Anthonymcd95 Posted August 14, 2021 Posted August 14, 2021 Good afternoon, I cannot find a Fan speed moniter to add to my sensor panel. I have the fans controlled by TT RGB + software, checked compatilibilty support in aida was on. Any suggestions fans work fine, on controller that came with them from Thermaltake? I can see fan speeds etc in TT Software. Attached is a Screen Shot of the options for Fan Speeds only GPU comes up. Any support would be loved! Quote
Anthonymcd95 Posted August 14, 2021 Author Posted August 14, 2021 Here is the USB DEbug if that helps ------[ Versions ]------ Program Version : AIDA64 Extreme v6.33.5700 BenchDLL Version: 4.5.846.8-x64 Windows Version : Microsoft Windows 10 Pro 10.0.19043.1165 (64-bit) GetProductInfo : 0x00000030 ------[ Motherboard Info ]------ Motherboard ID : 63-0100-000001-00101111-090216-Chipset$0AAAA000_BIOS DATE: 06/05/20 13:17:43 VER: VA.B0 Motherboard Model : MSI Z370 Gaming Pro Carbon (MS-7B45) Motherboard Chipset : Intel Kaby Point Z370, Intel Coffee Lake-S DMI MB Manufacturer : Micro-Star International Co., Ltd. DMI MB Product : Z370 GAMING PRO CARBON (MS-7B45) DMI MB Version : 2.0 DMI MB Serial : I216175696 DMI SYS Manufacturer: Micro-Star International Co., Ltd. DMI SYS Product : MS-7B45 DMI SYS Version : 2.0 DMI SYS Serial : Default string DMI BIOS Version : A.B0 ------[ USB Devices ]------ Intel(R) USB 3.0 eXtensible Host Controller - 1.0 (Microsoft) - [Port 1] USB Composite Device (Razer BlackWidow Ultimate 2013) - - USB Input Device - - - HID Keyboard Device - - USB Input Device - - - HID-compliant consumer control device - - - HID-compliant device - - - HID-compliant device - - - HID-compliant system controller - - - HID Keyboard Device - - USB Input Device - - - HID-compliant mouse - [Port 2] Xbox One Controller (Controller) - - USB Input Device - - - XINPUT compatible HID device - [Port 3] < No Device Connected > - [Port 4] < No Device Connected > - [Port 5] < No Device Connected > - [Port 6] < No Device Connected > - [Port 7] < No Device Connected > - [Port 8] USB Input Device - - HID-compliant vendor-defined device - [Port 9] Xbox Gaming Device (RIG WX1) - - Xbox Controller - - - Headphones (Xbox Controller) - - - Headset Microphone (Xbox Controller) - [Port 10] USB Composite Device (USB 2.0 Camera) - - CyberTrack H4 - - USB 2.0 Camera - - - Microphone (USB 2.0 Camera) - [Port 11] Generic USB Hub (USB2.0 Hub) - - [Port 1] Generic USB Hub (USB2.0 Hub) - - - [Port 1] < No Device Connected > - - - [Port 2] USB Input Device - - - - HID-compliant vendor-defined device - - - [Port 3] < No Device Connected > - - - [Port 4] < No Device Connected > - - [Port 2] Generic USB Hub - - - [Port 1] USB Input Device (LEDFanBox) - - - - HID-compliant vendor-defined device - - - [Port 2] < No Device Connected > - - [Port 3] < No Device Connected > - - [Port 4] USB Mass Storage Device (Cruzer Blade) - - - SanDisk Cruzer Blade USB Device - [Port 12] Generic USB Hub - - [Port 1] < No Device Connected > - - [Port 2] < No Device Connected > - - [Port 3] < No Device Connected > - - [Port 4] < No Device Connected > - [Port 13] NETGEAR A7000 WiFi USB3.0 Adapter (A7000) - - Microsoft Wi-Fi Direct Virtual Adapter #2 - - Microsoft Wi-Fi Direct Virtual Adapter - [Port 14] USB Composite Device (Razer DeathAdder 2013) - - USB Input Device - - - HID-compliant mouse - - USB Input Device - - - HID-compliant consumer control device - - - HID-compliant device - - - HID-compliant device - - - HID-compliant system controller - - - HID Keyboard Device - - USB Input Device - - - HID Keyboard Device - [Port 15] < No Device Connected > - [Port 16] < No Device Connected > - [Port 17] < No Device Connected > - [Port 18] < No Device Connected > - [Port 19] < No Device Connected > - [Port 20] < No Device Connected > - [Port 21] < No Device Connected > - [Port 22] < No Device Connected > - [Port 23] < No Device Connected > - [Port 24] < No Device Connected > - [Port 25] < No Device Connected > - [Port 26] < No Device Connected > ASMedia USB 3.1 eXtensible Host Controller - 1.10 (Microsoft) - [Port 1] < No Device Connected > - [Port 2] < No Device Connected > - [Port 3] < No Device Connected > - [Port 4] < No Device Connected > ------[ USB Composite Device]------ Device Description : USB Composite Device Device ID : 1532-011A Device Class : 03 / 01 (Human Interface Device) Device Protocol : 01 Revision : 0200h Manufacturer : Razer Product : Razer BlackWidow Ultimate 2013 Supported USB Version: 2.00 Current Speed : Full (USB 1.1) ------[ Xbox One Controller]------ Device Description : Xbox One Controller Device ID : 045E-02EA Device Class : FF / 47 Device Protocol : D0 Revision : 0408h Manufacturer : Microsoft Product : Controller Serial Number : 3032363030313737323934373530 Supported USB Version: 2.00 Current Speed : Full (USB 1.1) ------[ USB Input Device]------ Device Description : USB Input Device Device ID : 264A-2329 Device Class : 03 / 00 (Human Interface Device) Device Protocol : 00 Revision : 0002h Supported USB Version: 2.00 Current Speed : Full (USB 1.1) ------[ Xbox Gaming Device]------ Device Description : Xbox Gaming Device Device ID : 047F-C060 Device Class : FF / 47 Device Protocol : D0 Revision : 0401h Manufacturer : Plantronics Product : RIG WX1 Supported USB Version: 2.00 Current Speed : Full (USB 1.1) ------[ USB Composite Device]------ Device Description : USB Composite Device Device ID : 0C45-636B Device Class : EF / 02 (Interface Association Descriptor) Device Protocol : 01 Revision : 0100h Manufacturer : Sonix Technology Co., Ltd. Product : USB 2.0 Camera Serial Number : SN0001 Supported USB Version: 2.00 Current Speed : High (USB 2.0) ------[ Generic USB Hub]------ Device Description : Generic USB Hub Device ID : 05E3-0608 Device Class : 09 / 00 (Hi-Speed Hub with single TT) Device Protocol : 01 Revision : 6070h Product : USB2.0 Hub Supported USB Version: 2.00 Current Speed : High (USB 2.0) ------[ Generic USB Hub]------ Device Description : Generic USB Hub Device ID : 05E3-0608 Device Class : 09 / 00 (Hi-Speed Hub with single TT) Device Protocol : 01 Revision : 8536h Product : USB2.0 Hub Supported USB Version: 2.00 Current Speed : High (USB 2.0) ------[ USB Input Device]------ Device Description : USB Input Device Device ID : 264A-2199 Device Class : 03 / 00 (Human Interface Device) Device Protocol : 00 Revision : 0000h Supported USB Version: 1.10 Current Speed : Full (USB 1.1) ------[ Generic USB Hub]------ Device Description : Generic USB Hub Device ID : 0424-2512 Device Class : 09 / 00 (Hi-Speed Hub with multiple TTs) Device Protocol : 02 Revision : 0BB3h Supported USB Version: 2.00 Current Speed : High (USB 2.0) ------[ USB Input Device]------ Device Description : USB Input Device Device ID : 264A-2261 Device Class : 03 / 00 (Human Interface Device) Device Protocol : 00 Revision : 0100h Manufacturer : TT Product : LEDFanBox Supported USB Version: 2.00 Current Speed : Full (USB 1.1) ------[ USB Mass Storage Device]------ Device Description : USB Mass Storage Device Device ID : 0781-5567 Device Class : 08 / 06 (Mass Storage) Device Protocol : 50 Revision : 0100h Manufacturer : SanDisk Product : Cruzer Blade Serial Number : 4C530001210329113043 Supported USB Version: 2.10 Current Speed : High (USB 2.0) ------[ Generic USB Hub]------ Device Description : Generic USB Hub Device ID : 05E3-0608 Device Class : 09 / 00 (Hi-Speed Hub with single TT) Device Protocol : 01 Revision : 6070h Supported USB Version: 2.00 Current Speed : High (USB 2.0) ------[ NETGEAR A7000 WiFi USB3.0 Adapter]------ Device Description : NETGEAR A7000 WiFi USB3.0 Adapter Device ID : 0846-9054 Device Class : FF / FF Device Protocol : FF Revision : 0000h Manufacturer : Realtek Product : A7000 Serial Number : 123456 Supported USB Version: 2.10 Current Speed : High (USB 2.0) ------[ USB Composite Device]------ Device Description : USB Composite Device Device ID : 1532-0037 Device Class : 03 / 01 (Human Interface Device) Device Protocol : 02 Revision : 0200h Manufacturer : Razer Product : Razer DeathAdder 2013 Supported USB Version: 2.00 Current Speed : Full (USB 1.1) ------[ DevClass / USB Hubs ]------ <DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#5&408c5b2&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>93</DEVINST><INSTANCE>USB\ROOT_HUB30\5&408C5B2&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR> <DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0608#5&ece646b&0&12#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>137</DEVINST><INSTANCE>USB\VID_05E3&PID_0608\5&ECE646B&0&12</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000C</ADDR><REV>6070</REV> <DESC>USB Root Hub (USB 3.0)</DESC><DEVPATH>\\?\usb#root_hub30#4&3188df39&0&0#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>141</DEVINST><INSTANCE>USB\ROOT_HUB30\4&3188DF39&0&0</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000000</ADDR> <DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0608#5&ece646b&0&11#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>136</DEVINST><INSTANCE>USB\VID_05E3&PID_0608\5&ECE646B&0&11</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000B</ADDR><REV>6070</REV> <DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_0424&pid_2512#6&e6be844&0&2#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>106</DEVINST><INSTANCE>USB\VID_0424&PID_2512\6&E6BE844&0&2</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0;;3</REV> <DESC>Generic USB Hub</DESC><DEVPATH>\\?\usb#vid_05e3&pid_0608#6&e6be844&0&1#{f18a0e88-c30c-11d0-8815-00a0c906bed8}</DEVPATH><DEVINST>143</DEVINST><INSTANCE>USB\VID_05E3&PID_0608\6&E6BE844&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>8536</REV> ------[ DevClass / USB Devices ]------ <DESC>USB Input Device</DESC><DEVPATH>\\?\usb#vid_264a&pid_2199#7&2d91185&0&2#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>33</DEVINST><INSTANCE>USB\VID_264A&PID_2199\7&2D91185&0&2</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0000</REV> <DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_0c45&pid_636b#sn0001#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>166</DEVINST><INSTANCE>USB\VID_0C45&PID_636B\SN0001</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000A</ADDR><REV>0100</REV> <DESC>USB Input Device</DESC><DEVPATH>\\?\usb#vid_264a&pid_2261#7&38b35d3f&3&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>161</DEVINST><INSTANCE>USB\VID_264A&PID_2261\7&38B35D3F&3&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV> <DESC>Xbox Gaming Device</DESC><DEVPATH>\\?\usb#vid_047f&pid_c060#5&ece646b&0&9#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>117</DEVINST><INSTANCE>USB\VID_047F&PID_C060\5&ECE646B&0&9</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000009</ADDR><REV>0401</REV> <DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_1532&pid_0037#5&ece646b&0&14#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>129</DEVINST><INSTANCE>USB\VID_1532&PID_0037\5&ECE646B&0&14</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000E</ADDR><REV>0200</REV> <DESC>NETGEAR A7000 WiFi USB3.0 Adapter</DESC><DEVPATH>\\?\usb#vid_0846&pid_9054#123456#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>118</DEVINST><INSTANCE>USB\VID_0846&PID_9054\123456</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>0000000D</ADDR><REV>0000</REV> <DESC>USB Input Device</DESC><DEVPATH>\\?\usb#vid_264a&pid_2329#5&ece646b&0&8#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>180</DEVINST><INSTANCE>USB\VID_264A&PID_2329\5&ECE646B&0&8</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000008</ADDR><REV>0002</REV> <DESC>Xbox One Controller</DESC><DEVPATH>\\?\usb#vid_045e&pid_02ea#3032363030313737323934373530#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>61</DEVINST><INSTANCE>USB\VID_045E&PID_02EA\3032363030313737323934373530</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000002</ADDR><REV>0408</REV> <DESC>USB Mass Storage Device</DESC><DEVPATH>\\?\usb#vid_0781&pid_5567#4c530001210329113043#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>139</DEVINST><INSTANCE>USB\VID_0781&PID_5567\4C530001210329113043</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000004</ADDR><REV>0100</REV> <DESC>USB Composite Device</DESC><DEVPATH>\\?\usb#vid_1532&pid_011a#5&ece646b&0&1#{a5dcbf10-6530-11d2-901f-00c04fb951ed}</DEVPATH><DEVINST>134</DEVINST><INSTANCE>USB\VID_1532&PID_011A\5&ECE646B&0&1</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV> ------[ DevClass / Human Interface Devices ]------ <DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0037&mi_01&col01#7&37972087&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>3</DEVINST><INSTANCE>HID\VID_1532&PID_0037&MI_01&COL01\7&37972087&0&0000</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV> <DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0037&mi_02#7&2d5c0da9&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>4</DEVINST><INSTANCE>HID\VID_1532&PID_0037&MI_02\7&2D5C0DA9&0&0000</INSTANCE><BUSNUM>00000006</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV> <DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#vid_1532&pid_0037&mi_00#7&13bfe2c5&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>5</DEVINST><INSTANCE>HID\VID_1532&PID_0037&MI_00\7&13BFE2C5&0&0000</INSTANCE><BUSNUM>00000004</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV> <DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_264a&pid_2199#8&35a7e48b&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>7</DEVINST><INSTANCE>HID\VID_264A&PID_2199\8&35A7E48B&0&0000</INSTANCE><BUSNUM>00000008</BUSNUM><ADDR>00000001</ADDR><REV>0000</REV> <DESC>XINPUT compatible HID device</DESC><DEVPATH>\\?\hid#vid_045e&pid_02ff&ig_00#7&1892e1cf&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>187</DEVINST><INSTANCE>HID\VID_045E&PID_02FF&IG_00\7&1892E1CF&0&0000</INSTANCE><BUSNUM>0000000E</BUSNUM><ADDR>00000001</ADDR> <DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0037&mi_01&col02#7&37972087&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>8</DEVINST><INSTANCE>HID\VID_1532&PID_0037&MI_01&COL02\7&37972087&0&0001</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000002</ADDR><REV>0200</REV> <DESC>HID-compliant system controller</DESC><DEVPATH>\\?\hid#vid_1532&pid_0037&mi_01&col03#7&37972087&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>9</DEVINST><INSTANCE>HID\VID_1532&PID_0037&MI_01&COL03\7&37972087&0&0002</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000003</ADDR><REV>0200</REV> <DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0037&mi_01&col04#7&37972087&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>10</DEVINST><INSTANCE>HID\VID_1532&PID_0037&MI_01&COL04\7&37972087&0&0003</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000004</ADDR><REV>0200</REV> <DESC>HID-compliant consumer control device</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_01&col02#7&22db07cf&0&0001#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>11</DEVINST><INSTANCE>HID\VID_1532&PID_011A&MI_01&COL02\7&22DB07CF&0&0001</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000002</ADDR><REV>0200</REV> <DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_01&col01#7&22db07cf&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>12</DEVINST><INSTANCE>HID\VID_1532&PID_011A&MI_01&COL01\7&22DB07CF&0&0000</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV> <DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_264a&pid_2329#6&3b26bac1&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>13</DEVINST><INSTANCE>HID\VID_264A&PID_2329\6&3B26BAC1&0&0000</INSTANCE><BUSNUM>00000003</BUSNUM><ADDR>00000001</ADDR><REV>0002</REV> <DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_0037&mi_01&col05#7&37972087&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>14</DEVINST><INSTANCE>HID\VID_1532&PID_0037&MI_01&COL05\7&37972087&0&0004</INSTANCE><BUSNUM>00000005</BUSNUM><ADDR>00000005</ADDR><REV>0200</REV> <DESC>HID-compliant mouse</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_02#7&faaeb91&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>15</DEVINST><INSTANCE>HID\VID_1532&PID_011A&MI_02\7&FAAEB91&0&0000</INSTANCE><BUSNUM>00000002</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV> <DESC>HID-compliant system controller</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_01&col03#7&22db07cf&0&0002#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>16</DEVINST><INSTANCE>HID\VID_1532&PID_011A&MI_01&COL03\7&22DB07CF&0&0002</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000003</ADDR><REV>0200</REV> <DESC>HID Keyboard Device</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_00#7&360b240d&0&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}\kbd</DEVPATH><DEVINST>17</DEVINST><INSTANCE>HID\VID_1532&PID_011A&MI_00\7&360B240D&0&0000</INSTANCE><BUSNUM>00000000</BUSNUM><ADDR>00000001</ADDR><REV>0200</REV> <DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_01&col04#7&22db07cf&0&0003#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>18</DEVINST><INSTANCE>HID\VID_1532&PID_011A&MI_01&COL04\7&22DB07CF&0&0003</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000004</ADDR><REV>0200</REV> <DESC>HID-compliant device</DESC><DEVPATH>\\?\hid#vid_1532&pid_011a&mi_01&col05#7&22db07cf&0&0004#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>19</DEVINST><INSTANCE>HID\VID_1532&PID_011A&MI_01&COL05\7&22DB07CF&0&0004</INSTANCE><BUSNUM>00000001</BUSNUM><ADDR>00000005</ADDR><REV>0200</REV> <DESC>HID-compliant vendor-defined device</DESC><DEVPATH>\\?\hid#vid_264a&pid_2261#8&9204bc8&9&0000#{4d1e55b2-f16f-11cf-88cb-001111000030}</DEVPATH><DEVINST>20</DEVINST><INSTANCE>HID\VID_264A&PID_2261\8&9204BC8&9&0000</INSTANCE><BUSNUM>00000009</BUSNUM><ADDR>00000001</ADDR><REV>0100</REV> ------[ HID Device Info / HID-compliant vendor-defined device ]------ Device ID : 264A-2199 Revision : 0000h Device Instance : HID\VID_264A&PID_2199\8&35A7E48B&0&0000 Usage : 0001h Usage Page : FF00h Input Report Byte Length : 65 Output Report Byte Length : 65 Feature Report Byte Length: 0 ------[ HID Device Info / XINPUT compatible HID device ]------ Product : Controller (Xbox One For Windows) Device ID : 045E-02FF Revision : 0000h Device Instance : HID\VID_045E&PID_02FF&IG_00\7&1892E1CF&0&0000 Usage : 0005h Usage Page : 0001h Input Report Byte Length : 16 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ HID Device Info / HID-compliant consumer control device ]------ Manufacturer : Razer Product : Razer DeathAdder 2013 Device ID : 1532-0037 Revision : 0200h Device Instance : HID\VID_1532&PID_0037&MI_01&COL02\7&37972087&0&0001 Usage : 0001h Usage Page : 000Ch Input Report Byte Length : 16 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ HID Device Info / HID-compliant system controller ]------ Manufacturer : Razer Product : Razer DeathAdder 2013 Device ID : 1532-0037 Revision : 0200h Device Instance : HID\VID_1532&PID_0037&MI_01&COL03\7&37972087&0&0002 Usage : 0080h Usage Page : 0001h Input Report Byte Length : 16 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ HID Device Info / HID-compliant device ]------ Manufacturer : Razer Product : Razer DeathAdder 2013 Device ID : 1532-0037 Revision : 0200h Device Instance : HID\VID_1532&PID_0037&MI_01&COL04\7&37972087&0&0003 Usage : 0000h Usage Page : 0001h Input Report Byte Length : 16 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ HID Device Info / HID-compliant consumer control device ]------ Manufacturer : Razer Product : Razer BlackWidow Ultimate 2013 Device ID : 1532-011A Revision : 0200h Device Instance : HID\VID_1532&PID_011A&MI_01&COL02\7&22DB07CF&0&0001 Usage : 0001h Usage Page : 000Ch Input Report Byte Length : 16 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ HID Device Info / HID-compliant vendor-defined device ]------ Device ID : 264A-2329 Revision : 0002h Device Instance : HID\VID_264A&PID_2329\6&3B26BAC1&0&0000 Usage : 0001h Usage Page : FF00h Input Report Byte Length : 65 Output Report Byte Length : 65 Feature Report Byte Length: 0 ------[ HID Device Info / HID-compliant device ]------ Manufacturer : Razer Product : Razer DeathAdder 2013 Device ID : 1532-0037 Revision : 0200h Device Instance : HID\VID_1532&PID_0037&MI_01&COL05\7&37972087&0&0004 Usage : 0000h Usage Page : 0001h Input Report Byte Length : 16 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ HID Device Info / HID-compliant system controller ]------ Manufacturer : Razer Product : Razer BlackWidow Ultimate 2013 Device ID : 1532-011A Revision : 0200h Device Instance : HID\VID_1532&PID_011A&MI_01&COL03\7&22DB07CF&0&0002 Usage : 0080h Usage Page : 0001h Input Report Byte Length : 16 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ HID Device Info / HID-compliant device ]------ Manufacturer : Razer Product : Razer BlackWidow Ultimate 2013 Device ID : 1532-011A Revision : 0200h Device Instance : HID\VID_1532&PID_011A&MI_01&COL04\7&22DB07CF&0&0003 Usage : 0000h Usage Page : 0001h Input Report Byte Length : 16 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ HID Device Info / HID-compliant device ]------ Manufacturer : Razer Product : Razer BlackWidow Ultimate 2013 Device ID : 1532-011A Revision : 0200h Device Instance : HID\VID_1532&PID_011A&MI_01&COL05\7&22DB07CF&0&0004 Usage : 0000h Usage Page : 0001h Input Report Byte Length : 16 Output Report Byte Length : 0 Feature Report Byte Length: 0 ------[ HID Device Info / HID-compliant vendor-defined device ]------ Manufacturer : TT Product : LEDFanBox Device ID : 264A-2261 Revision : 0100h Device Instance : HID\VID_264A&PID_2261\8&9204BC8&9&0000 Usage : 0001h Usage Page : FF00h Input Report Byte Length : 65 Output Report Byte Length : 193 Feature Report Byte Length: 0 ------[ DevClass / COM Ports ]------ < No COM Port Found > ------[ DevClass / LPT Ports ]------ < No LPT Port Found > ------[ DevClass / Modems ]------ < No Modem Found > ------[ DevClass / SideShow Devices ]------ < No SideShow Device Found > ------[ DevClass / GX3 Devices ]------ < No GX3 Device Found > ------[ DevClass / USBXpress Devices ]------ < No USBXpress Device Found > ------[ DevClass / WinUSB Devices ]------ < No WinUSB Device Found > ------[ LibUsb0 Devices ]------ < No LibUsb0 Device Found > ------[ CH341 Devices ]------ < No CH341 Device Found > ------[ FTD2xx Devices ]------ < No FTD2xx Device Found > ------[ LibMPSSE Devices ]------ < No LibMPSSE Device Found > ------[ SiUSBXp Devices ]------ SiUSBXp.dll Path = C:\Program Files (x86)\EVGA\LED Sync\SiUSBXp.dll DLL Version = 3.5.0.0 Driver Version = < No SiUSBXp Device Found > ------[ T-Balancer Devices ]------ < No T-Balancer Device Found > ------[ Koolance TMS-200 Devices ]------ < No T-Koolance TMS-200 Device Found > ------[ GRID+ V3 Devices ]------ < No GRID+ V3 Device Found > ------[ Smart Dev V2 Devices ]------ < No Smart Dev V2 Device Found > ------[ Kraken X-2/X-3 Devices ]------ < No Kraken X-2/X-3 Device Found > Quote
Anthonymcd95 Posted August 19, 2021 Author Posted August 19, 2021 Bump If anyone has any info you can pm me or if this isnt allowed I can delete the thread? Quote
Fiery Posted August 26, 2021 Posted August 26, 2021 On 8/19/2021 at 12:28 AM, Anthonymcd95 said: Bump If anyone has any info you can pm me or if this isnt allowed I can delete the thread? Expand Riing Quad seems to use a new protocol that currently is not supported by AIDA64. We'll order a Riing Quad set and check out the controller's new protocol and will implement support for it if possible. 2 Quote
Arthur Tylingo Posted September 8, 2021 Posted September 8, 2021 same here, thermaltake gen 3 controller not recognized in aida64 Quote
Alpharius68 Posted December 7, 2021 Posted December 7, 2021 Is this why the TT ring duo fans don’t show up in Aida64, would love to have some fan speed info to display. 1 Quote
mads Posted January 2, 2022 Posted January 2, 2022 On 8/26/2021 at 12:48 PM, Fiery said: Riing Quad seems to use a new protocol that currently is not supported by AIDA64. We'll order a Riing Quad set and check out the controller's new protocol and will implement support for it if possible. Expand is there any news about Thermaltake Riing Quad fan support 1 Quote
HuntSekker Posted April 12, 2023 Posted April 12, 2023 Any movement on support for these TT fan controllers. I have 5 of these controllers in my rig, three of which run the fans, two run some of the other RGB stuff. I really could do with Fan speed monitoring if possbile. Is there anything I could do to help here, managed to write my own code to get them into Signal RGB, would be a full house to get them in here - been watching for an update for 6 months. Please - would be so helpful. Quote
