User123 Posted July 24, 2021 Posted July 24, 2021 Hi, I bought a new motherboard Gigabyte Z590 UD AC but now the chassis fan speeds are missing. It shows CPU und GPU, but I'd love to see the system fans as well. Could you please update? Sensor dump file attached. Thank you. isasensordump.txt Quote
Fiery Posted July 25, 2021 Posted July 25, 2021 8 hours ago, User123 said: Hi, I bought a new motherboard Gigabyte Z590 UD AC but now the chassis fan speeds are missing. It shows CPU und GPU, but I'd love to see the system fans as well. Could you please update? Sensor dump file attached. Thank you Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. Let me know if it helps. If not, then please post a screenshot of the Computer / Sensor page of AIDA64 to let us check the currently measured fan headers and their labels. Quote
User123 Posted July 31, 2021 Author Posted July 31, 2021 I tried this already, but latest Beta does not help. The chassis fans are missing, I have plugged them and can set their speed via the Gigabyte Windows App but AIDA64 does not list them only CPU fan. desdump.txt isasensordump.txt Quote
