MOST Posted November 1, 2021 Posted November 1, 2021 Hi there, I have the Remote Sensor Panel running on an iPad. Recently I have added the power sensor for my GPU so it shows how many watts it's using. However, it shows it with two decimals like this "348.71 W" Is there any way to remove the decimals so I just have the "rounded" wattage number? Quote
Fiery Posted November 8, 2021 Posted November 8, 2021 On 11/1/2021 at 2:14 PM, MOST said: Hi there, I have the Remote Sensor Panel running on an iPad. Recently I have added the power sensor for my GPU so it shows how many watts it's using. However, it shows it with two decimals like this "348.71 W" Is there any way to remove the decimals so I just have the "rounded" wattage number? You can configure the number of decimal digits to be displayed for each sensor reading in AIDA64 / main menu / File / Preferences / Hardware Monitoring. 1 Quote
MOST Posted November 8, 2021 Author Posted November 8, 2021 Thx Fiery for always being here and helping out - but also sorry man, I should have known there is a setting for that. My bad Quote
