Sierra4 Posted November 5, 2021 Posted November 5, 2021 Hi all, New to AIDA and did my first 10" sensor panel which I'm very pleased with. Wish there were larger gauges built in though. Anyway, is there a way to monitor other items on your network such as Unifi gateways and Access Points? Being able to put some key info from the Unifi controller dashboard onto the Aida panel would be brilliant. Thanks All. Quote
Fiery Posted November 8, 2021 Posted November 8, 2021 On 11/5/2021 at 5:33 PM, Sierra4 said: Hi all, New to AIDA and did my first 10" sensor panel which I'm very pleased with. Wish there were larger gauges built in though. Anyway, is there a way to monitor other items on your network such as Unifi gateways and Access Points? Being able to put some key info from the Unifi controller dashboard onto the Aida panel would be brilliant. Thanks All. AIDA64 currently doesn't support such monitoring sources. Quote
Sierra4 Posted November 14, 2021 Author Posted November 14, 2021 Thanks you Fiery. It's a shame but thanks for letting me know. Quote
