Hello. I have an Asus notebook and I wanted to monitor its operation with the OSD. But there is a value that is wrong.
The fan RPM.
The notebook has two fans but Aida only detects one. Not to mention the values are wrong.
I know the values are wrong because the Asus app has the correct values there.
When the fans are at 0 AIDA does not detect the fans.
When they are working, it shows a wrong value.
The faster the fan spins, the lower the speed in AIDA
Is there any way to fix this?
1486710212_Capturadeecr2022-01-31104247.thumb.png.d79f393cea4d0919cba34d990f56c0ad.png
The fan RPM.
Hello. Do you already have a solution to the problem that you can give me?
isasensordump.txt
  • 1 year later...
