athlon64 Posted June 22, 2012 Posted June 22, 2012 I just upgraded to aida64 extreme 2.50. I love sensor pannel! Such a good feature , i have configured it and put part of my wallpaper in it so it looks transparent. I got rid of 2 gadgets thanks to it. Now the only concern i have is saving it. I spent 2 hours making it so i don"t want to repeat it in the future. I read somewhere on this forum that if i want to save aida64 settings i have to back up AIDA64.INI file in aida installation folder. But i searched for it and it doesn"t seem to be there. Help please? Quote
Fiery Posted June 22, 2012 Posted June 22, 2012 1) AIDA64.INI file can be found in the AIDA64 installation folder, e.g. C:\Program Files (x86)\FinalWire\AIDA64 Extreme Edition. 2) You can backup only your SensorPanel settings if you right-click on the SensorPanel --> SensorPanel Manager --> push the Export button. Regards, Fiery Quote
athlon64 Posted June 22, 2012 Author Posted June 22, 2012 Here is a screenshot of aida64 installation folder: http://imageshack.us/photo/my-images/18/desktop2012062220281703.jpg/ i really can"T find any .INI files? Btw i have allready backed up sensor pannel but where do i put that backup file in case i reinstall aida? Quote
Fiery Posted June 22, 2012 Posted June 22, 2012 The AIDA64.INI file is right under the .manifest file. Windows hides the file extension You can import a .sensorpanel file if you push the Import button in the SensorPanel Manager. Quote
