edd080 Posted December 28, 2021 Posted December 28, 2021 Hello there, I currently have an Asus ROG Strix G733QSA laptop and I have been noticing that AIDA64 takes 6% constantly of my System CPU usage; I have read on other threads that this could be due to some stability options namely ECSupport which on Asus motherboards requires this option to be off; however this made no difference in my situation. The only way I managed to solve this was by unchecking GPU sensor support; however since this is now unchecked I do not have any power or temperature readings for my GPU's. Can this be fixed in some way please? I am using the latest version of AIDA64. Thanks. Quote
Fiery Posted December 29, 2021 Posted December 29, 2021 15 hours ago, edd080 said: Hello there, I currently have an Asus ROG Strix G733QSA laptop and I have been noticing that AIDA64 takes 6% constantly of my System CPU usage; I have read on other threads that this could be due to some stability options namely ECSupport which on Asus motherboards requires this option to be off; however this made no difference in my situation. The only way I managed to solve this was by unchecking GPU sensor support; however since this is now unchecked I do not have any power or temperature readings for my GPU's. Can this be fixed in some way please? I am using the latest version of AIDA64. Thanks. Please right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA GPU Registers. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. You may need to enable status bar in AIDA64 / main menu / View first. Also right-click on the bottom status bar of AIDA64 main window --> Video Debug --> nVIDIA SMBus Dump. Copy-paste the full results into this topic, or attach the results as a TXT file to your post. Thanks, Fiery Quote
