HeMan91 Posted February 11, 2021 Posted February 11, 2021 Hello, I recently updated to the BETA release because AIDA64 read my RTX3090 temperature about 2 degrees higher than actual. The BETA fixed that issue but introduced a new bug, my PWM fan speed is now incorrect and approximately 20% less than actual. MSI Afterburner and GPU-z will correctly display 50% while AIDA will display 29-30%. Thanks! Quote
Fiery Posted February 12, 2021 Posted February 12, 2021 On 2/11/2021 at 6:28 AM, HeMan91 said: Hello, I recently updated to the BETA release because AIDA64 read my RTX3090 temperature about 2 degrees higher than actual. The BETA fixed that issue but introduced a new bug, my PWM fan speed is now incorrect and approximately 20% less than actual. MSI Afterburner and GPU-z will correctly display 50% while AIDA will display 29-30%. Thanks! Please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
HeMan91 Posted February 14, 2021 Author Posted February 14, 2021 As requested. nvidiagpureg.txt Quote
Fiery Posted March 3, 2021 Posted March 3, 2021 On 2/14/2021 at 4:16 PM, HeMan91 said: As requested. nvidiagpureg.txt 23.12 kB · 1 download Thank you! Please also post an nVIDIA SMBus Dump. Quote
HeMan91 Posted March 22, 2021 Author Posted March 22, 2021 On 3/3/2021 at 4:40 AM, Fiery said: Thank you! Please also post an nVIDIA SMBus Dump. My apologies for not seeing this sooner. Here's the file. nvidiasmbusdump.txt Quote
BAG Posted March 22, 2021 Posted March 22, 2021 AIDA64 is correct! To be more precise: MSI Afterburner and GPU-Z are wrong (on the percent, but have the correct RPM). Precision X1 and AIDA64 (6.32.5650 Beta) are correct. See attached image. img20210322165105.bmp Quote
Fiery Posted March 27, 2021 Posted March 27, 2021 On 3/22/2021 at 6:25 AM, HeMan91 said: My apologies for not seeing this sooner. Here's the file. Thank you! Can you please check if @BAG's observation applies to your system too. Check if Precision X1 agrees with GPU-Z or AIDA64. Also, make sure to use the latest AIDA64 beta build available for download at: https://www.aida64.com/downloads/latesta64xebeta Quote
HeMan91 Posted March 27, 2021 Author Posted March 27, 2021 1 hour ago, Fiery said: Thank you! Can you please check if @BAG's observation applies to your system too. Check if Precision X1 agrees with GPU-Z or AIDA64. Also, make sure to use the latest AIDA64 beta build available for download at: https://www.aida64.com/downloads/latesta64xebeta Hello, I updated to the latest version and still experience the same problem. To reiterate, this PWM problem started with the BETA version that fixed the GPU temperature. I don't use Precision X1 but here's a similar screenshot. Quote
Fiery Posted April 6, 2021 Posted April 6, 2021 On 3/27/2021 at 5:54 PM, HeMan91 said: Hello, I updated to the latest version and still experience the same problem. To reiterate, this PWM problem started with the BETA version that fixed the GPU temperature. I don't use Precision X1 but here's a similar screenshot. When it's an EVGA video card, I'd trust Precision X1 over 3rd party software. So it'd be important to verify what PWM setting is indicated by Precision X1. Quote
HeMan91 Posted May 18, 2021 Author Posted May 18, 2021 On 4/6/2021 at 7:23 AM, Fiery said: When it's an EVGA video card, I'd trust Precision X1 over 3rd party software. So it'd be important to verify what PWM setting is indicated by Precision X1. I can't use Precision X1 without risking it automatically installing an incorrect firmware on my GPU. All I know is that PWM monitoring used to work fine in AIDA64 UNTIL that update. Quote
