byw7 Posted June 15, 2012 Posted June 15, 2012 On opening of Aida 64 Business (2.50.2000) now sounds more immediately Ding Dong the noise, that you hear when a USB drive connects or disconnects from the PC. There is no external USB drive (flash drive / USB hard drive) connected! How can I stop this? How can I solve the problem? Kind Regards byw7 Quote
Fiery Posted June 15, 2012 Posted June 15, 2012 In case you don't have any RAID arrays defined and you don't have any external storage devices connected, then you can try disabling RAID member enumeration and RAID SMART support in AIDA64 / main menu / File / Preferences / Stability. You need to restart AIDA64 after altering those options. Regards, Fiery Quote
byw7 Posted June 15, 2012 Author Posted June 15, 2012 Thank you, Fiery! The Option: Low -level SMART operations war my problem! Tick removed-again "peace" is. Quote
