ChapiChapiLIVE Posted January 8, 2021 Posted January 8, 2021 Hello, first of all thanks for helping me. I just assembled my new PC: - Ryzen 9 5950X -Noctua NH D15 (One ) -x570 Aorus Master -RTX 3070 I would like to know if these temperatures are normal, I have done the Aida64 stress test and after almost 2 hours 01:48 to be exact, it has reached 80º as maximum I have been playing Cyberpunk 2077 for about an hour and the maximum that the CPU has reached is 77º with MSI Afterburner My IDLE temps without doing anything on the computer and only watching the msi afterburner monitor is about 40 - 50º But sometimes i see some spikes of 67º Being in Windows 10 while I use google, I open tabs and the temperature is around the same. I am using only one fan in the NH D15 because the second one does not fit me due to the height of the RAM, but as I saw in reddit there should not be much difference between using 1 or 2 only a few degrees less How do you see these temperatures? They are normal? Quote
Fiery Posted January 9, 2021 Posted January 9, 2021 12 hours ago, ChapiChapiLIVE said: Hello, first of all thanks for helping me. I just assembled my new PC: - Ryzen 9 5950X -Noctua NH D15 (One ) -x570 Aorus Master -RTX 3070 I would like to know if these temperatures are normal, I have done the Aida64 stress test and after almost 2 hours 01:48 to be exact, it has reached 80º as maximum I have been playing Cyberpunk 2077 for about an hour and the maximum that the CPU has reached is 77º with MSI Afterburner My IDLE temps without doing anything on the computer and only watching the msi afterburner monitor is about 40 - 50º But sometimes i see some spikes of 67º Being in Windows 10 while I use google, I open tabs and the temperature is around the same. I am using only one fan in the NH D15 because the second one does not fit me due to the height of the RAM, but as I saw in reddit there should not be much difference between using 1 or 2 only a few degrees less How do you see these temperatures? They are normal? They look normal to me. Quote
