Displaying wrong CPU Temp after BIOS update (Gigabyte X570 I Aorus Pro WiFi)
JustKeevin
  • JustKeevin changed the title to Displaying wrong CPU Temp
13 hours ago, JustKeevin said:
I recently updated my Gigabyte X 570 I bios to 35d and Aida64 is reporting wrong CPU temps. It's showing it's 17 and HWINFO shows it as 42. Also the voltages might be messed up as well, CPU and RAM.
  • Fiery changed the title to Displaying wrong CPU Temp after BIOS update (Gigabyte X570 I Aorus Pro WiFi)
