el_guineo Posted January 25, 2021 Posted January 25, 2021 So on loading AIDA64 with Windows open, all my NIC8 gauges, bars, and data are invisible. If I close AIDA64 and reopen, then the NIC data appears correctly. I tried delaying the AIDA64 "open on windows boot" for 1-3 minutes to see if Windows needed to "catch up" registering Ethernet devices, but same problem persists. Any ideas? Quote
Fiery Posted January 27, 2021 Posted January 27, 2021 On 1/26/2021 at 12:00 AM, el_guineo said: So on loading AIDA64 with Windows open, all my NIC8 gauges, bars, and data are invisible. If I close AIDA64 and reopen, then the NIC data appears correctly. I tried delaying the AIDA64 "open on windows boot" for 1-3 minutes to see if Windows needed to "catch up" registering Ethernet devices, but same problem persists. Any ideas? What kind of NIC is your NIC8? Or maybe the list of the eight NIC's keep being extended (or shrunk) between AIDA64 sessions? Do you think you may have a dynamic network connection that may get removed and added to the list of network adapters? Quote
el_guineo Posted January 28, 2021 Author Posted January 28, 2021 A Realtek 2.5g adapter. Interesting note, that they may shrink or added. Meanwhile, I added a script to load / kill / reload AIDA64 in a span of 5 minutes and that solves it. But its a dirty hack. Any way to force AIDA64 to "refresh" the NIC list once in a while? Quote
el_guineo Posted January 28, 2021 Author Posted January 28, 2021 Just now, el_guineo said: A Realtek 2.5g adapter. Interesting note, that they may shrink or added. Meanwhile, I added a script to load / kill / reload AIDA64 in a span of 5 minutes and that solves it. But its a dirty hack. Any way to force AIDA64 to "refresh" the NIC list once in a while? How can I check if any of my NICs are dynamic? Quote
