Motherboard sensor reading stuck (ASRock 990FX Professional)
The temp reading for the motherboard is stuck at 30c. I have uninstalled/reinstalled but the problem persists. Even with the aircon set to 18c this reading doesn't move.
Here's the de-bug info if that helps:
Sensor Properties
Sensor Type Nuvoton NCT6776F (ISA 290h)
GPU Sensor Type Diode, Volterra VT1556 (ATI-Diode, 70h)
Motherboard Name ASRock 990FX Professional
Chassis Intrusion Detected Yes
Temperatures
Motherboard 30 °C (86 °F)
CPU 23 °C (73 °F)
CPU #1 / Core #1 16 °C (61 °F)
CPU #1 / Core #2 16 °C (61 °F)
CPU #1 / Core #3 16 °C (61 °F)
CPU #1 / Core #4 16 °C (61 °F)
CPU #1 / Core #5 16 °C (61 °F)
CPU #1 / Core #6 16 °C (61 °F)
CPU #1 / Core #7 16 °C (61 °F)
CPU #1 / Core #8 16 °C (61 °F)
GPU Diode (DispIO) 34 °C (93 °F)
GPU Diode (MemIO) 36 °C (97 °F)
GPU Diode (Shader) 38 °C (100 °F)
GPU VRM 24 °C (75 °F)
SAMSUNG HD103SI 16 °C (61 °F)
WDC WD2002FAEX-007BA0 27 °C (81 °F)
WDC WD10EADS-00M2B0 39 °C (102 °F)
Cooling Fans
Chassis #1 1478 RPM
Chassis #2 2770 RPM
GPU 2332 RPM (41%)
Voltage Values
CPU Core 1.120 V
+3.3 V 3.216 V
+5 V 4.944 V
+12 V 11.827 V
+5 V Standby 5.236 V
GPU VRM 1.175 V
Motherboard ID : 63-0100-000001-00101111-050311-Chipset$0AAAA000_BIOS DATE: 11/17/11 20:34:00 VER: 04.06.04
Motherboard Model : ASRock 990FX Professional
Motherboard Chipset : AMD 990FX, AMD K15
DMI MB Manufacturer : ASRock
DMI MB Product : 990FX Professional
DMI MB Version :
DMI MB Serial :
DMI SYS Manufacturer: To Be Filled By O.E.M.
DMI SYS Product : To Be Filled By O.E.M.
DMI SYS Version : To Be Filled By O.E.M.
DMI SYS Serial : To Be Filled By O.E.M.
DMI BIOS Version : P1.50
ITE 87xx Port = 00h
ITE 87xx Device ID = 0000h
ITE 87xx Version = 00h
Winbond SuperIO Port = 2Eh
Winbond SuperIO HWMonitor Port = 0290h
Winbond SuperIO Device ID = C333h
Winbond Sensor ID A3/5C/reg$58 = A3 / 5C / C1
Fintek SuperIO Port = 00h
Fintek SuperIO Device ID = 0000h
LPC47 SuperIO Device ID = FFFFh
------[ Nuvoton ISA Sensor Device at 0290 / Bank #0 ]------
0000 04 FF 04 FF 00 FF FF FF FF FF FF FF FF FF FF FF
0010 04 FF 00 00 00 00 FF FF 40 00 00 00 00 01 00 00
0020 6F E0 CA CA B2 CE 57 1E FF FF FF DA 00 00 00 00
0030 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
0040 03 00 10 FF FF 00 3F FF 2D FF FF FF 18 05 06 A3
0050 FF FF FF FF FF FF FF FF C1 FF FF FF FF 00 00 FF
0060 CF FF FF FF FF 01 00 FF FF FF FF FF FF FF FF FF
0070 00 0A 00 1E 00 18 00 01 80 FF FF FF FF FF FF FF
0080 FF 03 1F 0F FF 3C 3C 3C 00 00 00 00 00 00 00 00
0090 0A 00 00 00 00 0A 0A 0A 0A AA EF 80 FF 40 46 C4
00A0 0E 01 00 00 FF 00 00 FF 00 00 80 66 66 06 00 01
00B0 00 00 00 00 00 00 28 00 1C 00 00 00 B4 80 C4 FF
00C0 01 00 00 00 00 00 00 00 00 1E 02 FF FF FF FF FF
00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
Reg$20 CPU Core: r = 111, r*0.016 = 1.78
Reg$21 CPU Aux: r = 224, r*0.016 = 3.58
Reg$22 +3.3 V: r = 202, r*0.016 = 3.23
Reg$23 +5 V: r = 202, r*0.016 = 3.23
Reg$24 +12 V: r = 178, r*0.016 = 2.85
Reg$25 -12 V: r = 206, r*0.016 = 3.30
Reg$26 -5 V: r = 87, r*0.016 = 1.39
------[ Nuvoton ISA Sensor Device at 0290 / Bank #1 ]------
0000 01 00 00 0A 0A 01 01 3C FF FF FF FF 00 FF FF FF
0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0020 00 19 23 2D 37 FF FF 8C AA C8 E6 FF FF FF FF FF
0030 FF 00 FF FF 00 7F FF FF 00 01 00 00 00 00 00 00
0040 FF FF FF FF FF BE 05 FF FF FF FF FF FF FF 06 FF
0050 18 00 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0080 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #2 ]------
0000 02 32 02 0A 0A 01 01 3C FF FF FF FF 00 FF FF FF
0020 00 28 32 3C 46 FF FF 8C AA C8 E6 FF FF FF FF FF
0040 FF FF FF FF FF 36 06 FF FF FF FF FF FF FF 06 FF
0050 01 80 00 4B 00 50 00 FF FF FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #3 ]------
0000 03 00 00 0A 0A 01 01 3C FF FF FF FF 00 FF FF FF
0030 FF 00 FF FF 00 3C FF FF 00 01 00 00 00 00 00 00
0040 FF FF FF FF FF A4 00 FF FF FF FF FF FF FF 06 FF
0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #4 ]------
0000 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0010 00 00 00 00 00 00 00 00 00 00 00 FF FF FF FF FF
0020 FF FF FF 96 64 96 64 E1 96 FF FF FF FF FF FF FF
0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0040 3F 00 03 FF FF FF FF FF FF FF FF FF FF FF 06 FF
0050 00 13 FF FF 00 00 00 FF 00 5E 1F B1 09 FF FF FF
0060 FF 01 00 00 00 00 00 00 FF FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #5 ]------
0000 FF FF 00 00 00 00 FF FF FF FF FF FF FF 00 00 FF
0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 06 FF
0050 D8 00 00 FF 00 00 00 00 FF FF FF FF FF FF FF FF
0060 00 00 00 00 00 00 07 00 01 FF FF FF FF FF FF FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #6 ]------
0000 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0020 FF 01 02 03 01 01 01 FF 00 00 00 1E 1E 1E 00 FF
0030 1C 16 1A 11 FF 1F FF 1F FF 1F 00 00 80 00 00 00
0040 00 00 00 00 02 02 02 FF FF FF FF FF FF FF 06 FF
0050 7F 7F 7F 7F 7F 7F 05 BE 06 36 00 A4 00 A4 00 A4
0070 7F 7F 50 4B 04 7F 7F 50 4B 04 7F 7F 50 4B 04 FF
------[ Nuvoton ISA Sensor Device at 0290 / Bank #7 ]------
0000 FF 10 02 00 00 00 00 00 00 00 00 00 00 00 00 00
0010 00 00 00 00 00 00 00 F8 80 F8 80 F8 80 F8 80 00
0020 28 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
0030 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF
0027 0150 0250 007D 007E 062B 062C 062D 0720
T: 30 23 1 255 255 30 30 30 40
T: 30 24 1 255 255 30 30 30 40
------[ SB7xx/8xx/9xx PM2 at 0CD0 ]------
0000 06 1E F7 FF BF 05 00 00 00 00 00 00 00 00 FF FF
0010 06 1E F7 FF BF 05 00 00 00 00 00 00 00 00 FF FF
0020 06 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF
0030 06 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF
0040 06 00 00 00 00 00 00 00 00 00 00 00 00 00 FF FF
0060 1F 00 00 00 00 00 01 00 00 F6 00 01 00 00 FF FF
0070 01 00 00 FF FF 01 00 00 FF FF 01 00 00 FF FF FF
0090 1F 55 01 00 00 C0 97 00 00 00 00 00 00 00 00 00
00A0 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF
00B0 FF FF 55 55 FF 00 00 FF C0 FF 00 00 C0 FF 00 00
00C0 C0 FF 00 00 C0 FF 00 00 C0 FF 00 00 C0 FF 00 00
00D0 C0 FF 00 00 C0 FF 00 00 FF FF FF FF FF FF FF FF
00E0 03 00 00 00 00 00 02 00 00 FF 96 1F 01 00 00 02
00F0 19 0A 02 05 C8 20 80 00 05 06 00 00 08 08 00 42
Reg$59VIN0: r = $FFFF, r*0.000046 = 3.0146
Reg$5DVIN1: r = $FFFF, r*0.000046 = 3.0146
Reg$61VIN2: r = $0000, r*0.000046 = 0.0000
Reg$65VIN3: r = $0100, r*0.000046 = 0.0118
Reg$69VIN4: r = $00F6, r*0.000046 = 0.0113
Reg$6DVIN5: r = $FF00, r*0.000046 = 3.0029
Reg$71VIN6: r = $0000, r*0.000046 = 0.0000
Reg$75VIN7: r = $0001, r*0.000046 = 0.0000
------[ SB7xx/8xx/9xx PM at 0CD6 ]------
0000 0E 00 4F 4A 00 04 00 02 34 05 04 02 06 21 43 55
0010 FF 0F 00 00 FF 0F 00 00 00 00 00 00 00 00 00 00
0020 00 00 D1 FE 01 00 D8 FE 25 0B 00 00 01 0B 00 00
0030 00 00 00 00 07 00 C0 FE 00 00 00 00 00 00 00 00
0040 00 00 00 00 00 00 00 80 F1 00 C0 FE 03 00 00 00
0050 03 00 D0 FE 90 00 00 97 01 FF 15 66 00 05 00 01
0060 00 08 04 08 08 08 10 08 20 08 B2 00 00 FE BA 00
0070 00 00 00 00 17 00 00 04 FF FF 00 00 85 01 E0 A0
0080 1F 1A 00 20 00 00 00 00 30 10 00 00 9E 00 80 00
0090 02 05 02 0B 01 00 10 00 00 10 00 10 00 00 00 00
00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00B0 00 00 00 00 00 0B 05 05 08 00 08 40 02 00 53 00
00C0 F9 0B 58 40 3C 02 00 00 0C 40 28 00 FF FF FF FF
00D0 00 00 30 00 00 00 00 00 15 00 91 00 01 00 10 03
00E0 D8 0C 00 00 00 00 00 02 00 00 00 01 03 12 00 7F
00F0 9C 03 00 00 00 00 01 21 6C 27 00 00 00 00 00 00
_TZ_.THM0._TMP :
_TZ_.THM1._TMP :
_TZ_.THR0._TMP :
_TZ_.THR1._TMP :
_TZ_.TZ00._TMP :
_TZ_.TZ01._TMP :
_TZ_.RTMP :
_TZ_.RFAN :
_TZ_.RFAN(0) :
_TZ_.RFAN(1) :
_SB_.ATKD._HID :
_SB_.ATKD.TMPR :
_SB_.PCI0.LPC0.EC0_.CCTV :
_SB_.PCI0.LPC0.EC0_.LRPM :
_SB_.PCI0.LPC0.EC0_.HRPM :
_SB_.PCI0.SBRG.EC0_.ECPU :
_SB_.PCI0.SBRG.EC0_.TACH(0):
_SB_.PCI0.SBRG.EC0_.TACH(1):
_SB_.PCI0.SBRG.EC0_.TAH0 :
_SB_.PCI0.SBRG.EC0_.TAH1 :
_SB_.PCI0.SBRG.EC0_.ST00 :
_SB_.PCI0.SBRG.EC0_.SC01 :
_SB_.PCI0.SBRG.EC0_.SC02 :
_SB_.PCI0.SBRG.EC0_.SC03 :
_SB_.PCI0.SBRG.EC0_.SC04 :
_SB_.PCI0.SBRG.EC0_.SC05 :
_SB_.PCI0.SBRG.EC0_.SC06 :
_SB_.PCI0.PIB_.EC0_.TCRT :
_SB_.PCI0.SBRG.EC0_.CTPM :
_SB_.PCI0.SBRG.EC__.CPUT :
_SB_.PCI0.SBRG.EC__.SYST :
_SB_.PCI0.LPC_.EC0_.CTMP :
_SB_.PCI0.LPCB.EC0_.CTMP :
_SB_.PCI0.LPC_.EC0_.TMP1 :
_SB_.PCI0.LPC_.EC0_.TMP2 :
_SB_.PCI0.LPC_.EC0_.TMPI :
_SB_.PCI0.LPC_.EC0_.TMPV :
_SB_.PCI0.LPCB.EC0_.A1TP :
_SB_.PCI0.LPCB.EC0_.A2TP :
_SB_.PCI0.LPCB.EC0_.FAN0 :
_SB_.PCI0.LPCB.EC__.TS1R :
_SB_.PCI0.LPCB.EC__.TS2R :
_SB_.PCI0.LPCB.EC__.TS3R :
_SB_.PCI0.LPCB.EC__.F1FL :
_SB_.PCI0.LPCB.EC__.F1FH :
_SB_.PCI0.LPCB.EC__.F2FL :
_SB_.PCI0.LPCB.EC__.F2FH :
_SB_.PCI0.LPC_.H8EC.RTMP :
_SB_.PCI0.LPC_.H8EC.LTMP :
_SB_.PCI0.LPC_.H8EC.MTMP :
_SB_.PCI0.LPC_.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.CTMP :
_SB_.PCI0.LPCB.H8EC.DTMP :
_SB_.PCI0.LPCB.H8EC.GTMP :
_SB_.PCI0.LPCB.H8EC.ITMP :
_SB_.PCI0.LPCB.H8EC.MTMP :
_SB_.PCI0.LPCB.H8EC.STMP :
_SB_.PCI0.LPCB.H8EC.PFAN :
------[ SMBus #0 ]------
SMBus Type : Intel / VIA / ServerWorks / SMSC / ATI
SMBus Port : 0B00
Can Have SPD: Yes
Scan Type : Full
------[ SMBus Device B00-D2B ]------
0000 25 99 A6 5D DA 59 08 30 10 03 2F C8 28 A4 AC 0A %..].Y.0../.(...
0010 A0 0D 99 07 40 00 00 00 00 ED A0 34 10 00 E8 E1 ....@......4....
0020 6D 5B A2 62 35 64 00 00 71 72 26 AE CE 22 9B 22 m[.b5d..qr&.."."
0030 44 57 87 00 89 00 38 10 43 30 18 00 00 12 55 02 DW....8.C0....U.
0040 06 06 00 00 41 40 3F 40 40 42 41 42 E1 C3 C4 82 ....A@?@@BAB....
0050 D9 82 D9 82 D9 8E 02 E4 D8 4E D0 F4 BA F4 BA E3 .........N......
0060 F0 27 F0 32 1A 00 02 80 00 02 80 FF 7F 00 00 00 .'.2...........
0070 00 03 00 03 55 68 EB EB 00 00 B0 46 3E 00 00 8B ....Uh.....F>...
0080 EA AC D3 83 EA 99 D3 FA B9 FB B9 64 0D 00 03 FE ...........d....
0090 04 07 00 00 C0 00 00 88 00 00 19 10 1F AD 50 00 ..............P.
00A0 00 00 00 00 00 00 00 00 00 03 00 00 03 FF 9F 00 ................
00B0 00 00 0F 00 00 00 00 FF FF 88 88 01 0A 0A FF 88 ................
00C0 01 01 01 00 00 C0 00 00 00 00 00 00 00 00 00 80 ................
00D0 00 00 00 00 80 33 00 00 08 00 01 00 00 00 00 00 .....3..........
00E0 00 00 00 15 15 00 00 00 00 00 00 00 00 00 00 00 ................
0000 2525 9999 A6A6 5D5D DADA 5959 0808 3030 1010 0303 2F2F C8C8 2828 A4A4 ACAC 0A0A
0010 A0A0 0D0D 9999 0707 4040 0000 0000 0000 0000 EDED A0A0 3434 1010 0000 E8E8 E1E1
0020 6D6D 5B5B A2A2 6262 3535 6464 0000 0000 7171 7272 2626 AEAE CECE 2222 9B9B 2222
0030 4444 5757 8787 0000 8989 0000 3838 1010 4343 3030 1818 0000 0000 1212 5555 0202
0040 0606 0606 0000 0000 4141 4141 4040 4141 3E3E 3E3E 4141 4242 E1E1 C3C3 C4C4 8282
0050 D9D9 8282 D9D9 8282 D9D9 8D8D 0202 C9C9 D8D8 4D4D D0D0 F4F4 BABA F4F4 BABA CBCB
0060 F0F0 2626 F0F0 3232 1A1A 0000 0202 8080 0000 0202 8080 FFFF 7F7F 0000 0000 0000
0070 0000 0303 0000 0303 5555 A8A8 EBEB EBEB 0000 0000 B0B0 4141 3C3C 0000 0000 5E5E
0080 EAEA 9494 D3D3 5454 EAEA 8181 D3D3 FCFC B9B9 F5F5 B9B9 6464 0D0D 0000 0303 F8F8
0090 0202 0707 0000 0000 C0C0 0000 0000 8888 0000 0000 1919 1010 1F1F ADAD 5050 0000
00A0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0303 0000 0000 0303 FFFF 9F9F 0000
00B0 0000 0000 0F0F 0000 0000 0000 0000 FFFF FFFF 8888 8888 0101 0A0A 0A0A FFFF 8888
00C0 0101 0101 0101 0000 0000 C0C0 0000 0000 0000 0000 0000 0000 0000 0000 0000 8080
00D0 0000 0000 0000 0000 8080 3333 0000 0000 0808 0000 0101 0000 0000 0000 0000 0000
00E0 0000 0000 0000 1515 1515 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
00F0 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
------[ SMBus Device B00-D35 ]------
0000 5F 1C 17 2C 00 17 2C 00 FF FF FF FF FF FF FF FF _..,..,.........
0010 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0020 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0030 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0040 FF 1C 17 2C 00 17 2C 00 FF FF FF FF FF FF FF FF ...,..,.........
0050 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0060 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0070 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0080 FF 1C 17 2C 00 17 2C 00 FF FF FF FF FF FF FF FF ...,..,.........
0090 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00A0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00B0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00C0 FF 1C 17 2C 00 17 2C 00 FF FF FF FF FF FF FF FF ...,..,.........
00D0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00E0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00F0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0000 1C5F 171C 2C17 002C FF00 FF17 FF2C FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0020 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0030 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0040 1CFF 171C 2C17 002C FF00 FF17 FF2C FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0050 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0060 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0080 1CFF 171C 2C17 002C FF00 FF17 FF2C FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00A0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00B0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00C0 1CFF 171C 2C17 002C FF00 FF17 FF2C FF00 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00D0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00E0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00F0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
------[ SMBus Device B00-D43 ]------
0000 FF 88 FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0010 FF FF FF FF FF FF FF FF FF B0 FF FF FF FF FF FF ................
0020 15 FF FF FF FF 00 00 FF FF FF FF FF FF FF FF FF ................
0040 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
0070 FF FF FF FF FF FF FF FF 02 02 FF FF FF 00 80 FF ................
0080 00 FF FF FF FF FF FF FF 82 D1 FF D0 D2 32 1A FF .............2..
0090 FF FF FF FF FF FF 6C 73 12 FF 01 01 FF FF FF FF ......ls........
00C0 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ................
00D0 FF FF FF FF 00 FF 80 F7 00 00 00 00 FF FF FF FF ................
0000 FFFF 4288 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 19B0 FFFF FFFF FFFF FFFF FFFF FFFF
0020 B015 FFFF FFFF FFFF FFFF 0000 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0040 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF A002 0002 FFFF FFFF FFFF 6E00 5A80 FFFF
0080 9300 FFFF FFFF FFFF FFFF FFFF FFFF FFFF D982 D8CA FFFF 0BD0 F0CC 0032 001A FFFF
0090 FFFF FFFF FFFF FFFF FFFF FFFF EA60 EA64 1E12 FFFF 0D01 0701 FFFF FFFF FFFF FFFF
00C0 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
00D0 FFFF FFFF FFFF FFFF 1C00 FFFF 4380 B9FA 0000 8D00 3000 5B00 FFFF FFFF FFFF FFFF
0080 00 FF FF FF FF FF FF FF 82 4C FF D0 26 1A 32 FF .........L..&.2.
0090 FF FF FF FF FF FF 81 94 12 FF 01 01 FF FF FF FF ................
00D0 FF FF FF FF 00 FF 80 F5 00 00 00 00 FF FF FF FF ................
0000 FFFF 5088 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0010 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF 0BB0 FFFF FFFF FFFF FFFF FFFF FFFF
0020 A215 FFFF FFFF FFFF FFFF 0000 0000 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF
0070 FFFF FFFF FFFF FFFF FFFF FFFF FFFF FFFF B202 0002 FFFF FFFF FFFF 7C00 4880 FFFF
0080 8100 FFFF FFFF FFFF FFFF FFFF FFFF FFFF D982 D04C FFFF 0BD0 F026 001A 0032 FFFF
0090 FFFF FFFF FFFF FFFF FFFF FFFF FFFF D3A0 0C12 FFFF 0D01 0701 FFFF FFFF FFFF FFFF
00D0 FFFF FFFF FFFF FFFF 0E00 FFFF 5180 B9EE 0000 9F00 2200 4900 FFFF FFFF FFFF FFFF
------[ SMBus Device B00-D50 ]------
0000 92 10 0B 02 03 19 00 09 03 52 01 08 0C 00 3C 00 .........R....<.
0010 69 78 69 30 69 11 20 8C 00 05 3C 3C 00 F0 83 0D ixi0i. ...<<....
0020 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0030 00 00 00 00 00 00 00 00 00 00 00 00 0F 11 01 01 ................
0040 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0050 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0060 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
0070 00 00 00 00 00 04 CD 00 00 00 00 00 00 00 F3 DD ................
0080 46 33 2D 31 36 30 30 30 43 4C 39 2D 34 47 42 52 F3-16000CL9-4GBR
0090 4D 00 00 00 04 CD 00 00 00 00 00 00 00 00 00 00 M...............
00A0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ................
00B0 0C 4A 01 12 01 0A 00 00 00 2C 0A 59 20 00 59 59 .J.......,.Y .YY
00C0 63 78 11 17 88 3E 00 13 05 3C 30 11 F0 3C 00 00 cx...>...<0..<..
00D0 13 00 26 00 00 00 00 00 00 00 00 00 00 00 00 00 ..&.............
------[ Chips Found ]------
B00-D2B: CHiL CHL8326
B00-D35: uPI uP6262
B00-D51: SPD
Any help would be greatly appreciated.
Is the motherboard temperature stuck in ASRock's own monitoring application (F-Stream) as well? If you try that application, then please let us know what version of it do you have installed.
I don't think the motherboard temperature reading is stuck. In this dump you have 30 Celsius, while in your other topic the motherboard temperature is 32 Celsius. Hence it does change.
Make sure to compare AIDA64 sensor readings against ASRock F-Stream readings. If you see a discrepancy there, please post a screen shot that shows AIDA64 Sensor page and F-Stream readings next to each other (side-by-side), so we can compare the values.
Please sign in to comment
Sign In Now
