Hey,
I got Intel Cryo Cooler running and I love it, I would love to have the data on Aida64 for all the obvious reasons.
I got a serial port monitor running on it and I see the data flow but I do not know how to interpolate it to the desired numbers - Ambient, Humidity, Cooler Temp, Dew point and Power draw.
Can I get and help here ?
Thanks
Elior
On 1/30/2021 at 5:22 PM, elior77 said:
Hey,
Thanks
Elior
AIDA64 currently doesn't support that device.  Is it branded Intel or some other vendor?  Is your device available for purchase on the 'bay or Amazon perhaps?
Intel® Cryo Cooling Technology is a unique combination of software, firmware, and hardware that powers advanced subambient coolers designed to maximize PC performance and overclocking.
Intel Cryo Cooling Technology can achieve temperatures below ambient (room temperature), so cold silicon can reach higher frequencies at lower voltages compared to warm silicon. This helps to reach higher overclocking frequencies unlike previous liquid cooling technologies.
The Intel® Cryo Cooling Technology hardware (liquid cooling solution) consists of the following elements, but it depends on partner/vendor implementation:
  • Pump
  • Radiator
  • Heatsink/Cooling block
  • Condensation controller (already installed on the cooling block)
  • 4 months later...
