Fusion Posted November 7, 2021 Share Posted November 7, 2021 Hi All looking to internally wire my sensor panel to a USB2 header splitter cable. 1x for power and 1x into a USB2 display adapter. Can someone recommend one that works at that resolution to match the screen? Thanks Quote Link to comment Share on other sites More sharing options...
SpeedyV Posted November 12, 2021 Share Posted November 12, 2021 On 11/7/2021 at 6:15 AM, Fusion said: Hi All looking to internally wire my sensor panel to a USB2 header splitter cable. 1x for power and 1x into a USB2 display adapter. Can someone recommend one that works at that resolution to match the screen? Thanks I am searching for the same exact thing so please post back here if you find one and I will do the same. I already have an Ingcool 1024x600 internal display. For that one I am using a Pluggable USB2.0 to DVI adapter with a DVI to HDMI passive adapter. Kind of messy but it works. The Pluggable spec does not list 1024x600 but its doing it. I tried a Startech USB2.0 to HDMI adapter but it would not do 1024x600. Now I bought a Formulamod clone of the Barrowch FBEHD-01 display (1920x480). I tried a J5 Create JUA250 USB2.0 to HDMI adapter but it would not do 1920x480. My main GPU (Asus TUF 3080OC) will do it but I want to keep the wiring internal to the case and not use a main GPU output. These adapters are a crap shoot in terms of whether they will do non-standard resolutions. Very few list all resolutions they will do. In the case of the Pluggable, its one of the few that (supposedly) lists all supported resolutions, but mine is doing 1024x600 which is not listed, so who knows. I have not tried connecting the Pluggable to the 1920x480 display but I will. If it works, I will post back here. Quote Link to comment Share on other sites More sharing options...
Fusion Posted January 4, 2022 Author Share Posted January 4, 2022 Hi SpeedyV - Thanks for the response on this. Oddly thought id checked this thread more recently than this and not spotted your reply. As I didn't spot your thread I went and got that usb2 Startech and found it didn't work at that resolution your just get a bunch of trippy lines! Ill sling that on ebay when I get chance. Like you I have a 3080TI FE however I use all 4 displays off it. I've considered putting in a spare WX4100 that I have kicking around but its overkill, will ruin the look of my case and lead to routing wires outside the case. Ideally I want to use the spare USB2 headers I have on the motherboard but ill consider sacrificing a USB3 one if someone can confirm it will do the 1920x480 resolution Thanks Quote Link to comment Share on other sites More sharing options...
Fusion Posted February 6, 2022 Author Share Posted February 6, 2022 Surely someone on here has found a USB display adapter that does 1920x480…. It’s one (if not the) most common display size. getting a bit tiresome buying usb display adapters and sending them back Please please help! Quote Link to comment Share on other sites More sharing options...
SpeedyV Posted February 9, 2022 Share Posted February 9, 2022 I ended up using a Monoprice clone of the Pluggable UGA-165 for my 1920x480 display. It is annoying that these are USB2.0 to DVI because I had to add passive DVI to HDMI adapters on both of them. The original Pluggable UGA-165 is driving my Ingcool 1024x600 display and the Monoprice version is driving my FormulaMod 1920x480 display. They are a little bulky, and the DVI to HDMI adapter makes it worse, but they work. They are also still available. There are many generic versions of these adapters. I think if they say "DisplayLink" on them they are using the same chipset so should do these resolutions. Quote Link to comment Share on other sites More sharing options...
Fusion Posted February 11, 2022 Author Share Posted February 11, 2022 Cheers SpeedyV Owe you one! Tried cheap ones tried expensive ones even obscure ones! Noting would work. Space behind the MB tray is good I’m my case so should be simple to hide. Going to order that plugable one on eBay for £60 now and a dvi adapter. FYI not sure all displaylink ones work as I tried a Dell laptop port replicator with displaylink on and it didn’t work! cheers again Quote Link to comment Share on other sites More sharing options...
Fusion Posted February 13, 2022 Author Share Posted February 13, 2022 Works perfect cheers SpeedyV ignore spec its a bit more badass than that! Just grabbed a quick template from the examples thread Quote Link to comment Share on other sites More sharing options...
Scott Hughes Posted January 18, 2023 Share Posted January 18, 2023 Hey Fusion, do you mind sharing that template? I'm having a hard time tracking one down that works at 480x1920. Also, thanks for the tip on the monoprice. I tried a couple of cheap hdmi adapters that didn't work. Going to order one of those now. Quote Link to comment Share on other sites More sharing options...
