Kiel Yam da Silva Alves Posted January 24 Report Share Posted January 24 what now? I opening app check 64-bit or 32-bit. and not everything 64-bit. he separated 32-Bit os and 64-bit processor cpu. can change 32-bit os to 64-bit os android? span widget Quote Link to comment Share on other sites More sharing options...
Fiery Posted January 25 Report Share Posted January 25 9 hours ago, Kiel Yam da Silva Alves said: what now? I opening app check 64-bit or 32-bit. and not everything 64-bit. he separated 32-Bit os and 64-bit processor cpu. can change 32-bit os to 64-bit os android? span widget Please note that AIDA64 shows the current CPU instruction set, as it is utilized by the Android platform. So when your Android platform is 32-bit, AIDA64 will show 32-bit CPU instruction set. It's normal that many 64-bit capable Android devices have a 32-bit Android platform installed. You can only convert an Android platform to 64-bit by installing a new Android firmware update that is 64-bit. You need to consult with the manufacturer of your device and inquire them whether they have such an update for your device. Quote Link to comment Share on other sites More sharing options...
