Atila Posted February 6, 2021 Posted February 6, 2021 Hi !! Firts sorry for my english, if I start my 1024x600 panel sensor on my main screen (4k resolution) it resizes to 2304x1364 and even if I move it to the secondary screen it doesn't resize. I have to put the 1024x600 secondary screen as the main screen, after starting aida64 and now the panel is seen in 1024x600, then I put the 4k screen as the main screen again and the panel moves to the 4k screen in 1024x600 and now it is only to move it to the secondary screen active all the options of blocking size and position and it works perfect. Here if I deactivate the display of the sensor panel and I activate it again appears in secondary screen. The problem is that when I restart the computer it returns to the 4k screen with a resolution of 2304x1364 and I have to do the same process again, I don't know how to make it start on the secondary screen. Quote
Fiery Posted February 6, 2021 Posted February 6, 2021 6 minutes ago, Atila said: Hi !! Firts sorry for my english, if I start my 1024x600 panel sensor on my main screen (4k resolution) it resizes to 2100 and even if I move it to the secondary screen it doesn't resize. I have to put the 1024x600 secondary screen as the main screen, after starting aida64 and now the panel is seen in 1024x600, then I put the 4k screen as the main screen again and the panel moves to the 4k screen in 1024x600 and now it is only to move it to the secondary screen active all the options of blocking size and position and it works perfect. Here if I deactivate the display of the sensor panel and I activate it again appears in secondary screen. The problem is that when I restart the computer it returns to the 4k screen with a resolution of 2100 and I have to do the same process again, I don't know how to make it start on the secondary screen. For such multi-monitor issues usually the solution is to move the smaller screen to the left of the main screen in the Windows Settings. That way in case the main screen resolution changes, it won't affect the SensorPanel position. Quote
Atila Posted February 6, 2021 Author Posted February 6, 2021 17 minutes ago, Fiery said: For such multi-monitor issues usually the solution is to move the smaller screen to the left of the main screen in the Windows Settings. That way in case the main screen resolution changes, it won't affect the SensorPanel position. Thanks for answering. I have tried to put it to the left in various positions and it does not solve it. When I close and open aida the panel returns to the 4k screen at 2304x1364. If I open aida64 on the 1024x600 screen as the main one, it opens it well, but if I put the 4k screen as the main one, it opens it on the 4k screen and at 2304x1364 I have tried both the panel sensor and the osd panel and it is the same Quote
Atila Posted February 6, 2021 Author Posted February 6, 2021 It is a problem with the resolutions, when I put the two screens in 1024x600 resolution and leave the panel sensor on the secondary screen ... I restart the computer and the panel remains on the secondary screen. But when I change the resolution of my main screen to 4k the panel returns to the main screen in 2304x1364. Another way for it to stay on the secondary screen is to change the resolution of the panel to 1024x600 but it is cut off, the only way for the panel to appear full is to change the resolution of windows to 1024x600 Automatic resolution when I import the panel Panel cut off when I change resolution to 1024x600 on my main 4k screen Is there a way to import my sensor panel and not rescale it? Quote
Largeone299us Posted April 4, 2021 Posted April 4, 2021 I have the same issue going on. The sensor panel always jumps to the 4k screen and scales and will not retain its true numbers when I send it to the small screen. It also automatically puts it in the upper corner of the main screen every time i restart aida 64. Quote
Youss Posted January 14, 2022 Posted January 14, 2022 here is the solution go to aida64.exe > properties > compatibility > change high DPI settings > activate "Override high DPI Scaling behavior" to Systems hope this helped Quote
Omnius Posted January 15, 2022 Posted January 15, 2022 If anyone in this thread is still having this problem, I have written a piece of software that solves the problem for me. It allows you to designate a monitor and it will make sure the sensor panel sticks to that monitor even if you move it around or if your monitor configuration changes (like turning off a monitor, etc.). See this thread: Quote
ColloquialCapt Posted Tuesday at 09:58 PM Posted Tuesday at 09:58 PM This is a super old topic, but I found a fix that I thought I'd share. I also had a problem with the resolution shifting when I would move the sensor panel back to the correct monitor once it started in the wrong spot. Edit the aida64.ini file. For me it was located here: "C:\Program Files (x86)\FinalWire\AIDA64 Extreme"\aida64.ini". You can right click on it and edit with notepad. I had to add the appropriate sections and entries, as the didn't exist. Add the following in its own section (you need to adjust the resolution and monitor for your specific setup). [HardwareMonitoring] HWMonEnable=1 HWMonEnableSensorPanel=1 SensorPanelMonitor=5 SensorPanelWidth=515 SensorPanelHeight=1920 Here's where I put mine in relation to other sections, but the location shouldn't matter: [RptLook] ReportTheme=Auto NFName=Verdana NFSize=80 NFColor=0 NFBold=0 NFItalic=0 PCFName=Verdana PCFSize=140 PCFColor=8388608 PCFBold=1 PCFItalic=0 DCFName=Verdana DCFSize=110 DCFColor=8388608 DCFBold=1 DCFItalic=0 BGColor=16777215 [HardwareMonitoring] HWMonEnable=1 HWMonEnableSensorPanel=1 SensorPanelMonitor=5 SensorPanelWidth=515 SensorPanelHeight=1920 [Sum] group_computer=1 computertype=1 Quote
