steve17 Posted September 28, 2021 Posted September 28, 2021 I have the latest Aida64. 6.33.5700. I'm using an ASrock extreme wifi 6E mobo. The 2 fans I normally use show up okay in Aida64. So I don't have a problem, but I noticed when I plugged in a fan in another header to check the speed, it didn't show up in Aida 64, but it did show up in the BIOS. It's the CHA_FAN4 that is missing. Quote
Fiery Posted September 28, 2021 Posted September 28, 2021 1 hour ago, steve17 said: I have the latest Aida64. 6.33.5700. I'm using an ASrock extreme wifi 6E mobo. The 2 fans I normally use show up okay in Aida64. So I don't have a problem, but I noticed when I plugged in a fan in another header to check the speed, it didn't show up in Aida 64, but it did show up in the BIOS. It's the CHA_FAN4 that is missing. Make sure to upgrade to the latest beta version of AIDA64 Extreme available at: https://www.aida64.com/downloads/latesta64xebeta After upgrading to this new version, make sure to restart Windows to finalize the upgrade. If it doesn't help, please right-click on the bottom status bar of AIDA64 main window --> Sensor Debug --> ISA Sensor Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Thanks, Fiery Quote
