Hi there,
I am having a problem getting the Hard Disk temperatures to display with Aida64.
I have ST380817AS Segate Barracuda
The report reads as follows:
Temperatures:
Motherboard: 46°C
GPU Diode: 57°C
CPU: 48°C
CPU Fan: 5114 RPM
Chipset Fan: 5625 RPM
CPU Core: 1.392V
+3.3V: 3.328V
+5V: 5.080V
12V: 12.096V
Although on HW Monitor Can Read Hard Drive Temperature
But for some reason I cannot find any setting which allows me to add the Hard Drive Temperature Sensor List.
Thanks For Your Help
Chris
Please try to enable the option RAID SMART support in AIDA64 / main menu / File / Preferences / Stability, and restart AIDA64 to apply the changes.
Let me know if it helps. If not, then please let us know more about your system configuration, e.g. motherboard model, IDE or AHCI or RAID mode selected for your SATA controller, any RAID arrays defined, AIDA64 version?
Please sign in to comment
Sign In Now
