI : _SB_.PCI0.LPC_.EC0_.TMPV : _SB_.PCI0.LPCB.EC0_.A1TP : _SB_.PCI0.LPCB.EC0_.A2TP : _SB_.PCI0.LPCB.EC0_.FAN0 : _SB_.PCI0.LPCB.EC__.TS1R : _SB_.PCI0.LPCB.EC__.TS2R : _SB_.PCI0.LPCB.EC__.TS3R : _SB_.PCI0.LPCB.EC__.F1FL : _SB_.PCI0.LPCB.EC__.F1FH : _SB_.PCI0.LPCB.EC__.F2FL : _SB_.PCI0.LPCB.EC__.F2FH : _SB_.PCI0.LPC_.H8EC.RTMP : _SB_.PCI0.LPC_.H8EC.LTMP : _SB_.PCI0.LPC_.H8EC.MTMP : _SB_.PCI0.LPC_.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.CTMP : _SB_.PCI0.LPCB.H8EC.DTMP : _SB_.PCI0.LPCB.H8EC.GTMP : _SB_.PCI0.LPCB.H8EC.ITMP : _SB_.PCI0.LPCB.H8EC.MTMP : _SB_.PCI0.LPCB.H8EC.STMP : _SB_.PCI0.LPCB.H8EC.PFAN : ------[ Asus ATK0110 ]------ Motherboard ID: M4A785-M ICPU/VCPU/PCPU: 25620 / 0 / 35190 CPU Temperature : 35.0 C MB Temperature : 43.0 C CHASSIS FAN Speed : 0 RPM CPU FAN Speed : 3571 RPM +12 Voltage : 11.912 V +3.3 Voltage : 3.312 V +5 Voltage : 5.017 V Vcore Voltage : 1.440 V CPU Temperature : 35.0 C MB Temperature : 43.0 C Chassis Fan Speed : 0 RPM CPU Fan Speed : 3571 RPM +12V Voltage : 11.912 V +3.3V Voltage : 3.312 V +5V Voltage : 5.017 V Vcore Voltage : 1.440 V CPU Voltage : 0.8000 V CPU/NB Voltage : 1.200 V DRAM Voltage : 1.950 V GPU Sideport Voltage : 0.000 V HT Voltage : 1.200 V NB Voltage : 1.100 V CPU Frequency : 200.00 MHz GPU Frequency : 500.00 MHz GPU Sideport Frequency: 0.00 MHz CPU Ratio : 16.0x =========================================== Thank you for explaining the stress test for me, Anticonformity11 Quote
Anticonformity11 Posted March 19, 2012 Author Posted March 19, 2012 Could the AUX sensor be the CPU's temperature for some reason? If so, why would it be labeled as AUX and not CPU? Quote
Fiery Posted March 19, 2012 Posted March 19, 2012 Yes, Aux looks like it is the CPU temperature actually. The next AIDA64 beta release will fix the temperature labelling and voltage ratio issues. I'll post a message into this topic once the new beta is available for download. Quote
Fiery Posted March 23, 2012 Posted March 23, 2012 Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild1856ykhfgv3djmzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know how the sensor readings look now. Quote
Anticonformity11 Posted March 24, 2012 Author Posted March 24, 2012 They look great, thanks for your help. I really appreciate it! Quote
