Hello, I try to isolate the component of my pc which is faulty and used the Benchmark Stability Test.
So far I do not overclock and I exchanged my PSU already.
First issues I noticed were that sometimes my external audio interface and W-Lan-Adapter disconnected out of the sudden.
I bought new ones problem was solved.
After a some time my games crashed, some after 20 minutes other sessions after hours.
Drivers are all up to date.
The results of my Benchmarks are as follow:
1. Stress CPU                     = Passed
2. Stress FPU                     = Crashes after ~2-5 min.
3. Stress cache                  = Crashes reliably after ~20 seconds
4. Stress system memory = Passed
5. Stress local disks          = Passed
6. Stress GPU                    = Passed
Do you have a clue how i can make sure my motherboard might be the culprit?
Regards Boris
Regards Boris
Expand
It could be a number of issues, e.g. motherboard failure, PSU failure, weak PSU, etc.  It's hard to tell, so you may want to take your PC to a local specialist and have it checked out.
