SagiC Posted January 2, 2021 Posted January 2, 2021 Hello Aida64 community! I'm reporting a problem and hope maybe someone has a solution. I use the sensor panel for a little on screen display and its being bogged down by the sensor response time of my NZXT Kraken x63 apparently. I have attached the sensor profile dump, the culprit seems to be the entry "Kraken X-2" Any help would be appreciated sensorprof.txt Quote
ObiWanCanOweMe Posted January 6, 2021 Posted January 6, 2021 I'm seeing similar performance from my Kraken X-2 as well. sensorprof.txt Quote
Fiery Posted January 13, 2021 Posted January 13, 2021 On 1/6/2021 at 2:49 AM, ObiWanCanOweMe said: I'm seeing similar performance from my Kraken X-2 as well. That's the performance you get from a slow USB protocol I'm afraid. We cannot fix this issue from our end. Quote
SagiC Posted January 14, 2021 Author Posted January 14, 2021 On 1/13/2021 at 7:27 AM, Fiery said: That's the performance you get from a slow USB protocol I'm afraid. We cannot fix this issue from our end. It seems to be a hit and miss anyway, I think something else is interfering.. Anyway thanks for the reply! Quote
