Hello,
any idea, why the Southbridge Fan is the only one which is not listed in Aida/Sensors?
Motherboard Name    ASRock X570 Creator  (3 PCI-E x1, 3 PCI-E x16, 2 M.2, 4 DDR4 DIMM, Audio, Video, Dual Gigabit LAN, WiFi)
https://www.asrock.com/MB/AMD/X570 Creator/index.asp
Driver latest ASRock Motherboard Utility ver:3.0.378
BIOS Typ    AMI (12/01/2020)
I tryed HWInfo and there is the Fan listed.
thanks
Debug Infos:
Sensor Properties
Sensor Type	Nuvoton NCT6683D  (ISA A24h)
GPU Sensor Type	Diode  (NV-Diode)
Temperatures
Motherboard	39 °C
CPU	71 °C
CPU Diode	72 °C
M.2 #1	74 °C
South Bridge	74 °C
PCH Diode	74 °C
Temperature #1 (Commander Pro)	34 °C
Temperature #2 (Commander Pro)	5 °C
Temperature #3 (Commander Pro)	5 °C
Temperature #4 (Commander Pro)	123 °C
GPU1: GPU Diode	53 °C
GPU2: GPU Diode	41 °C
DIMM1	54 °C
DIMM2	54 °C
DIMM3	54 °C
DIMM4	54 °C
WDS200T1X0E-00AFY0	60 °C
Seagate FireCuda 520 SSD ZP2000GM30002	47 °C
Samsung SSD 970 EVO 1TB	30 °C / 38 °C
Cooling Fans
CPU	606 RPM
Front	630 RPM
CPU Pumpe	1238 RPM
rechts oben (Commander Pro)	1007 RPM
unten rechts (Commander Pro)	1037 RPM
unten links (Commander Pro)	1026 RPM
hinten 140 (Commander Pro)	808 RPM
rechts unten (Commander Pro)	947 RPM
Fan #26 (Commander Pro)	0 RPM
GPU1: GPU	1106 RPM  (61%)
GPU1: GPU2	1109 RPM  (61%)
GPU2: GPU	990 RPM  (30%)
GPU2: GPU2	991 RPM  (30%)
Voltage Values
CPU Core	1.100 V
CPU VID	1.100 V
+3.3 V	3.296 V
+5 V	4.980 V
+12 V	12.288 V
DIMM	1.216 V
Chipset	0.520 V
SoC	0.544 V
VPPM	2.528 V
CPU VDD	1.419 V
CPU VDDNB	1.081 V
GPU1: GPU Core	0.725 V
GPU2: GPU Core	0.719 V
Current Values
CPU VDD	56.12 A
CPU VDDNB	5.41 A
Power Values
CPU Package	85.51 W
CPU VDD	79.62 W
CPU VDDNB	5.85 W
GPU1: GPU	42.95 W
GPU1: GPU TDP%	13%
GPU2: GPU	39.33 W
GPU2: GPU TDP%	17%
Motherboard ID      : 63-0100-000001-00101111-122418-Chipset$0AAAA000_BIOS DATE: 12/01/20 16:36:07 VER: 05.00011
Motherboard Model   : ASRock X570 Creator
Motherboard Chipset : AMD Bixby X570, AMD K17.7 FCH, AMD K17.7 IMC
DMI MB Manufacturer : ASRock
DMI MB Product      : X570 Creator
DMI MB Version      :
DMI MB Serial       :
DMI SYS Manufacturer: To Be Filled By O.E.M.
DMI SYS Product     : To Be Filled By O.E.M.
DMI SYS Version     : To Be Filled By O.E.M.
DMI SYS Serial      : To Be Filled By O.E.M.
DMI BIOS Version    : P3.30
ITE SuperIO Port           = 00h
ITE SuperIO HWMonitor Port = 0000h     (    0000h /     0000h)
ITE SuperIO HWMonitor MMIO = 00000000h (00000000h / 00000000h)
ITE SuperIO Device ID      = 0000h     (    0000h /     0000h)
ITE SuperIO Version        = 00h       (      00h /       00h)
Winbond SuperIO Port              = 2Eh
Winbond SuperIO HWMonitor Port/60 = 0A20h (0A20h / 0000h)
Winbond SuperIO Device ID         = C732h (C732h / 0000h)
Winbond Sensor ID A3/5C/reg$58    = FF / FF / FF
Fintek SuperIO Port           = 00h
Fintek SuperIO Device ID      = 0000h (0000h / 0000h)
SMSC SuperIO Port           = 00h
SMSC SuperIO Device ID      = 0000h (0000h / 0000h)
ASpeed SuperIO Port = 00h
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #0 ]------
0000  C7 32 1C 00  00 00 00 03  FF 00 FC 87  01 00 01 F8
0010  3F E6 2F 00  00 00 FF FF  FF FF FE FF  FF FF FF FF
0020  FF FF 00 00  FF FF 01 40  FF FF FF FF  FF FF FF FF
0030  C3 01 00 04  00 00 00 00  00 44 0E 03  1E 00 00 00
0040  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0050  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0060  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0070  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0080  DC EB F5 FE  05 0C 12 19  20 27 2F 39  45 55 73 A7
0090  FF 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  B0 F0 A0 90  70 70 60 70  70 70 80 A0  C0 00 E0 48
00B0  40 00 00 17  00 00 00 00  00 00 00 00  00 00 00 00
00C0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00D0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00E0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00F0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #1 ]------
0000  31 80 27 00  31 80 46 00  4A 00 00 00  00 00 00 00
0010  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0020  1F 00 3E 00  40 00 4C 00  41 00 44 00  4F 00 CE 00
0030  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0040  02 60 00 00  04 D6 02 81  00 00 09 FE  00 00 00 00
0060  45 B0 F6 53  B0 57 00 00  00 00 78 00  00 F5 C1 C7
0070  00 00 00 00  00 00 00 00  00 00 FF 00  12 00 00 3F
0080  80 0A 08 20  00 05 0A 05  2F 02 02 0A  00 00 7A FF
0090  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  89 88 89 46  47 00 00 00  00 00 00 00  00 00 00 00
00B0  66 67 68 6D  76 72 73 60  00 00 00 00  00 00 00 00
00C0  A5 A7 AE B0  B2 B6 20 20  20 20 20 20  20 20 20 20
00D0  A6 A8 AF B1  B3 B7 20 20  03 03 03 03  03 03 03 03
00E0  06 40 06 40  06 40 06 40  06 40 06 40  06 40 06 40
00F0  80 80 80 80  80 80 80 80  00 03 40 05  20 00 09 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #2 ]------
0000  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0020  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0080  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00A0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00B0  00 00 00 00  A0 00 B0 00  00 00 00 00  00 00 00 00
00C0  FF FF FF FF  FF FF FF FF  FF FF FF 01  21 24 03 25
00E0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00F0  00 00 00 00  00 00 00 00  00 00 00 00  08 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #3 ]------
00B0  00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00F0  00 00 00 00  00 00 00 00  00 00 00 00  00 01 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #4 ]------
0010  A3 96 40 00  33 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #5 ]------
0060  41 01 07 07  05 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #6 ]------
0000  C7 31 0E 2B  13 07 0C 00  01 00 00 00  12 05 1C 00
0010  C7 31 FF FF  12 05 1E 00  00 00 00 00  00 00 00 00
0020  B0 03 00 26  8B 00 00 00  00 00 00 00  00 00 00 00
0030  00 01 00 00  00 00 00 00  46 10 00 00  00 00 00 00
0040  50 00 46 10  00 00 00 00  00 00 00 00  00 00 00 00
0050  A7 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0070  07 00 69 05  00 00 00 00  00 00 00 00  00 00 00 00
00A0  00 01 00 00  50 00 02 00  00 00 00 00  00 00 00 01
00B0  50 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
00D0  00 00 00 00  00 00 00 00  12 05 1C 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #7 ]------
0010  C0 00 00 00  00 00 80 00  00 00 00 C0  00 00 00 00
0020  00 00 00 00  00 00 00 00  80 20 09 01  01 00 00 80
0040  07 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0060  08 08 00 80  00 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #8 ]------
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #9 ]------
0000  80 80 80 80  80 80 00 00  00 00 00 00  00 00 00 00
0010  00 00 00 01  00 00 00 02  00 00 00 08  00 00 00 08
0020  00 00 00 02  00 00 00 10  00 00 00 00  00 00 00 00
00D0  03 03 03 03  03 03 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #10 ]------
0000  C0 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
0020  00 00 00 00  00 00 00 00  80 80 80 FF  80 80 80 80
0040  00 00 00 00  00 00 00 00  03 E8 07 D0  1E 1E 1E 22
0050  3C 44 44 44  03 02 02 3C  02 00 00 00  00 00 00 00
0080  01 00 00 00  0A 00 00 00  02 00 00 00  A0 00 00 00
0090  14 00 00 00  00 0A 00 00  08 00 00 00  00 A0 00 00
00A0  10 00 00 00  00 00 0A 00  20 00 00 00  00 00 A0 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #11 ]------
0000  1E 41 55 5A  64 7F 7F 00  3E 00 4A 00  CC 00 FF 00
0010  FF 00 FF 00  FF 00 00 00  1E 46 46 46  64 7F 7F 00
0020  99 00 FF 00  FF 00 FF 00  FF 00 FF 00  FF 00 00 00
0030  1E 4B 4B 4B  64 7F 7F 00  99 00 FF 00  FF 00 FF 00
0040  FF 00 FF 00  FF 00 00 00  22 4D 59 5D  64 7F 7F 00
0050  27 00 5A 00  97 00 CA 00  FF 00 FF 00  FF 00 00 00
0060  1E 46 46 46  64 7F 7F 00  99 00 FF 00  FF 00 FF 00
0070  FF 00 FF 00  FF 00 00 00  1E 41 55 5A  5A 7F 7F 00
0080  17 00 4A 00  66 00 99 00  FF 00 FF 00  FF 00 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #12 ]------
0080  00 45 00 B0  00 F4 00 52  00 B0 00 57  00 00 00 00
00A0  31 27 46 46  27 4A 00 00  00 00 00 00  00 00 00 00
00F0  00 00 00 00  00 00 00 00  60 00 00 00  FF 80 00 00
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #13 ]------
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #14 ]------
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #15 ]------
------[ NCT6683 ISA Sensor Device at 0A20 / Bank #16 ]------
   0100  0102  0104  0106  0108
T:   49    39    49    70    74
T:   49    39    49    70    74
T:   49    39    49    70    74
T:   49    39    49    70    74
T:   49    39    49    69    74
T:   49    39    49    69    74
T:   49    39    49    68    74
T:   49    39    49    67    74
T:   49    39    49    67    74
T:   49    39    49    66    74
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #0 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #1 ]------
0000  31 00 27 00  31 80 42 00  4A 00 00 00  00 00 00 00
0020  27 00 3E 00  40 00 4C 00  41 00 44 00  4F 00 CC 00
0040  02 60 00 00  04 D6 02 4F  00 00 09 DE  00 00 00 00
0060  45 B0 ED 4F  B0 57 00 00  00 00 91 00  00 39 F1 14
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #2 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #3 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #4 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #5 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #6 ]------
0020  B6 03 00 26  8B 00 00 00  00 00 00 00  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #7 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #8 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #9 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #10 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #11 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #12 ]------
0080  00 45 00 B0  00 EB 00 4D  00 B0 00 57  00 00 00 00
00A0  31 27 42 42  27 4A 00 00  00 00 00 81  00 00 00 00
00B0  00 00 00 00  00 00 00 00  00 00 00 81  00 00 00 00
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #13 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #14 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #15 ]------
------[ NCT6683 ISA Sensor Device at 0A24 / Bank #16 ]------
T:   49    39    49    66    74
T:   49    39    49    67    74
T:   49    39    49    67    74
T:   49    39    49    67    74
T:   49    39    49    67    74
T:   49    39    49    66    74
T:   49    39    49    67    74
T:   49    39    49    66    74
T:   49    39    49    67    74
T:   49    39    49    69    74
------[ K15.6/K15.7/K16.6/K17/K17.1/K17.3/K17.5/K17.6/17.7/K18/K21 PM2 at 0CD0 ]------
0000  05 04 01 00  00 00 00 00  00 00 00 00  00 00 00 00
0010  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0020  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0030  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0040  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0050  00 00 00 00  FF FF FF FF  FF FF FF FF  FF FF FF FF
0060  00 00 00 00  00 00 00 00  00 00 00 FF  FF FF FF FF
0070  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
0080  FF FF FF FF  FF FF FF FF  FF FF 00 00  00 00 00 00
0090  00 00 00 00  00 FF FF FF  FF FF FF FF  FF FF FF FF
00A0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00B0  00 FF 00 00  FF 00 00 FF  FF FF FF FF  FF FF FF FF
00C0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
00D0  FF FF FF FF  FF FF FF FF  FF FF FF FF  FF 00 FF 00
00E0  00 00 00 00  00 00 00 00  00 00 00 00  01 00 00 02
00F0  19 0A 02 05  C8 20 80 00  04 06 00 00  08 08 00 02
------[ K15.6/K15.7/K16.6/K17/K17.1/K17.3/K17.5/K17.6/17.7/K18/K21 PM at 0CD6 ]------
0000  77 0B 07 E3  02 04 01 00  14 05 1C 02  06 21 43 55
0010  74 00 50 01  16 00 20 00  42 86 64 A8  40 00 3C 00
0020  20 01 9C 01  A1 00 E0 00  55 00 10 00  80 00 00 00
0030  00 00 00 00  00 00 00 00  00 00 00 00  00 08 01 00
0040  FF FF FF 00  00 00 00 88  21 2B 35 59  00 00 3F 49
0050  00 00 3E 3F  90 00 00 14  01 FF 55 44  00 06 00 00
0060  00 08 04 08  08 08 10 08  20 08 B2 00  FF FF BA 00
0070  01 0B 00 00  17 01 06 19  FF FF 00 00  FF FF E0 80
0080  00 00 26 00  00 00 00 00  00 00 00 00  9E 00 80 00
0090  02 05 02 0B  01 00 10 00  00 10 00 01  00 00 00 00
00A0  00 00 00 00  00 00 00 00  F8 CE FF 00  00 00 00 00
00B0  00 20 84 02  00 00 80 05  88 00 28 00  02 00 52 C0
00C0  00 08 08 00  28 02 00 00  0C 40 28 00  DB B6 6D DB
00D0  00 F4 00 BF  00 00 00 00  00 00 11 00  00 00 00 00
00E0  D8 0C 00 00  00 00 01 00  04 00 00 01  15 14 0B 7F
00F0  9C 73 00 00  00 00 00 00  3F 00 F0 FE  00 00 00 00
_TZ_.THM0._TMP             :
_TZ_.THM1._TMP             :
_TZ_.THR0._TMP             :
_TZ_.THR1._TMP             :
_TZ_.TZ00._TMP             :
_TZ_.TZ01._TMP             :
_TZ_.RTMP                  :
_TZ_.RFAN                  :
_TZ_.RFAN(0)               :
_TZ_.RFAN(1)               :
_SB_.ATKD._HID             :
_SB_.ATKD.TMPR             :
_SB_.PCI0.LPC0.EC0_.CCTV   :
_SB_.PCI0.LPC0.EC0_.LRPM   :
_SB_.PCI0.LPC0.EC0_.HRPM   :
_SB_.PCI0.SBRG.EC0_.ECPU   :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0   :
_SB_.PCI0.SBRG.EC0_.TAH1   :
_SB_.PCI0.SBRG.EC0_.ST00   :
_SB_.PCI0.SBRG.EC0_.SC01   :
_SB_.PCI0.SBRG.EC0_.SC02   :
_SB_.PCI0.SBRG.EC0_.SC03   :
_SB_.PCI0.SBRG.EC0_.SC04   :
_SB_.PCI0.SBRG.EC0_.SC05   :
_SB_.PCI0.SBRG.EC0_.SC06   :
_SB_.PCI0.SBRG.EC0_.TH0R   :
_SB_.PCI0.SBRG.EC0_.TH1R   :
_SB_.PCI0.SBRG.EC0_.F0TS   :
_SB_.PCI0.SBRG.EC0_.F1TS   :
_SB_.PCI0.PIB_.EC0_.TCRT   :
_SB_.PCI0.SBRG.EC0_.CTPM   :
_SB_.PCI0.SBRG.EC__.CPUT   :
_SB_.PCI0.SBRG.EC__.SYST   :
_SB_.PCI0.LPC_.EC0_.CTMP   :
_SB_.PCI0.LPCB.EC0_.CTMP   :
_SB_.PCI0.LPC_.EC0_.TMP1   :
_SB_.PCI0.LPC_.EC0_.TMP2   :
_SB_.PCI0.LPC_.EC0_.TMPI   :
_SB_.PCI0.LPC_.EC0_.TMPV   :
_SB_.PCI0.LPCB.EC0_.A1TP   :
_SB_.PCI0.LPCB.EC0_.A2TP   :
_SB_.PCI0.LPCB.EC0_.FAN0   :
_SB_.PCI0.LPCB.EC__.TS1R   :
_SB_.PCI0.LPCB.EC__.TS2R   :
_SB_.PCI0.LPCB.EC__.TS3R   :
_SB_.PCI0.LPCB.EC__.F1FL   :
_SB_.PCI0.LPCB.EC__.F1FH   :
_SB_.PCI0.LPCB.EC__.F2FL   :
_SB_.PCI0.LPCB.EC__.F2FH   :
_SB_.PCI0.LPC_.H8EC.RTMP   :
_SB_.PCI0.LPC_.H8EC.LTMP   :
_SB_.PCI0.LPC_.H8EC.MTMP   :
_SB_.PCI0.LPC_.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.CTMP   :
_SB_.PCI0.LPCB.H8EC.DTMP   :
_SB_.PCI0.LPCB.H8EC.GTMP   :
_SB_.PCI0.LPCB.H8EC.ITMP   :
_SB_.PCI0.LPCB.H8EC.MTMP   :
_SB_.PCI0.LPCB.H8EC.STMP   :
_SB_.PCI0.LPCB.H8EC.PFAN   :
_SB_.PCI0.LPCB.EC0_.OTPC   :
_SB_.PCI0.LPCB.EC0_.VGAT   :
_SB_.PCI0.LPCB.EC0_.CHPT   :
_SB_.PCI0.LPCB.EC0_.CPUT   :
_SB_.PCI0.LPCB.EC0_.SYST   :
_SB_.PCI0.LPCB.EC0_.DTS1   :
_SB_.PCI0.LPCB.EC0_.DTS2   :
_SB_.PCI0.LPCB.EC0_.DIMM   :
_SB_.PCI0.LPCB.EC0_.FANH   :
_SB_.PCI0.LPCB.EC0_.FANL   :
_SB_.PCI0.LPCB.EC0_.CUTP   :
_SB_.PCI0.LPCB.EC0_.PHTP   :
_SB_.PCI0.LPCB.EC0_.DIMT   :
_SB_.PCI0.LPCB.EC0_.INLE   :
_SB_.PCI0.LPCB.EC0_.PANT   :
_SB_.PCI0.LPCB.EC0_.F0RM   :
_SB_.PCI0.LPCB.EC0_.F0DT   :
_SB_.PCI0.LPCB.EC0_.F1RM   :
_SB_.PCI0.LPCB.EC0_.F1DT   :
_SB_.PCI0.SBRG.EC0_.CUTP   :
_SB_.PCI0.SBRG.EC0_.PHTP   :
_SB_.PCI0.SBRG.EC0_.DIMT   :
_SB_.PCI0.SBRG.EC0_.INLE   :
_SB_.PCI0.SBRG.EC0_.PANT   :
_SB_.PCI0.SBRG.EC0_.F0RM   :
_SB_.PCI0.SBRG.EC0_.F0DT   :
_SB_.PCI0.SBRG.EC0_.F1RM   :
_SB_.PCI0.SBRG.EC0_.F1DT   :
_SB_.SAMB.TMPC             :
_SB_.SAMB.TMPH             :
_SB_.STR0._TMP             :
_SB_.STR1._TMP             :
_SB_.STR2._TMP             :
_SB_.STR3._TMP             :
_SB_.STR4._TMP             :
_SB_.STR5._TMP             :
_SB_.STR6._TMP             :
_SB_.STR7._TMP             :
CPUT                       :
GPUT                       :
SYST                       :
FANT                       :
BATT                       :
------[ SMBus #0 ]------
SMBus Type  : Intel / VIA / ServerWorks / SMSC / ATI
SMBus Port  : 0B00
Can Have SPD: Yes
Scan Type   : Full
------[ SMBus Device B00-D18 ]------
  0000  00 00 00 00 00 C3 1C 22 00 FF FF FF FF FF FF FF  ......."........
  0010  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0020  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0030  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0040  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0050  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0060  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0070  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0080  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0090  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00A0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00B0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00C0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00D0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00E0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  00F0  FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF  ................
  0000  EF00 0000 0000 0000 0000 5CC3 851C 2122 0100 FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0010  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0020  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0030  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0040  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0050  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0060  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0070  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0080  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0090  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00A0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00B0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00C0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00D0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00E0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00F0  FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
------[ SMBus Device B00-D19 ]------
  0000  EF00 0000 0000 0000 0000 64C3 851C 2122 0100 FFFF FFFF FFFF FFFF FFFF FFFF FFFF
------[ SMBus Device B00-D1A ]------
------[ SMBus Device B00-D1B ]------
------[ SMBus Device B00-D3B ]------
  0000  03 00 00 00 00 00 00 00 00 00 00 11 11 88 88 00  ................
  0010  00 00 00 03 00 97 3D 65 02 00 00 00 00 11 88 03  ......=e........
  0020  00 00 00 00 00 11 55 38 8E 00 00 00 00 00 00 00  ......U8........
  0030  00 00 00 68 FF FF FF FF FF FF FF FF FF FF FF FF  ...h............
  0040  FF FF FF FF FF 03 00 17 05 FF FF FF FF FF FF FF  ................
  00B0  FF 87 21 FF FF FF FF FF FF FF FF FF FF FF FF FF  ..!.............
  0000  0003 0000 0000 0000 0000 0000 0000 0000 0000 0000 1100 1111 8811 8888 0088 0000
  0010  0000 0000 0300 0003 9700 4097 653D 0265 0002 0000 0000 0000 1100 8811 0388 0003
  0020  0000 0000 0000 0000 1100 5511 3855 8E38 008E 0000 0000 0000 0000 0000 0000 0000
  0030  0000 0000 6800 FF68 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  0040  FFFF FFFF FFFF FFFF FFFF 0003 FF00 0517 FF05 FFFF FFFF FFFF FFFF FFFF FFFF FFFF
  00B0  FFFF 2187 FF21 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
------[ SMBus Device B00-D46 ]------
  0000  9C 6B 70 66 7A 80 72 1B 65 61 65 5B 56 5A 80 80  .kpfz.r.eae[VZ..
  0010  7D 67 51 3C 42 5B 16 07 1D B7 37 99 40 FF FF 4D  }gQ<B[....7.@..M
  0020  E8 57 0A 57 C5 22 10 2E FF FF 00 00 00 00 00 40  .W.W.".........@
  0030  00 00 00 00 00 E8 E8 34 2A 1F 00 3E 5E 00 00 5E  .......4*..>^..^
  0040  93 6E CA A0 5A 28 6B 2A B8 F9 FC 70 6C 00 71 00  .n..Z(k*...pl.q.
  0050  E1 AA A0 90 A0 90 42 84 50 00 00 79 0E 0C F6 0A  ......B.P..y....
  0060  8A 00 40 FF FF 00 99 00 00 6F 08 00 02 04 11 55  ..@......o.....U
  0070  83 70 72 FF AB 2B 04 2E 61 2A B4 00 00 00 00 00  .pr..+..a*......
  0080  B4 07 00 52 49 00 00 50 01 00 00 00 5A 00 00 00  ...RI..P....Z...
  0090  00 00 00 00 00 00 00 00 D4 FC 00 00 00 00 FF FF  ................
  00A0  20 06 23 F0 06 16 00 00 00 00 00 00 00 00 00 00   .#.............
  00B0  0F 48 07 70 65 00 01 00 11 55 2C EB AF 1B 1B 00  .H.pe....U,.....
  00C0  00 23 C6 05 CA 00 FE BC 13 1E 00 00 00 03 00 40  .#.............@
  00D0  0C AD 00 00 00 3F 00 C0 E4 0F 00 00 00 02 00 00  .....?..........
  00E0  00 00 00 00 00 00 00 80 07 01 00 00 00 00 00 00  ................
  00F0  00 00 00 00 00 00 00 00 00 00 04 4D 49 52 00 00  ...........MIR..
  0000  6B9C 706B 6670 7A66 807A 7280 1B72 651B 6165 6561 5B65 565B 5A56 805A 8080 7D80
  0010  677D 5167 3C51 423C 5B42 165B 0716 1D07 B71D 37B7 9937 4099 FF40 FFFF 4DFF E84D
  0020  57E8 0A57 570A C557 22C5 1022 2E10 FF2E FFFF 00FF 0000 0000 0000 0000 4000 0040
  0030  0000 0000 0000 0000 E800 E8E8 34E8 2A34 1F2A 001F 3E00 5E3E 005E 0000 5E00 935E
  0040  6E93 CA6E A0CA 5AA0 285A 6B28 2A6B B82A F9B8 FCF9 70FC 6C70 006C 7100 0071 E100
  0050  AAE1 A0AA 90A0 A090 90A0 4290 8442 5084 0050 0000 7900 0E79 0C0E F60C 0AF6 8A0A
  0060  008A 4000 FF40 FFFF 00FF 9900 0099 0000 6F00 086F 0008 0200 0402 1104 5511 8355
  0070  7083 7270 FF72 ABFF 2BAB 042B 2E04 612E 2A61 B42A 00B4 0000 0000 0000 0000 B400
  0080  07B4 0007 5200 4952 0049 0000 5000 0150 0001 0000 0000 5A00 005A 0000 0000 0000
  0090  0000 0000 0000 0000 0000 0000 0000 D400 FCD4 00FC 0000 0000 0000 FF00 FFFF 20FF
  00A0  0620 2306 F023 06F0 1606 0016 0000 0000 0000 0000 0000 0000 0000 0000 0000 1900
  00B0  481A 0648 7006 6670 0066 0100 0001 1100 5511 2C55 EA2C AFE6 1BAF 1B1B 001B 0000
  00C0  2300 C623 05C6 D705 00D7 0000 BC00 14BC 1F15 001D 0000 0000 0300 0003 4000 0C40
  00D0  AD0C 00AD 0000 0000 3F00 003F C000 E4C0 0FE4 000F 0000 0000 0200 0002 0000 0000
  00E0  0000 0000 0000 0000 0000 0000 8000 0780 0107 0001 0000 0000 0000 0000 0000 0000
  00F0  0000 0000 0000 0000 0000 0000 0000 0000 0000 0400 4D04 494D 5249 0052 0000 9C00
------[ SMBus Device B00-D50 ]------
  0000  23 10 0C 02 86 29 00 08 00 00 00 03 09 03 80 00  #....)..........
  0010  00 00 08 0C FF FF 03 00 6C 6C 6C 11 08 74 30 11  ........lll..t0.
  0020  F0 0A 20 08 00 A8 1E 2B 2B 00 00 00 00 00 00 00  .. ....++.......
  0030  00 00 00 00 00 00 00 00 00 00 00 00 16 36 16 36  .............6.6
  0040  16 36 16 36 00 00 2B 0C 2B 0C 2B 0C 2B 0C 00 00  .6.6..+.+.+.+...
  0050  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0060  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0070  00 00 00 00 00 ED B5 CE 00 00 00 00 00 C2 D6 0F  ................
  0080  11 11 01 01 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0090  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00A0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  00F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 DE 27  ...............'
  0100  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0110  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0120  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0130  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0140  02 9E 00 00 00 00 00 00 00 43 4D 57 31 32 38 47  .........CMW128G
  0150  58 34 4D 34 44 33 36 30 30 43 31 38 00 00 80 AD  X4M4D3600C18....
  0160  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0170  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  0180  0C 4A 05 20 00 00 00 00 00 A3 00 00 05 FF FF 03  .J. ............
  0190  00 50 62 62 10 BA 1D 30 11 F0 0A 20 08 00 B0 20  .Pbb...0... ...
  01A0  2D 00 00 00 00 00 00 00 00 BF 94 CD E4 E4 FE BB  -...............
  01B0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01C0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01D0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01E0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
  01F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
------[ SMBus Device B00-D52 ]------
------[ SMBus Device B00-D53 ]------
------[ Chips Found ]------
B00-D46: uPI uP????
On 1/12/2021 at 10:27 AM, Stefan Knaak said:
Hello,
thanks
Debug Infos:
Thank you for the data!  Make sure to upgrade to the latest beta version of AIDA64 Extreme available at:
Let me know how it works on your motherboard.
