Tank Posted May 30, 2012 Posted May 30, 2012 I created my own sensor panel for my laptop, including Network Speed for LAN & Wlan. Unfortunately some time ago both bars stopped working - it seems like the numbering of the NIC adapters have changed somehow. I was able to repair the LAN sensor, but for my WLAN none of the NICs in the list work. any advice ? regards, t. Quote
Fiery Posted May 30, 2012 Posted May 30, 2012 How many network adapters do you have? You can check them on the Network / Windows Network page. Is the WLAN adapter among those network adapters? How many network adapters are listed among the hardware monitor items? For example: NIC1 Download Rate, NIC2 Download Rate -- means 2 adapters detected by the hardware monitor module. Thanks, Fiery Quote
Tank Posted May 30, 2012 Author Posted May 30, 2012 How many network adapters do you have? You can check them on the Network / Windows Network page. Is the WLAN adapter among those network adapters? How many network adapters are listed among the hardware monitor items? For example: NIC1 Download Rate, NIC2 Download Rate -- means 2 adapters detected by the hardware monitor module. Quote
Fiery Posted May 30, 2012 Posted May 30, 2012 Can you please check how many subpages of the Windows Network page do the "Bytes empfangen" and "Bytes gesendet" lines appear properly? Does it match the 4 NIC items on the OSD items page? Quote
Tank Posted June 1, 2012 Author Posted June 1, 2012 All 6 entries have this lines. Intel® Centrino® Advanced-N 6230 = correct WLAN traffic. Realtek PCIe GBE Family Controller = correct LAN traffic. The others are showing zeros with normal computer use (I need the juniper VPN only very occasional) Quote
Fiery Posted June 1, 2012 Posted June 1, 2012 Thank you for the info. We've tested it with 6 network adapters in a single system, and found no errors. Are you sure NIC5 and NIC6 items are not there among the OSD Items in the Preferences? Please try to scroll up and down in the list, and try finding them. Quote
Tank Posted June 3, 2012 Author Posted June 3, 2012 tried it, unfortunately there is no nic#5 + #6 Quote
Fiery Posted June 11, 2012 Posted June 11, 2012 Please upgrade to the latest beta version of AIDA64 Extreme Edition available at: http://www.aida64.com/downloads/aida64extremebuild2013jdgxb3fcslzip After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. Make sure to scroll down to the very bottom of the OSD Items list to try finding the previously missing items for NIC#5 and NIC#6. Quote
