Netev Posted January 6, 2021 Posted January 6, 2021 in the battery section, there is an error in the description of the charging-discharging process. 1. When actually charging, it shows the status of "discharging" and vice versa when it is actually discharging, it shows the status of being "charging". 2. actually shows the values in amperes (A), but it says that milliamps (mA), that is, the smartphone is charging with 6.2 amperes, it shows that 6.20 milliamps (mA) are being discharged. can you solve this discrepancy? Quote
Fiery Posted January 6, 2021 Posted January 6, 2021 5 minutes ago, Netev said: in the battery section, there is an error in the description of the charging-discharging process. 1. When actually charging, it shows the status of "discharging" and vice versa when it is actually discharging, it shows the status of being "charging". 2. actually shows the values in amperes (A), but it says that milliamps (mA), that is, the smartphone is charging with 6.2 amperes, it shows that 6.20 milliamps (mA) are being discharged. can you solve this discrepancy? Thank you, the issue will be fixed in the next AIDA64 for Android app update. 1 Quote
