Junchan Posted April 16, 2021 Posted April 16, 2021 Hi! just newbie here, i just started using aida64 and i'm just wondering if it is possible to show the water temperature in sensor panel? thanks in advance. Quote
Mice007 Posted April 16, 2021 Posted April 16, 2021 It is possible if you have a temp sensor / pump that is supported by AIDA64. Can you see the temperature info in Computer / Sensor page? Quote
