Hello everyone
i am wondering if there is a way to have the max value for a sensor display in the sensor panel and stay there until the computer is restart.
thank you
  On 3/7/2021 at 3:12 AM, ViLRuX said:
Hello everyone
thank you
Expand
It's not possible for the SensorPanel, but you can have that data either logged into a HTML or CSV log file (AIDA64 / main menu / File / Preferences / Hardware Monitoring / Logging), or track it using the Statistics tab of the AIDA64 System Stability Test (AIDA64 / main menu / Tools / System Stability Test).
