Enzaki Posted May 1, 2021 Posted May 1, 2021 hi aida i have this Corsair H115i Platinum but its disconnect and then its Connect again i have add corsairlinkdump anyway as it disconnect all light and fan speed info stops for 2 to 5 sec and then it Connect again is there any fix for that happen like 2 till 10 times a day and i use aida64 V6.33.5700 bg enzaki corsairlinkdump.txt Quote
Gutemine Posted May 1, 2021 Posted May 1, 2021 Hallo, hatte das gleich Problem. Hab den Hacken in der Einstellungen-Corsair Hydro-Platin-Sensor deaktiviert. Kann aber nicht die Lösung sein. Gruß Alex Quote
Enzaki Posted May 4, 2021 Author Posted May 4, 2021 @Fiery sry to poke you like this but is there any info you need to help fix this problem that i can send to you plz let me konw bg enzaki (: Quote
