I have found just about everything I want to display on the sensor panel but a few things. The fans and pump coolant temperature connected to the Corsair iCUE H150i Elite Capellix (Commander CORE) which I know Aida is working on adding. Then these....
I can see the northbridge, southbridge, and memory voltages in the main Aidia64 window but none of these show up in the sensor panel to be displayed. I would at least like to add NB and memory voltages if possible. Is there something I need to tick or enable to get these to be able to be added to the sensor panel? Thanks.
Can you see those voltages listed on the Computer / Sensor page of AIDA64?  If yes, then they should be available for the SensorPanel too...
Thanks Fiery for the reply. Thanks for all you do around here too. I very much appreciate all the hard work you do around here. So many of us would be lost and in a mess if it wasn't for you tending to us all.
Nope, it's not there. Its under Motherboard / Chipset page. So I guess there is no way of getting them to display on the Sensor panel correct?
Also Fiery, you wouldn't have a ETA on the Corsair iCUE H150i Elite Capellix (Commander CORE) would you? I think I seen in another post y'all had one on order and was awaiting it to arrive so as y'all could maybe see about adding it to our sensor panels correct?
Thank you for your kind words.  What is listed on the Chipset page are the nominal values for the hardware, and not measured values.  They cannot be shown on the SensorPanel.
Our Capellix device has arrived, and we're already working on it.  Give us a few more days to have something to try ;)
I'm afraid the Capellix is a hard nut to crack.  We've tried a number of ways to try and communicate with the device, but so far we haven't found a way to interrogate it in a way to make it return the fans+pump RPM as well as the thermal reading.  We'll keep researching it, but at this time I cannot promise any timeline about this issue :(
